08-23-2021, 21:35 | #1 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Puerto Rico
Member: 2549748 Status: Offline Thanks Meter: 212 | LM-X420MM Reset FRP [Answered] I initially with **** credits but now *** credits Code: Welcome to Octoplus/Octopus Box LG Software version 3.1.4 Card S/N : 00000031E1 -------------------------------------------------------------------------------- Connecting to server 0...OK Username: kingunlockpr Authorizing...OK Checking balance...OK Your balance: 907 credits. -------------------------------------------------------------------------------- Work ID: 00000000016FBC88 Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: X420MM Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X420MM IMEI: 358940-10-050641-4 Android version: 9 Battery level: 100% Mode: Emergency Initializing flash...OK Platform: msm8953 SW version: LMX420MMAT-02-V10o-310-160-FEB-05-2020-ARB00+0 Android version: 9 LAF Version: 1.1 Product ID: HB28S191226004976 IMEI: 358940-10-050641-4 Target operator: LAO Hardware: rev_10 Reading partitions...OK Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: kingunlockpr Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 907 credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to "X420MM_358940100506414_23-08-2021_15-12-27.oct" Reading partitions...OK Prepairing for change protect status... Reconnecting phone...OK Initializing flash...OK Removing write protection... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Reading partitions...OK Resetting FRP Lock... Reading partitions...OK Restore write protection... Reconnecting phone...OK Initializing flash...OK Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Reading partitions...OK Resetting FRP lock successfully completed! Performed by 3.1.4 Software version. Last edited by Octopus box; 08-24-2021 at 06:16. |
