06-01-2021, 14:00 | #1 (permalink) |
Freak Poster Join Date: Dec 2019 Location: Pak
Member: 2942140 Status: Offline Thanks Meter: 91 | LMQ630 Rebuild ERROR [Answered] i have LMQ630NAT want repair imei octopus need 100 credit this is Good but Stile not Rebuild and 100 credit loss please need your help and solve my problem here is logs Code: Selected USB connection type Work ID: 00000000010D3807 Checking data...OK Platform: LG MTK Selected port: COM397 Selected baudrate: 0 Selected model: Q630N Connecting to phone... Phone found at port COM397 Mode: Emergency Initializing flash...OK Model ID: LM-Q630N Platform: mt6765 Code name: mdh40lm Android version: 10 SW version: LMQ630NAT-00-V20e-KT-KR-FEB-24-2021+0 LAF Version: 1.1 Product ID: LCL2S200606307417 IMEI: 354179-11-138094-9 Target operator: LAO Hardware: rev_10 Battery level: 40% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354179-11-138094-9 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: 7SnehJuWFq Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM397 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM238 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 59640 Mb eMMC flash chip: .15010044.48364441.4204E440.6AFA47F7 eMMC flash chip: Unknown: DH6DAB Internal RAM size: 224 Kb External RAM size: 4096 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "Q630N_354179111380949_27-05-2021_16-52- 39.SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... To complete the operation, Please perform the following steps: 1. Please disconnect the USB cable, Power phone ON and connect USB cable again. 2. Select "File transfer" connection mode. 3. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 4. Press "Ok" button. New IMEI A: 354741-10-501379-2 Finalizing... Performed by 3.1.2 Software version. |
The Following User Says Thank You to GSM-SURGEON For This Useful Post: |
06-01-2021, 14:15 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. We added you one more attempt, please, try to repeat Repair IMEI operation once again and post here result. |
06-01-2021, 14:38 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | To complete the operation, Please perform the following steps: 1. Please disconnect the USB cable, Power phone ON and connect USB cable again. 2. Select "File transfer" connection mode. 3. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 4. Press "Ok" button. Last edited by Octopus support; 06-01-2021 at 15:09. |
