05-04-2022, 09:17 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: whole world
Member: 791227 Status: Offline Thanks Meter: 10 | LM-X210CM Unlock Question [Solved] my 100 Welcome to Octoplus/Octopus Box LG Software version 3.1.8.01 Card S/N : 00000234B4 -------------------------------------------------------------------------------- Work ID: 0000000001B5780C Checking data...OK Platform: LG Qualcomm Selected port: COM23 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376******** Android version: 8.1.0 Battery level: 100% Mode: Normal Firmware compiled date: Oct 24 2019 Firmware compiled time: 07:00:00 Firmware released date: Jul 29 2020 Firmware released time: 18:46:34 SW Version: MPSS.JO.3.0.c12-00036-8937_GENNS_PACK- 1.220702.1.229846.1 IMEI: 354376-09-***** Bluetooth address: 00:57:C1:89:65:16 Wi-Fi MAC address: 38:30:F9:32:98:F2 SPC: 000000 Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Reset Security operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210CM_354376*******_04-05-2022_09-06- 19.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...Failed! LAF Error: 80000119. Reading security area... Please, insert / reinsert SD Card into Phone. Then press "OK" button. Reading partitions... Reading security area... Connecting to phone...OK Initializing flash...OK Checking data... Connecting to phone...OK Initializing flash...OK Switching to Normal mode... Connecting to phone... Can't found Micro SD cards Please, connect Micro SD card to PC, then press "OK" button! Can't found Micro SD cards Please, connect Micro SD card to PC, then press "OK" button! Connecting to phone... Backup saved to "LMX210CM_35437609*****_04-05-2022_09-12- 29.SEC" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Resetting secutiy area...OK Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect USB cable to then phone 4. Press "Ok" button Found model LMX210CM* ÿh at port COM23 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Performed by 3.1.8.01 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001B5780C Checking data...OK Platform: LG Qualcomm Selected port: COM23 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-******* Android version: 8.1.0 Battery level: 100% Mode: Normal Firmware compiled date: Oct 24 2019 Firmware compiled time: 07:00:00 Firmware released date: Jul 29 2020 Firmware released time: 18:46:34 SW Version: MPSS.JO.3.0.c12-00036-8937_GENNS_PACK- 1.220702.1.229846.1 IMEI: 354376-09-***** Bluetooth address: 00:57:C1:89:65:16 Wi-Fi MAC address: 38:30:F9:32:98:F2 SPC: 000000 Please, select Unlock Method! Selected Unlock via SD Card (with Unlock APK) Unlock operation for LMX210CM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: slycelltronix Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 37 credits. To perform "Unlock" operation you need to have 0 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Switching to Download mode...OK Initializing flash...OK Platform: msm8937 SW version: LMX210CMAT-00-V20o-CRK-US-JUL-29-2020-ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: CY12S18102400*** IMEI: 354376-09-****** Target operator: CRK Hardware: rev_10 Please, insert / reinsert SD Card into Phone. Then press "OK" button. Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone...OK Initializing flash...OK Prepairing loader... Executing loader... Connecting to phone...OK Initializing flash...OK Initializing device... Checking data... Calculating. Please Wait... Unlocking... Phone successfully unlocked! Rebooting phone... Warning: If your device ask for Unlock Code, after operation was completed, then You can perform Unlock operation via wipe security! Performed by 3.1.8.01 Software version. credits gone but phone still locked even after security reset; |
05-04-2022, 09:41 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello. As can we see from the software log, your phone was successfully unlocked. Please insert SIM card, type *#06# and make a video with phone's screen, where we can see, that device is locked, then send us link with video we will check. |
The Following User Says Thank You to Octopus support For This Useful Post: |
05-05-2022, 10:06 | #7 (permalink) |
Member: 791227 Status: Offline Thanks Meter: 10 | before it was asking for network unlock code after unlock it was asking for unlock code 7 attempts remain. then after reset security: this phone is permanently locked and can not be unlocked |
05-05-2022, 12:51 | #10 (permalink) | ||||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We recommended to read atentitive software manual before do any operations. Quote:
05-06-2022, 10:41 | #11 (permalink) |
Member: 791227 Status: Offline Thanks Meter: 10 | i tried that before this procedure but it was giving error but now phone is unlocked ,thank you octopus team. |
The Following User Says Thank You to victorsky For This Useful Post: |
