08-22-2020, 21:42 | #1 (permalink) |
Junior Member Join Date: May 2014 Location: Nicaragua
Member: 2185284 Status: Offline Thanks Meter: 4 | LM-X420EMW Suck logo after unlock [Solved] Welcome to Octoplus/Octopus Box LG Software version 3.0.2.02 -------------------------------------------------------------------------------- Connecting to server ...OK Username: digileo280 Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: X420EMW Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM87 Mode: Emergency Initializing flash...OK Model ID: LM-X420EMW Platform: mt6765 Android version: 8.1.0 SW version: LMX420EMWAT-64-V10f-EEA-XX-SEP-19-2019+0 LAF Version: 1.1 Product ID: 96HGAD29BEEN02I49 IMEI: 353615-10-353731-0 Target operator: LAO Hardware: rev_11 Battery level: 78% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 353615-10-353731-0 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: digileo280 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area... Reconnecting phone... Phone found at port COM87 Mode: Emergency Initializing flash...OK Prepairing for change protect status... Reconnecting phone... Phone found at port COM87 Mode: Emergency Initializing flash...OK Removing write protection...OK Reconnecting phone... Phone found at port COM87 Mode: Emergency Initializing flash...OK Reading partitions...OK Erasing part 1...OK Reconnecting phone... Phone found at port COM87 Mode: Emergency Initializing flash...OK Prepairing for change protect status... Reconnecting phone... Phone found at port COM87 Mode: Emergency Initializing flash...OK Restore write protection...OK Reconnecting phone... Phone found at port COM87 Mode: Emergency Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Reconnecting phone... Phone found at port COM87 Mode: Emergency Initializing flash...OK Restore write protection...OK Reconnecting phone... Phone found at port COM87 Mode: Emergency Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Reconnecting phone... Phone found at port COM87 Mode: Emergency Initializing flash...OK Restore write protection...OK Reconnecting phone... Phone found at port COM87 Mode: Emergency Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.2.02 Software version. |
08-24-2020, 09:52 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Online Thanks Meter: 2,141 | Hello. We added you one more attempt. Please download and install latest test software version 3.0.2.04 from the Support Area (LG/TEST SOFTWARE/), put the phone into download mode then repeat the operation once again. Quote:
The Following User Says Thank You to Octopus support For This Useful Post: |
08-24-2020, 23:21 | #3 (permalink) |
Member: 2185284 Status: Offline Thanks Meter: 4 | thanks full unlock Welcome to Octoplus/Octopus Box LG Software version 3.0.2.04 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: X420EMW Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM87 Mode: Emergency Initializing flash...OK Model ID: LM-X420EMW Platform: mt6765 Android version: 8.1.0 SW version: LMX420EMWAT-64-V10f-EEA-XX-SEP-19-2019+0 LAF Version: 1.1 Product ID: 96HGAD29BEEN02I49 IMEI: 353615-10-353731-0 Target operator: LAO Hardware: rev_11 Battery level: 47% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 353615-10-353731-0 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: SIU2eaPoHX Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area... Initializing flash...OK Writing security area...OK Initializing flash...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.2.04 Software version. |
