Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 11-21-2022, 09:30   #1 (permalink)
Member: 179142
Thanks Meter: 42
LG V500EM Unlock stopped [Answered]
i try to unlock but proces dtop at sending loader.
here is the log
Welcome to Octoplus/Octopus Box LG Software version 3.2.0
Card S/N : 000002xxxx
Work ID: 0000000001B6C5D3
Checking data...OK
Platform: LG Qualcomm
Selected port: COM155
Selected model: V500EM
Reading info...
Found model LMV500EM: h0 at port COM155
Model ID: LM-V500EM
IMEI: 355826-10-004894-0
Android version: 12
Battery level: 88%
Mode: Normal
Firmware compiled date: May 16 2022
Firmware compiled time: 02:00:00
Firmware released date: Jul 12 2022
Firmware released time: 22:10:53
SW Version: MPSS.HE.1.5.3.c1-00125-SM8150_GENFUSION_PACK-
1.400300.8.410866.15
SPC: 000000
Unlocking...
Write security backup function doesn't work for this device with latest
firmware versions. If you'll encounter any problem during Unlock operation
- you won't be able to restore the phone to it's initial state, so proceed at
your own risk.
Continue?
Initializing ADB...OK
ADB Server was found. Trying to kill...
Waiting for phone...OK
Model ID: LM-V500EM
Phone firmware version: LMV500AT-00-V40a-LAO-COM-JUL-13-2022+0
Kernel version: 4.14.190-perf+ ([email protected]) (clang version
10.0.7 for Android NDK, GNU ld (binutils-2.27-bd24d23f) 2.27.0.20170315)
#1 SMP PREEMPT Wed Jul 13 01:51:55 IST 202
Android version: 12
Hardware: Qualcomm Technologies, Inc SM8150 AArch64 Processor rev
14 (aarch64)
Target operator: EEO
Connecting to server 0...OK
Octopus smart card is present.
Checking smart card...OK
Username: gpgindxxxxxxxxxxxxx
Authorizing...OK
Checking balance...OK
Checking operation...OK
Sending device information...OK
Get credits, needed for current operation...OK
Your balance: 100 credits.
To perform "Unlock" operation you need to have 100 credits.
Sending loader...
Performed by 3.2.0 Software version.
Work ID: 00000000018E875C
Checking data...OK
Selected port: COM190
Reading info...
Model ID: LM-V500EM
Android version: 12
Battery level: 87%
Mode: Emergency
Initializing flash...OK
Platform: msmnile
SW version: LMV500EMAT-01-V40a-234-30-JUL-13-2022+0
Android version: 11
LAF Version: 1.1
Product ID: PT02S190513001564
Target operator: LAO
Hardware: rev_10
Unlocking...
your own risk.
Continue?
Switching to Normal mode...
Model ID: LM-V500EM
Android version: 12
14 (aarch64)
Username: gpgxxxxxxxxxxxxx
Authorizing...OK
Sending loader...
Please help
Old 11-21-2022, 09:58   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 26,881
Hello.
Please, perform Factory Reset then repeat the operation and post here log.
Old 11-21-2022, 11:58   #3 (permalink)
Member: 179142
Thanks Meter: 42
i already reset and still the same 1st log was this one
Card S/N : 00000xxxxxx
Work ID: 0000000001B632C9
Checking data...OK
Reading info...
Model ID: LM-V500EM
Android version: 12
Battery level: 91%
Mode: Normal
SPC: 000000
Unlocking...
your own risk.
Continue?
Please, reconnect phone, enable USB debugging, and try again.
To enable USB debugging, please perform the following steps:
1. Disconnect cable
2. Install LG Android ADB drivers
3. Go to "Settings" -> "About phone" -> "Software information"
4. Click on Build number 5 times
5. Enable "Settings" -> "Developer options" -> "USB debugging" option
6. Connect the cable and check, whether ADB interface has appeared in
PC Device Manager.
Work ID: 00000000018DF85E
Checking data...OK
Reading info...
