11-27-2020, 18:23 | #1 (permalink) |
Junior Member Join Date: Jul 2020 Location: spain
Member: 2963183 Status: Offline Thanks Meter: 1 | LMX210APM Reset FRP not done [Solved] i try to do frp show done but still asking for google account and i write message to claim email 2 days ago no reply with all full inform thanks LOLITA20 i try it yesterday and today is the same still asking for google account thanks INFO : 24/11/2020 15:56:31 > Welcome to Octoplus FRP Tool v.1.9.6.0 INFO : 24/11/2020 15:56:31 INFO : 24/11/2020 15:57:42 > ----------------------------------------------------------------------------------- INFO : 24/11/2020 15:57:42 > Connecting to server... INFO : 24/11/2020 15:57:43 > Username: LOLITA20 INFO : 24/11/2020 15:57:43 > Authorizing... INFO : 24/11/2020 15:57:44 > Checking balance... WARN : 24/11/2020 15:57:45 > Your balance: 200 credits. INFO : 24/11/2020 15:57:45 > Performed by 1.9.6.0 Software version. INFO : 24/11/2020 15:57:45 > INFO : 24/11/2020 15:57:59 > Work ID: 2698242 INFO : 24/11/2020 15:57:59 > Platform: LG INFO : 24/11/2020 15:57:59 > Selected model: LMX210APM WARN : 24/11/2020 15:58:00 > Put the phone into Download Mode: WARN : 24/11/2020 15:58:00 > 1. Power phone OFF; WARN : 24/11/2020 15:58:00 > 2. Press and hold "Vol+" button and connect USB cable. INFO : 24/11/2020 15:58:00 > Searching for a phone. Please wait... INFO : 24/11/2020 15:58:00 > Found phone on COM20 INFO : 24/11/2020 15:58:00 > Reading info... INFO : 24/11/2020 15:58:00 > Detected phone model: LM-X210APM INFO : 24/11/2020 15:58:00 > Mode: Normal INFO : 24/11/2020 15:58:00 > Android version: 7.1.2 INFO : 24/11/2020 15:58:00 > Factory SW X210APM10m INFO : 24/11/2020 15:58:00 > Trying to enable Diagnostic Port... INFO : 24/11/2020 15:58:00 > Found phone on COM20 INFO : 24/11/2020 15:58:00 > Firmware released date: Jan 29 2019 INFO : 24/11/2020 15:58:00 > Firmware released time: 20:52:45 INFO : 24/11/2020 15:58:00 > Firmware compiled date: Jun 20 2018 INFO : 24/11/2020 15:58:00 > Firmware compiled time: 06:00:00 INFO : 24/11/2020 15:58:00 > Switching to Download Mode... INFO : 24/11/2020 15:58:13 > Found phone on COM20 INFO : 24/11/2020 15:58:14 > Initializing.. INFO : 24/11/2020 15:58:17 > SW version: LMX210APMAT-01-V10m-310-410-JAN-29-2019-ARB01+0 INFO : 24/11/2020 15:58:17 > Android version: 7.1.2 INFO : 24/11/2020 15:58:17 > Platform: msm8937 WARN : 24/11/2020 15:58:18 > Reset FRP operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? INFO : 24/11/2020 15:58:23 > Reading partition... INFO : 24/11/2020 15:58:24 > Detecting writing method... INFO : 24/11/2020 15:58:24 > Trying to repeat.. INFO : 24/11/2020 15:58:24 > Trying third method... INFO : 24/11/2020 15:58:25 > Searching for signatures... INFO : 24/11/2020 15:58:25 > Connecting to server... INFO : 24/11/2020 15:58:28 > Checking smart card... INFO : 24/11/2020 15:58:34 > Username: LOLITA20 INFO : 24/11/2020 15:58:34 > Authorizing... INFO : 24/11/2020 15:58:37 > Checking balance... WARN : 24/11/2020 15:58:37 > Your balance: 200 credits. INFO : 24/11/2020 15:58:37 > Checking operation... INFO : 24/11/2020 15:58:41 > Operation successfully checked. INFO : 24/11/2020 15:58:41 > Sending