06-13-2017, 00:05 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Redlands Ca Age: 49
Member: 810122 Status: Offline Thanks Meter: 65 | Lg v521 frp please Checking data...OK Platform: LG Qualcomm Selected port: COM185 Selected model: V521 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-V521 IMEI: 356286-07-305361-8 Android version: 7.0 Battery level: 3% SW Version: V52120h Mode: Normal Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Resetting FRP Lock... LAF Error: 80000121. Trying second method...OK Resetting FRP lock successfully completed! Performed by 2.6.8 Software version. |
06-13-2017, 07:39 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,425 | Hello. Does FRP was removed from your device, after performing Reset FRP operation? We have prepared test Software version for You. Please download it from the Support Area ("LG/TEST SOFTWARE" folder), then repeat operation again and post here full Software log. Last edited by Octopus box; 06-15-2017 at 08:23. |
06-14-2017, 20:04 | #3 (permalink) |
Member: 810122 Status: Offline Thanks Meter: 65 | DID NOT RESET FRP AND YOUR TEST ALSO DID NOT RESET FRP Welcome to Octoplus/Octopus Box LG Software version 2.6.8.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM185 Selected model: V521 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-V521 IMEI: 356286-07-305361-8 Android version: 7.0 Battery level: 1% SW Version: V52120h Mode: Emergency Initializing flash...OK SW version: LGV521AT-01-V20h-310-260-MAR-28-2017-ARB01+0 Android version: 7.0 LAF Version: 1.1 Product ID: CW85S161203006127 IMEI: 356286-07-305361-8 Target operator: TMO Hardware: rev_10 Reset FRP operation for V521 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock... Writing loader...OK Writing userdata...Failed! Restoring loader...OK Rebooting phone... Performed by 2.6.8.3 Software version. |
06-15-2017, 08:03 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,425 | Please perform 'Read Full Flash' operation, then send us the file, we will research where can be the problem. Last edited by Octopus box; 06-15-2017 at 08:22. |