Model ID: LM-V500EM
Android version: 12
Battery level: 91%
Mode: Normal
SPC: 000000
Unlocking...
your own risk.
Continue?
Model ID: LM-V500EM
Android version: 12
14 (aarch64)
Username: gpgindustries177
Authorizing...OK
Sending loader...
Old 11-21-2022, 12:42   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Your phone has a last security patch level which currently is not supported.
Try to reflash the phone to another firmware with Android 11 (V30) then repeat the Unlock operation.
Old 11-22-2022, 04:09   #5 (permalink)
Member: 179142
Thanks Meter: 42
Pardon me sir, if i downgrade phone firmware from 40a to 30a. Will it dead? Some warning in octopus lg say it will be dead if i do downgrade firmware
Old 11-22-2022, 08:08   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
In most cases, the operation is successful and the phone does not damaged but you can perform the operation at your own risk.
Old 11-23-2022, 09:55   #7 (permalink)
Member: 179142
Thanks Meter: 42
pardon me sir, i success downgrading to V20A , whwn i do unlock it says SERVER error. check balance not working too.
The operation was canceled by the userFailed!
Coud not connect to the server!
Connecting to server 1...Failed!
Connecting to server 2...Failed!
Connecting to server 3...Failed!
Connecting to server 0...Failed!
Work ID: 0000000000000000
Checking data...OK
Reading info...
Found model 8937.gen: d at port COM227
Incompatible model ID!
Found model at port COM227
Mode: Normal
Firmware compiled date: Jul 27 2016
Firmware released date: Sep 26 2017
Firmware released time: 04:34:55
SW Version: MPSS.JO.1.2.c2-00092-8937_GENNS_PACK-
1.103461.1.110954.1_V046
IMEI: 359363-09-195812-3
Bluetooth address: 78:02:F8:65:44:5B
Wi-Fi MAC address: 78:02:F8:65:44:5C
Unlocking...
your own risk.
Continue?
Waiting for phone...Failed!
More than one device, connected via ADB, were found. Please disconnect
all devices from PC and connect only the device You want to work with.
Checking data...OK
Reading info...
Model ID: LM-V500EM
Android version: 10
Battery level: 100%
Mode: Normal
Firmware compiled date: Dec 16 2019
Firmware compiled time: 00:00:00
Firmware released date: Jan 24 2020
Firmware released time: 19:46:34
SW Version: MPSS.HE.1.5.2.c8-00160-SM8150_GENFUSION_PACK-
1.237178.16
SPC: 000000
Unlocking...
operation - you won't be able to restore the phone to it's initial state, so
proceed at your own risk.
Continue?
Model ID: LM-V500EM
Phone firmware version: LMV500AT-00-V20a-LAO-COM-JAN-24-2020+0
Kernel version: 4.14.117-perf ([email protected]) (clang version 8.0.12
for Android NDK) #1 SMP PREEMPT Fri Jan 24 20:45:39 IST 202
Android version: 10
14 (aarch64)
Connecting to server 0...Failed!OK
Connecting to server 1...Failed!OK
Connecting to server 2...Failed!OK
Connecting to server 3...Failed!OK
Old 11-23-2022, 10:43   #8 (permalink)
Member: 179142
Thanks Meter: 42
Work ID: 0000000001BCA9CC
Checking data...OK
Reading info...
Model ID: LM-V500EM
Android version: 10
Battery level: 100%
Mode: Normal
1.237178.16
SPC: 000000
Unlocking...
your own risk.
Continue?
Model ID: LM-V500EM
Android version: 10
14 (aarch64)
Authorizing...OK
Sending loader...
Prepairing for change protect status...OK
Reading QCN...
Send SPC...OK
Reading Mobile Property...OK
Reading Feature Mask...OK
Reading Roaming List 0...OK
Reading NV_Numbered Items...OK
Reading NV_Numbered SIM1 Items...OK
Reading NV_Numbered SIM2 Items...OK
Reading NV Items...OK
Reading EFS...OK
Reading Provisioning Items...OK
Reading QCN done!
