05-29-2020, 11:40 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | LG G3 (VS985) IMEI successfully fixed Octopus Box LG Code: Welcome to Octoplus/Octopus Box LG Software version 3.0.2 Card S/N : 0000000E47 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM64 Selected model: VS985 Reading info... Model ID: VS985 4G IMEI: ************ Android version: 6.0 Battery level: 10% Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.0.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM64 Selected model: VS985 Reading info... Model ID: VS985 4G IMEI: ************* Android version: 6.0 Battery level: 15% Trying to enable Diagnostics ports... Found model VS9854CA: at port COM64 Fixing IMEI... New IMEI: -------------------- Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "VS985_********_29-05-2020_15-15- 45.qcn" Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method...OK Reading security area...OK Backup saved to "VS985_********_29-05-2020_15-30- 31.SEC" Switching to Normal mode... Found model VS9854CA: at port COM64 Writing security area...OK Rebooting phone... Found model VS9854CA: at port COM64 IMEI successfully fixed! Rebooting phone... Performed by 3.0.2 Software version. |
The Following User Says Thank You to naveedullah0044 For This Useful Post: |
