03-15-2022, 21:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Cuba-Holguin
Member: 256260 Status: Offline Thanks Meter: 726 | LM-G710TM Unlock Question [Answered] Connecting to server 0...OK Username: mT4eFMITHd Authorizing...OK Checking balance...OK Your balance: 150 credits. ------------------------------------------------------------------------ -------- Work ID: 00000000018396D9 Checking data...OK Platform: LG Qualcomm Selected port: COM499 Selected model: G710TM Reading info... Model ID: LM-G710TM IMEI: 358159-09-015126-9 Android version: 9 Battery level: 98% Trying to enable Diagnostics ports... Found model LM-G710TM at port COM499 Reading info... Model ID: LM-G710TM IMEI: 358159-09-015126-9 Android version: 9 Battery level: 98% Trying to enable Diagnostics ports... Found model LM-G710TM at port COM499 Reading info... Model ID: LM-G710TM IMEI: 358159-09-015126-9 Android version: 9 Battery level: 98% Mode: Normal Firmware compiled date: May 07 2019 Firmware compiled time: 07:00:00 Firmware released date: May 23 2019 Firmware released time: 15:15:16 SW Version: MPSS.AT.4.0.c2.9-00061-SDM845 _GEN_PACK-1.196773.1.198357.15 IMEI: 358159-09-015126-9 SPC: 000000 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: mT4eFMITHd Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 150 credits. To perform "Unlock" operation you need to have 100 credits. Switching to Download mode...OK Initializing flash...OK Platform: sdm845 SW version: LMG710TMAT-01-V20c-310-260-MAY-23- 2019-ARB00+0 Android version: 9 LAF Version: 1.1 Product ID: PT01S180517000996 IMEI: 358159-09-015126-9 Target operator: LAO Hardware: rev_10 Reading partitions...OK Checking operation... Reconnecting phone...OK Initializing flash...OK Patching... Step 1... Reconnecting phone...OK Initializing flash...OK Reading 0... Reconnecting phone...OK Initializing flash...OK Reading 1... Writing 1... Reconnecting phone...OK Initializing flash...OK Step 2... Reconnecting phone...OK Initializing flash...OK Reading 0... Reconnecting phone...OK Initializing flash...OK Reading 1... Writing 1... Reconnecting phone...OK Initializing flash...OK Switching to Normal mode... Found model LMG710TM: ÿÅ0 at port COM499 Prepairing for change protect status...OK Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Platform: sdm845 SW version: LMG710TMAT-01-V20c-310-260-MAY-23- 2019-ARB00+0 Android version: 9 LAF Version: 1.1 Product ID: PT01S180517000996 IMEI: 358159-09-015126-9 Target operator: LAO Hardware: rev_10 Reading partitions...OK Writing security area... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Initializing flash...OKOK Switching to Normal mode... Found model LMG710TM* ÿÅ0 at port COM499 Error code: Z1AL3CAS2Q Performed by 3.1.7 Software version. please refund |
