01-20-2021, 16:19 | #1 (permalink) |
Insane Poster Join Date: Apr 2016 Location: Ghana
Member: 2559264 Status: Offline Sonork: 100.1673373:mpee47 Thanks Meter: 14 | LMX210APM unlock issue [Solved] Card S/N : 01******5A -------------------------------------------------------------------------------- Selected USB connection type Platform: LG MTK Selected port: COM5 Selected baudrate: 921600 Selected model: X210 Please, power phone OFF and connect cable.OKCanceled! Performed by 3.0.8 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM27 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-323162-2 Android version: 8.1.0 Battery level: 49% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20e-310-410-APR-04-2019- ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VP01S190617003641 IMEI: 355437-10-323162-2 Target operator: ATT Hardware: rev_10 Performed by 3.0.8 Software version. -------------------------------------------------------------------------------- Work ID: 000000000073C19B Checking data...OK Platform: LG Qualcomm Selected port: COM27 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-323162-2 Android version: 8.1.0 Battery level: 49% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20e-310-410-APR-04-2019- ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VP01S190617003641 IMEI: 355437-10-323162-2 Target operator: ATT Hardware: rev_10 Please, select Unlock Method! Selected Unlock via wipe security (with Unlock codes) Unlocking... Switching to Normal mode... Found model LMX210AP: ÿh at port COM28 Initializing ADB...OK Waiting for phone...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: sharkoct20181205ss Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210APM_355437103231622_20-01-2021_ 14-02-57.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "LMX210APM_355437103231622_20-01-2021_ 14-09-30.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect USB cable to then phone 4. Press "Ok" button Found model LMX210AP* ÿh at port COM28 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: sharkoct20181205ss Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OKOK Finalizing...Failed! Error code: KLQWHCKAWF Performed by 3.0.8 Software version. -------------------------------------------------------------------------------- Connecting to server ...OK Username: sharkoct20181205ss Authorizing...OK Checking balance...OK Your balance: 0 credits. |
01-21-2021, 09:13 | #4 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello. Please download and install latest test software version 3.0.8.04 from the Support Area (LG/TEST SOFTWARE/), then do the Unlock operation via SD card method and post here results. Quote:
The Following User Says Thank You to Octopus support For This Useful Post: |
01-21-2021, 12:18 | #5 (permalink) | |
Member: 2559264 Status: Offline Sonork: 100.1673373:mpee47 Thanks Meter: 14 | Quote:
Will it consume additional credit because credit already deducted please? | |
01-21-2021, 14:40 | #8 (permalink) |
Member: 2559264 Status: Offline Sonork: 100.1673373:mpee47 Thanks Meter: 14 | IMEI is has changed to zeros [000000000000] can i still do the unlock process please? info Platform: LG Qualcomm Selected port: COM28 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 000000-00-000000-0 Android version: 8.1.0 Battery level: 100% Mode: Normal Performed by 3.0.8.04 Software version |
01-21-2021, 14:44 | #9 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Please write backup: "LMX210APM_355437103231622_20-01-2021_14-09-30.SEC", then do the Unlock operation via SD card method and post here results. |
01-21-2021, 15:36 | #10 (permalink) | |
Member: 2559264 Status: Offline Sonork: 100.1673373:mpee47 Thanks Meter: 14 | Unlock Successful, and successfully refunded with the first thread posted too. Quote:
Checking data...OK Platform: LG Qualcomm Selected port: COM28 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 000000-00-000000-0 Android version: 8.1.0 Battery level: 100% Mode: Normal Opening "LMX210APM_355437103231622_20-01-2021_14-09-30.SEC"... Writing security area... Copying on SD Card... Writing SP1... Writing SP2... Writing SP3... Switching to Download mode...OK Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-00-V20e-ATT-US-APR-04-2019-ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VP01S190617003641 IMEI: 000000-00-000000-0 Target operator: ATT Hardware: rev_10 Please, insert / reinsert SD Card into Phone. Then press "OK" button. Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Writing SP1... Connecting to phone...OK Initializing flash...OK Writing SP2... Connecting to phone...OK Initializing flash...OK Writing SP3... Connecting to phone...OK Initializing flash...OK Rebooting phone... Performed by 3.0.8.04 Software version. -------------------------------------------------------------------------------- Work ID: 0000000000753E31 Performed by 3.0.8.04 Software version. -------------------------------------------------------------------------------- Work ID: 0000000000753E64 Checking data...OK Platform: LG Qualcomm Selected port: COM28 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-323162-2 Android version: 8.1.0 Battery level: 100% Trying to enable Diagnostics ports... Found model LMX210AP: ÿh at port COM28 Reading info... Model ID: LM-X210APM IMEI: 355437-10-323162-2 Android version: 8.1.0 Battery level: 100% Mode: Normal Firmware compiled date: Sep 10 2018 Firmware compiled time: 09:00:00 Firmware released date: Apr 4 2019 Firmware released time: 10:58:45 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK-1 IMEI: 355437-10-323162-2 Bluetooth address: AC:F6:F7:6B:FC:1E Wi-Fi MAC address: AC:F6:F7:E1:C5:96 SPC: 000000 Please, select Unlock Method! Selected Unlock via SD Card (with Unlock APK) Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: sharkoct20181205ss Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 800 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Switching to Download mode...OK Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20e-310-410-APR-04-2019-ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VP01S190617003641 IMEI: 355437-10-323162-2 Target operator: ATT Hardware: rev_10 Please, insert / reinsert SD Card into Phone. Then press "OK" button. Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone...OK Initializing flash...OK Prepairing loader... Executing loader... Connecting to phone...OK Initializing flash...OK Initializing device... Checking data... Calculating. Please Wait... Unlocking... Phone successfully unlocked! Rebooting phone... Warning: If your device ask for Unlock Code, after operation was completed, then You can perform Unlock operation via wipe security! Performed by 3.0.8.04 Software version. | |
The Following 2 Users Say Thank You to mpee47 For This Useful Post: |