Backup saved to "V500EM_355826100048940_23-11-2022_16-18-00.qcn"
Switching to Download mode...OK
Platform: msmnile
SW version: LMV500EMAT-01-V20a-234-30-JAN-24-2020+0
Android version: 10
LAF Version: 1.1
Hardware: rev_10
Reading partitions...OK
Reading security area...Failed!
LAF Error: 80000119.
Writing security area...
Reconnecting phone...OK
Initializing flash...OKOK
Found model LMV500EM* h0 at port COM155
Send SPC...OK
Writing QCN...
Writing NV_Numbered Items...OK
Writing NV_Numbered SIM1 Items...OK
Writing NV_Numbered SIM2 Items...OK
Writing QCN done!
Phone successfully unlocked!
Rebooting phone...
unlock done but no service? signal is not coming
Old 11-25-2022, 07:23   #9 (permalink)
Member: 179142
Thanks Meter: 42
i write firmware v20, v30 and v40 but imei is null
Checking data...OK
Reading info...
Found model at port COM155
Mode: Normal
1.237178.16
IMEI: 359363-09-xxxxx-x
SPC: 000000
Opening "V500EM40a_00_0713.kdz"...OK
Firmware version: V50040a
Firmware model: LM-V500
Firmware type: 0100
Writing phone firmware without real necessity is at your own risk.
Downgrade may lead to phone damage!
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones,
modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without any
installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to your
computer during the flashing!
Prepairing firmware...OK
Selecting firmware partitions...OK
Selected default partitions!
Platform: msmnile
SW version: LMV500EMAT-00-V20a-LAO-SI-JAN-24-2020+0
Android version: 10
LAF Version: 1.1
IMEI: 359363-09-195820-6
Hardware: rev_10
Sending signature...OK
Setting options...OK
Do you want to format User Data?
Formating USERDATA...OK
Formating ENCRYPT...OK
Writing 1/161 gpt_main0.bin_0...OK
Writing 2/161 persist.img_15368...OK
Writing 3/161 ftm.img_23816...Skipped!
Writing 4/161 vendor_0.img_91784...OK
Writing 5/161 vendor_483.img_92267...OK
Writing 6/161 vendor_33251.img_125035...OK
Writing 7/161 vendor_66017.img_157801...OK
Writing 8/161 vendor_98787.img_190571...OK
Writing 9/161 vendor_131553.img_223337...OK
Writing 10/161 vendor_164323.img_256107...OK
Writing 11/161 vendor_197089.img_288873...OK
Writing 12/161 vendor_229859.img_321643...OK
Writing 13/161 vendor_262625.img_354409...OK
Writing 14/161 vendor_295395.img_387179...OK
Writing 15/161 vendor_328161.img_419945...OK
Writing 16/161 vendor_425984.img_517768...OK
Writing 17/161 vendor_428312.img_520096...OK
Writing 18/161 vendor_435199.img_526983...OK
Writing 19/161 factory_cache.img_526984...OK
Writing 20/161 system_0.img_962184...OK
Writing 21/161 system_33276.img_995460...OK
Writing 22/161 system_66042.img_1028226...OK
Writing 23/161 system_98812.img_1060996...OK
Writing 24/161 system_131578.img_1093762...OK
Writing 25/161 system_164348.img_1126532...OK
Writing 26/161 system_197114.img_1159298...OK
Writing 27/161 system_229884.img_1192068...OK
Writing 28/161 system_262650.img_1224834...OK
Writing 29/161 system_295420.img_1257604...OK
Writing 30/161 system_328186.img_1290370...OK
Writing 31/161 system_360954.img_1323138...OK
Writing 32/161 system_393722.img_1355906...OK
Writing 33/161 system_426490.img_1388674...OK
Writing 34/161 system_459258.img_1421442...OK
