06-14-2022, 08:24 | #1 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Pakistan
Member: 2684815 Status: Offline Thanks Meter: 133 | LG V50 LMV500N repair Problem [Solved] Checking data...OK Platform: LG Qualcomm Selected port: COM10 Selected model: V500N Reading info... Found model LMV500NA: ÿh0 at port COM9 Model ID: LM-V500N IMEI: 355693-10-537884-1 Android version: 11 Battery level: 79% Mode: Normal Firmware compiled date: Dec 20 2021 Firmware compiled time: 02:00:00 Firmware released date: Feb 21 2022 Firmware released time: 18:04:55 SW Version: MPSS.HE.1.5.3.c1-00125-SM8150_GENFUSION_PACK-1.400300.8.410866.8 IMEI: 000000000000000000 SPC: 000000 Fixing IMEI... New IMEI: 000000000000000000 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Initializing ADB...OK Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.1.9 Software version. |
06-14-2022, 09:16 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please, enable ADB then perform operation again. |
06-14-2022, 12:25 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please, perform this steps correctly 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Then, try to perform operation once again and send us result. |
