Hello, the unlock process using SDCard because of android 8.1 goes smooth but after it starts with a inserted simcard the phone says it has being locked permanently and it says Network locked, insert the SIM...
Work ID: 000000000106292F
Checking data...OK
Platform: LG Qualcomm
Selected port: COM118
Selected model: LMX210CM
Reading info...
Model ID: LM-X210CM
IMEI: 354376-09-989273-5
Android version: 8.1.0
Battery level: 41%
Mode: Normal
Firmware compiled date: Sep 10 2018
Firmware compiled time: 09:00:00
Firmware released date: Mar 29 2019
Firmware released time: 16:46:44
SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK-1
Bluetooth address: 38:30:F9:EE:16D
Wi-Fi MAC address: 38:30:F9:94:53:3D
SPC: 000000
Please, select Unlock Method!
Selected Unlock via SD Card
(with Unlock APK)
Unlock operation for LMX210CM will delete all user data on the
phone (contacts, pictures and others)!
Do You want to continue?
Connecting to server 0...OK
Octopus smart card is present.
Checking smart card...OK
Username: zedd7113
Authorizing...OK
Checking balance...OK
Checking operation...OK
Sending device information...OK
Get credits, needed for current operation...OK
Your balance: 265 credits.
To perform "Unlock" operation you need to have 100 credits.
Prepairing loader...
Step 1...
Step 2...
Step 3...
Copying on SD Card...
Switching to Download mode...OK
Initializing flash...OK
Platform: msm8937
SW version: LMX210CMAT-00-V20f-CRK-US-MAR-29-2019-ARB03
+0
LAF Version: 1.1
Product ID: CY12S190112001543
Target operator: CRK
Hardware: rev_10
Reading partitions...
Checking data...
Connecting to phone...OK
Sending loader...
Executing loader...
Initializing device...
Checking data...
Calculating. Please Wait...
Unlocking...
Phone successfully unlocked!
Rebooting phone...
Warning: If your device ask for Unlock Code, after operation was
completed, then You can perform Unlock operation via wipe
security!
Performed by 3.1.1.03 Software version.
I tried unlocking by Wiping Security and it fails while attempting to restore QCN:
Work ID: 0000000001062F91
Checking data...OK
Reading info...
Model ID: LM-X210CM
Battery level: 32%
Trying to enable Diagnostics ports...
Found model LMX210CM: ÿh at port COM118
Reading info...
Model ID: LM-X210CM
Battery level: 32%
Mode: Normal
SPC: 000000
Selected Unlock via wipe security
(with Unlock codes)
Unlocking...
Initializing ADB...OK
Waiting for phone...OK
Username: zedd7113
Authorizing...OK
Your balance: 165 credits.
To perform "Unlock" operation you need to have 0 credits.
Write security backup function doesn't work for this device with
latest firmware versions. If you'll encounter any problem during
Unlock operation - you won't be able to restore the phone to it's
initial state, so proceed at your own risk.
Continue?
Reading QCN...
Send SPC...OK
Reading Mobile Property...OK
Reading Feature Mask...OK
Reading Roaming List 0...OK
Reading NV_Numbered Items...OK
Reading NV_Numbered SIM1 Items...OK
Reading NV_Numbered SIM2 Items...OK
Reading NV Items...OK
Reading EFS...OK
Reading Provisioning Items...OK
Reading QCN done!
Backup saved to "LMX210CM_354376099892735_20-05-2021_
13-59-33.qcn"
Reading partitions...OK
Reading security area...OK
14-09-19.SEC"
Writing security area...OK
Switching to Normal mode...
Please perform the following steps:
1. Disconnect cable
2. Put phone into Normal mode manually
3. Connect USB cable to then phone
4. Press "Ok" button
Found model LMX210CM* ÿh at port COM118
Send SPC...OK
Writing QCN...
Writing NV_Numbered Items...Failed!
What could be the problem??
Is there any solution to this?
Are the credits consumed by this job lost?
Thank you.