device information... INFO : 24/11/2020 15:58:42 > Get credits, needed for current operation... WARN : 24/11/2020 15:58:42 > Your balance: 200 credits. Need: 100 credits. INFO : 24/11/2020 15:58:50 > Backup saved as LG_LMX210APM_24-11-2020_15-58-50.dump file INFO : 24/11/2020 15:58:51 > Reading partition... INFO : 24/11/2020 15:58:51 > Prepairing for change protect status... INFO : 24/11/2020 15:59:07 > Reconnecting... WARN : 24/11/2020 16:01:00 > Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! INFO : 24/11/2020 16:02:48 > Initializing.. INFO : 24/11/2020 16:02:51 > Removing write protection... INFO : 24/11/2020 16:03:08 > Reconnecting... WARN : 24/11/2020 16:05:00 > Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! INFO : 24/11/2020 16:05:51 > Initializing.. INFO : 24/11/2020 16:05:53 > Reading partition... INFO : 24/11/2020 16:05:54 > Resetting FRP lock.. INFO : 24/11/2020 16:06:16 > Reconnecting... WARN : 24/11/2020 16:06:16 > Please, perform the following steps: 1. Disconnect cable and power phone ON. 2. Complete all startup settings. 3. Power phone OFF and put it to Download mode. 4. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions! INFO : 24/11/2020 16:08:00 > Initializing.. INFO : 24/11/2020 16:08:03 > Reading partition... INFO : 24/11/2020 16:08:03 > Prepairing for change protect status... INFO : 24/11/2020 16:08:14 > Reconnecting... WARN : 24/11/2020 16:10:06 > Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! INFO : 24/11/2020 16:11:00 > Initializing.. INFO : 24/11/2020 16:11:03 > Restore write protection... INFO : 24/11/2020 16:11:20 > Reconnecting... WARN : 24/11/2020 16:13:12 > Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! INFO : 24/11/2020 16:15:30 > Initializing.. INFO : 24/11/2020 16:15:33 > Reading partition... WARN : 24/11/2020 16:15:34 > FRP lock is successfully reseted! INFO : 24/11/2020 16:15:34 > Performed by 1.9.6.0 Software version. INFO : 24/11/2020 16:15:34 > INFO : 25/11/2020 11:37:45 > Welcome to Octoplus FRP Tool v.1.9.7.0 INFO : 25/11/2020 11:37:45 INFO : 25/11/2020 11:39:01 > ----------------------------------------------------------------------------------- INFO : 25/11/2020 11:39:01 > Connecting to server... INFO : 25/11/2020 11:39:02 > Username: LOLITA20 INFO : 25/11/2020 11:39:02 > Authorizing... INFO : 25/11/2020 11:39:04 > Checking balance... WARN : 25/11/2020 11:39:05 > Your balance: 100 credits. INFO : 25/11/2020 11:39:05 > Performed by 1.9.7.0 Software version. INFO : 25/11/2020 11:39:05 > INFO : 25/11/2020 11:39:27 > Work ID: 00000000002A2509 INFO : 25/11/2020 11:39:27 > Platform: LG INFO : 25/11/2020 11:39:27 > Selected model: LMX210APM WARN : 25/11/2020 11:39:27 > Put the phone into Download Mode: WARN : 25/11/2020 11:39:27 > 1. Power phone OFF; WARN : 25/11/2020 11:39:27 > 2. Press and hold "Vol+" button and connect USB cable. INFO : 25/11/2020 11:39:27 > Searching for a phone. Please wait... INFO : 25/11/2020 11:39:28 > Found phone on COM22 INFO : 25/11/2020 11:39:28 > Reading info... INFO : 25/11/2020 11:39:28 > Detected phone model: LM-X210APM INFO : 25/11/2020 11:39:28 > Mode: Emergency INFO : 25/11/2020 11:39:28 > Initializing.. INFO : 25/11/2020 11:39:31 > SW