Writing 35/161 system_492026.img_1454210...OK
Writing 36/161 system_524794.img_1486978...OK
Writing 37/161 system_557562.img_1519746...OK
Writing 38/161 system_590330.img_1552514...OK
Writing 39/161 system_623098.img_1585282...OK
Writing 40/161 system_655866.img_1618050...OK
Writing 41/161 system_688634.img_1650818...OK
Writing 42/161 system_721402.img_1683586...OK
Writing 43/161 system_754170.img_1716354...OK
Writing 44/161 system_786938.img_1749122...OK
Writing 45/161 system_819708.img_1781892...OK
Writing 46/161 system_852474.img_1814658...OK
Writing 47/161 system_885244.img_1847428...OK
Writing 48/161 system_918010.img_1880194...OK
Writing 49/161 system_950778.img_1912962...OK
Writing 50/161 system_966501.img_1928685...OK
Writing 51/161 system_982015.img_1944199...OK
Writing 52/161 system_other_0.img_2021000...OK
Writing 53/161 system_other_508.img_2021508...OK
Writing 54/161 system_other_33276.img_2054276...OK
Writing 55/161 system_other_66042.img_2087042...OK
Writing 56/161 system_other_98812.img_2119812...OK
Writing 57/161 system_other_131578.img_2152578...OK
Writing 58/161 system_other_163840.img_2184840...OK
Writing 59/161 system_other_229376.img_2250376...OK
Writing 60/161 system_other_294912.img_2315912...OK
Writing 61/161 system_other_819200.img_2840200...OK
Writing 62/161 system_other_884736.img_2905736...OK
Writing 63/161 system_other_950272.img_2971272...OK
Writing 64/161 system_other_966501.img_2987501...OK
Writing 65/161 system_other_982015.img_3003015...OK
Writing 66/161 product_0.img_3079816...OK
Writing 67/161 product_508.img_3080324...OK
Writing 68/161 product_33276.img_3113092...OK
Writing 69/161 product_66042.img_3145858...OK
Writing 70/161 product_98812.img_3178628...OK
Writing 71/161 product_131578.img_3211394...OK
Writing 72/161 product_164348.img_3244164...OK
Writing 73/161 product_197114.img_3276930...OK
Writing 74/161 product_229884.img_3309700...OK
Writing 75/161 product_262650.img_3342466...OK
Writing 76/161 product_295420.img_3375236...OK
Writing 77/161 product_328186.img_3408002...OK
Writing 78/161 product_360954.img_3440770...OK
Writing 79/161 product_393722.img_3473538...OK
Writing 80/161 product_426490.img_3506306...OK
Writing 81/161 product_459258.img_3539074...OK
Writing 82/161 product_492026.img_3571842...OK
Writing 83/161 product_515995.img_3595811...OK
Writing 84/161 product_524287.img_3604103...OK
Writing 85/161 OP_EEO_GB.img_4128392...OK
Writing 86/161 OP_EEO_GB.img_4193928...OK
Writing 87/161 OP_EEO_GB.img_4259464...OK
Writing 88/161 userdata_0.img_5439240...OK
Writing 89/161 userdata_516.img_5439756...OK
Writing 90/161 userdata_32768.img_5472008...OK
Writing 91/161 userdata_98304.img_5537544...OK
Writing 92/161 userdata_163840.img_5603080...OK
Writing 93/161 userdata_229376.img_5668616...OK
Writing 94/161 userdata_262144.img_5701384...OK
Writing 95/161 userdata_262658.img_5701898...OK
Writing 96/161 userdata_294912.img_5734152...OK
Writing 97/161 userdata_491520.img_5930760...OK
Writing 98/161 gpt_backup0.bin_7103995...OK
Writing 99/161 gpt_main1.bin_0...OK
Writing 100/161 xbl.elf_6...OK
Writing 101/161 xbl_config.elf_902...OK
Writing 102/161 gpt_backup1.bin_2043...OK
