Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Major Poster ![]() ![]() Join Date: Oct 2015 Location: Brasil
Member: 2476261 Status: Offline Sonork: 1674003 Thanks Meter: 9 | ![]() Log Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM6 Selected baudrate: 115200 Selected model: X230DS Selected USB connection type Press and hold "Vol-" and connect cable.OK Phone found. CPU name: MT6737M CPU revision: 8A00.CB00.0000.0000 Prepairing loader...OK Sending loader...OK Synchronizing with loader... Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Reading partitions...Failed! Error code: PQLNVCFREW Opening "X230DS_V10A_VIVO.oct"... Writing Firmware... Reading partitions...Failed! Error code: PQLNVCFREW Performed by 2.8.0 Software version. Last edited by Octopus box; 03-26-2018 at 18:51. |
![]() | #2 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2015 Location: @kilinochchi, Sri Lanka
Member: 2372779 Status: Offline Sonork: 100.1680276 Thanks Meter: 33 ![]() | Service the motherboard and heat the board and the CPU IC then Flash again 100% its worked |
The Following User Says Thank You to NST-Thina For This Useful Post: |
![]() | #3 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Oct 2009
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,026 | @ Burini Hello. What is the state/problem of your phone exactly? Why You have decided to write firmware? Such error means, that it is not possible to read our data from the phone's flash chip, usually this means, that device has HW problem. |
![]() | #4 (permalink) |
Member: 2476261 Status: Offline Sonork: 1674003 Thanks Meter: 9 | the phone has no hardware problems, I made a copy of the system, it was 100% working, after the copy with LG module he did not call anymore and no longer writes the system, the copy was done via USB cable with LG module octopus activated on Medusa |
![]() | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,026 | What do You mean under "I made a copy of the system"? Have You read Full flash or what? Reading Full flash from the phone doesn't touch/change any data in the device, so reading of Full flash can't be the cause of this problem. Anyway, post here Full software log with all of performed operations with the device, we will check. |
![]() | #6 (permalink) | |
Member: 2476261 Status: Offline Sonork: 1674003 Thanks Meter: 9 | ![]() Quote:
This is my cell phone 100%. Thanks for your response | |
The Following User Says Thank You to Burini For This Useful Post: |