version: LMX210APMAT-01-V10m-310-410-JAN-29-2019-ARB01+0 INFO : 25/11/2020 11:39:31 > Android version: 7.1.2 INFO : 25/11/2020 11:39:31 > Platform: msm8937 WARN : 25/11/2020 11:39:31 > Reset FRP operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? INFO : 25/11/2020 11:39:35 > Reading partition... INFO : 25/11/2020 11:39:35 > Detecting writing method... INFO : 25/11/2020 11:39:36 > Trying to repeat.. INFO : 25/11/2020 11:39:36 > Trying third method... INFO : 25/11/2020 11:39:37 > Searching for signatures... INFO : 25/11/2020 11:39:37 > Connecting to server... INFO : 25/11/2020 11:39:38 > Checking smart card... INFO : 25/11/2020 11:39:53 > Username: LOLITA20 INFO : 25/11/2020 11:39:53 > Authorizing... INFO : 25/11/2020 11:39:55 > Checking balance... WARN : 25/11/2020 11:39:56 > Your balance: 100 credits. INFO : 25/11/2020 11:39:56 > Checking operation... INFO : 25/11/2020 11:39:59 > Operation successfully checked. INFO : 25/11/2020 11:39:59 > Sending device information... INFO : 25/11/2020 11:40:00 > Get credits, needed for current operation... WARN : 25/11/2020 11:40:00 > Your balance: 100 credits. Need: 100 credits. INFO : 25/11/2020 11:40:07 > Backup saved as LG_LMX210APM_25-11-2020_11-40-07.dump file INFO : 25/11/2020 11:40:07 > Reading partition... INFO : 25/11/2020 11:40:07 > Prepairing for change protect status... INFO : 25/11/2020 11:40:24 > Reconnecting... WARN : 25/11/2020 11:42:17 > Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! INFO : 25/11/2020 11:43:09 > Initializing.. INFO : 25/11/2020 11:43:13 > Removing write protection... INFO : 25/11/2020 11:43:31 > Reconnecting... WARN : 25/11/2020 11:45:23 > Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! INFO : 25/11/2020 11:46:17 > Initializing.. INFO : 25/11/2020 11:46:20 > Reading partition... INFO : 25/11/2020 11:46:20 > Resetting FRP lock.. INFO : 25/11/2020 11:46:42 > Reconnecting... WARN : 25/11/2020 11:46:43 > Please, perform the following steps: 1. Disconnect cable and power phone ON. 2. Complete all startup settings. 3. Power phone OFF and put it to Download mode. 4. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions! INFO : 25/11/2020 11:47:57 > Initializing.. INFO : 25/11/2020 11:48:00 > Reading partition... INFO : 25/11/2020 11:48:00 > Prepairing for change protect status... INFO : 25/11/2020 11:48:17 > Reconnecting... WARN : 25/11/2020 11:50:10 > Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! INFO : 25/11/2020 11:50:53 > Initializing.. INFO : 25/11/2020 11:50:56 > Restore write protection... INFO : 25/11/2020 11:51:13 > Reconnecting... WARN : 25/11/2020 11:53:05 > Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! INFO : 25/11/2020 11:53:43 > Initializing.. INFO : 25/11/2020 11:53:46 > Reading partition... WARN : 25/11/2020 11:53:47 > FRP lock is successfully reseted! INFO : 25/11/2020 11:53:48 > Performed by 1.9.7.0 Software version. INFO : 25/11/2020 11:53:48 > help me to refund for the 200 credit back thanks |
11-28-2020, 10:26 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | |
11-28-2020, 10:29 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @ lekan2020 We've been already answered to You via claim mail, plesae look attentive |