Writing 103/161 gpt_main2.bin_0...OK
Writing 104/161 xbl.elf_6...OK
Writing 105/161 xbl_config.elf_902...OK
Writing 106/161 gpt_backup2.bin_2043...OK
Writing 107/161 gpt_main3.bin_0...OK
Writing 108/161 mdmddr.mbn_320...OK
Writing 109/161 gpt_backup3.bin_2043...OK
Writing 110/161 gpt_main4.bin_0...OK
Writing 111/161 aop.mbn_6...OK
Writing 112/161 tz.mbn_134...OK
Writing 113/161 hyp.mbn_1158...OK
Writing 114/161 NON-HLOS.bin_1290...OK
Writing 115/161 abl.elf_101642...OK
Writing 116/161 dspso.bin_101898...OK
Writing 117/161 km4.mbn_118282...OK
Writing 118/161 akmu.mbn_118410...OK
Writing 119/161 boot.img_118538...OK
Writing 120/161 cmnlib.mbn_143114...OK
Writing 121/161 cmnlib64.mbn_143242...OK
Writing 122/161 devcfg.mbn_143370...OK
Writing 123/161 qupv3fw.elf_143402...OK
Writing 124/161 laf.img_143422...OK
Writing 125/161 vbmeta_EEO_GB.img_155710...OK
Writing 126/161 dtbo.img_155726...OK
Writing 127/161 uefi_sec.mbn_161870...OK
Writing 128/161 imagefv.elf_162382...OK
Writing 129/161 raw_resources.img_162894...OK
Writing 130/161 imeiprot.mbn_208462...OK
Writing 131/161 aop.mbn_208590...OK
Writing 132/161 tz.mbn_208718...OK
Writing 133/161 hyp.mbn_209742...OK
Writing 134/161 NON-HLOS.bin_209874...OK
Writing 135/161 abl.elf_310226...OK
Writing 136/161 dspso.bin_310482...OK
Writing 137/161 km4.mbn_326866...OK
Writing 138/161 akmu.mbn_326994...OK
Writing 139/161 boot.img_327122...OK
Writing 140/161 cmnlib.mbn_351698...OK
Writing 141/161 cmnlib64.mbn_351826...OK
Writing 142/161 devcfg.mbn_351954...OK
Writing 143/161 qupv3fw.elf_351986...OK
Writing 144/161 laf.img_352006...OK
Writing 145/161 vbmeta_EEO_GB.img_364294...OK
Writing 146/161 dtbo.img_364310...OK
Writing 147/161 uefi_sec.mbn_370454...OK
Writing 148/161 imagefv.elf_370966...OK
Writing 149/161 raw_resources.img_371478...OK
Writing 150/161 imeiprot.mbn_417046...OK
Writing 151/161 sec.elf_417174...OK
Writing 152/161 apdp.mbn_417438...OK
Writing 153/161 msadp.mbn_417502...OK
Writing 154/161 logfs_ufs_8mb.bin_428227...OK
Writing 155/161 storsec.mbn_447171...OK
Writing 156/161 multi_image.mbn_447203...OK
Writing 157/161 gpt_backup4.bin_453115...OK
Writing 158/161 gpt_main5.bin_0...OK
Writing 159/161 gpt_backup5.bin_3067...OK
Writing 160/161 gpt_main6.bin_0...Skipped!
Writing 161/161 gpt_backup6.bin_1019...Skipped!
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
Writing firmware done!
imei readed but on the phone says it was null and baseband was unknown
i get curious why the 2 file here is skipped?
Old 11-25-2022, 07:58   #10 (permalink)
Member: 1146942
Sonork: 100.1587278
Your mistake is that you flashed the phone from V40 immediately to V20 and because of this the phone is now in this state. We told you to flash on V30 and not on V20 as you did.
Old 11-25-2022, 12:27   #11 (permalink)
Member: 179142
Thanks Meter: 42
ok Thank you very much.
Because your support is the best, very fast response in skype.
Please be very careful handling this phone to my gsmhosting friends.
Old 11-25-2022, 12:27   #12 (permalink)
Member: 179142
Thanks Meter: 42
sorry double post.
My network connection is bad
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.23893 seconds with 7 queries
