08-16-2021, 19:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Cuba-Holguin
Member: 256260 Status: Offline Thanks Meter: 726 | LMX210APM Unlock question [Answered] user UXSGZl3psl Welcome to Octoplus/Octopus Box LG Software version 3.1.1.03 Card S/N : 0000089C64 -------------------------------------------------------------------------------- Connecting to server 0...OK Username: PXv1kqe97F Authorizing...OK Checking balance...OK Your balance: 0 credits. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: LjJWMnUnoj Authorizing...Failed! Login error: Wrong password! -------------------------------------------------------------------------------- Connecting to server 0...OK Username: LjJWMnUnoj Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Work ID: 00000000016831D0 Checking data...OK Platform: LG Qualcomm Selected port: COM254 Selected model: LMX210APM Reading info...Canceled! Performed by 3.1.1.03 Software version. -------------------------------------------------------------------------------- Work ID: 00000000016831F4 Checking data...OK Platform: LG Qualcomm Selected port: COM106 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-602178-0 Android version: 8.1.0 Battery level: 49% Mode: Normal Firmware compiled date: May 27 2019 Firmware compiled time: 08:00:00 Firmware released date: May 29 2019 Firmware released time: 17:13:22 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK- 1.201016.1.205920.1 IMEI: 355437-10-602178-0 Bluetooth address: 98:B8:BA:E3:E9:4C Wi-Fi MAC address: 98:B8:BA:5C:1C:F4 SPC: 000000 Please, select Unlock Method! Selected Unlock via SD Card (with Unlock APK) Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: LjJWMnUnoj Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20g-310-410-MAY-29-2019- ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VP01S190913004876 IMEI: 355437-10-602178-0 Target operator: ATT Hardware: rev_11 Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone...OK Initializing flash...OK Prepairing loader... Executing loader... Connecting to phone...OK Initializing flash...OK Initializing device... Checking data... Calculating. Please Wait... Unlocking... Phone successfully unlocked! Rebooting phone... Warning: If your device ask for Unlock Code, after operation was completed, then You can perform Unlock operation via wipe security! Performed by 3.1.1.03 Software version. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: XRxwn2E8B4 Authorizing...OK Checking balance...OK Your balance: 0 credits. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: UXSGZl3psl Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Work ID: 000000000168365E Checking data...OK Platform: LG Qualcomm Selected port: COM131 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-602142-6 Android version: 8.1.0 Battery level: 53% Mode: Normal Firmware compiled date: May 27 2019 Firmware compiled time: 08:00:00 Firmware released date: May 29 2019 Firmware released time: 17:13:22 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK- 1.201016.1.205920.1 IMEI: 355437-10-602142-6 Bluetooth address: 98:B8:BA:E3:E8:9E Wi-Fi MAC address: 98:B8:BA:5C:1C:4C SPC: 000000 Please, select Unlock Method! Selected Unlock via SD Card (with Unlock APK) Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: UXSGZl3psl Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20g-310-410-MAY-29-2019- ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VP01S190913008218 IMEI: 355437-10-602142-6 Target operator: ATT Hardware: rev_11 Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone...OK Initializing flash...OK Prepairing loader... Executing loader... Connecting to phone... Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Initializing flash...OK Failed! Please, perform the following steps: 1. Connect SD card via SD card reader to PC. 2. Put phone into Download mode manually. 3. Repeat Unlock operation. Rebooting phone... Performed by 3.1.1.03 Software version. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: UXSGZl3psl Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Work ID: 0000000001683882 Checking data...OK Platform: LG Qualcomm Selected port: COM131 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-602142-6 Android version: 8.1.0 Battery level: 55% Trying to enable Diagnostics ports... Found model LMX210AP: ÿh at port COM131 Reading info... Model ID: LM-X210APM IMEI: 355437-10-602142-6 Android version: 8.1.0 Battery level: 55% Mode: Normal Firmware compiled date: May 27 2019 Firmware compiled time: 08:00:00 Firmware released date: May 29 2019 Firmware released time: 17:13:22 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK- 1.201016.1.205920.1 IMEI: 355437-10-602142-6 Bluetooth address: 98:B8:BA:E3:E8:9E Wi-Fi MAC address: 98:B8:BA:5C:1C:4C SPC: 000000 Please, select Unlock Method! Selected Unlock via SD Card (with Unlock APK) Unlock operation for LMX210APM will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: UXSGZl3psl Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Can't found Micro SD cards Please, connect Micro SD card to PC, then press "OK" button! Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Platform: msm8937 SW version: LMX210APMAT-01-V20g-310-410-MAY-29-2019- ARB03+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: VP01S190913008218 IMEI: 355437-10-602142-6 Target operator: ATT Hardware: rev_11 Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone...OK Initializing flash...OK Prepairing loader... Executing loader... Connecting to phone... Please, perform the following steps: 1. Disconnect cable. 2. Power phone OFF and put it to Download mode. 3. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Initializing flash...OK Failed! Rebooting phone... Performed by 3.1.1.03 Software version. -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Work ID: 0000000001683BB8 Checking data...OK Platform: LG Qualcomm Selected port: COM131 Selected model: LMX210APM Reading info... Model ID: LM-X210APM IMEI: 355437-10-602142-6 Android version: 8.1.0 Battery level: 57% Mode: Normal Firmware compiled date: May 27 2019 Firmware compiled time: 08:00:00 Firmware released date: May 29 2019 Firmware released time: 17:13:22 SW Version: MPSS.JO.3.0.c12-00015-8937_GENNS_PACK- 1.201016.1.205920.1 IMEI: 355437-10-602142-6 Bluetooth address: 98:B8:BA:E3:E8:9E Wi-Fi MAC address: 98:B8:BA:5C:1C:4C SPC: 000000 Please, select Unlock Method! Selected Unlock via wipe security (with Unlock codes) Unlocking... Initializing ADB...OK Waiting for phone...OK Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: UXSGZl3psl Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "LMX210APM_355437106021426_17-08-2021_ 02-53-04.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Connect USB cable to then phone 4. Press "Ok" button Found model LMX210AP* ÿh at port COM131 Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: UXSGZl3psl Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OKOK Finalizing...Failed! Error code: KLQWHCKAWF Performed by 3.1.1.03 Software version. -------------------------------------------------------------------------------- Connecting to server 0...OK Username: UXSGZl3psl Authorizing...OK Checking balance...OK Your balance: 0 credits. |
08-17-2021, 06:21 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,140 | Hello. Please download and install latest software version 3.1.4 from the Support Area. (Path: /Soft/Octoplus LG/RELEASE SOFTWARE/install_octoplus_octopus_LG_3.1.4.exe) and repeat operation once again. Quote:
