GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Octopus LG/Octoplus LG (https://forum.gsmhosting.com/vbb/f799/)
-   -   LG X230Ds flash error [Solved] (https://forum.gsmhosting.com/vbb/f799/lg-x230ds-flash-error-solved-2368818/)
Burini 03-25-2018 05:22
LG X230Ds..Flash error
Log
Welcome to Octoplus/Octopus Box LG Software version 2.8.0
Checking data...OK
Platform: LG MTK
Selected port: COM6
Selected baudrate: 115200
Selected model: X230DS
Selected USB connection type
Press and hold "Vol-" and connect cable.OK
Phone found.
CPU name: MT6737M
CPU revision: 8A00.CB00.0000.0000
Prepairing loader...OK
Sending loader...OK
Synchronizing with loader...
Detecting flash chip...OK
Detecting EMMC flash chip...OK
Reading info...OK
Reading partitions...Failed!
Error code: PQLNVCFREW
Opening "X230DS_V10A_VIVO.oct"...
Writing Firmware...
Performed by 2.8.0 Software version.
NST-Thina 03-25-2018 05:35
Service the motherboard and heat the board and the CPU IC then Flash again 100% its worked
Octopus box 03-25-2018 12:47
@ Burini
Hello.
What is the state/problem of your phone exactly? Why You have decided to write firmware?
Such error means, that it is not possible to read our data from the phone's flash chip, usually this means, that device has HW problem.
Burini 03-25-2018 22:02
Originally Posted by Octopus box (Post 13041390)
@ Burini
Hello.
the phone has no hardware problems, I made a copy of the system, it was 100% working, after the copy with LG module he did not call anymore and no longer writes the system, the copy was done via USB cable with LG module octopus activated on Medusa
Octopus box 03-26-2018 05:37
What do You mean under "I made a copy of the system"? Have You read Full flash or what? Reading Full flash from the phone doesn't touch/change any data in the device, so reading of Full flash can't be the cause of this problem. Anyway, post here Full software log with all of performed operations with the device, we will check.
Burini 03-26-2018 17:03
already recovered the device, through the flashtool and imei rewritten with medusa pro LG activated
This is my cell phone 100%.
Thanks for your response
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.09153 seconds with 6 queries
