05-02-2018, 06:42 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: pakistan
Member: 1119917 Status: Offline Sonork: nedi Thanks Meter: 190 | LS990 or D855 hang on logo [Answered] Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: D855 Reading info... Could not detect mode! Performed by 2.8.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM124 Selected model: D855 Reading info... Model ID: LGLS990 Incompatible model ID! Canceled! Performed by 2.8.4 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM124 Selected model: D855 Reading info... Model ID: LGLS990 Incompatible model ID! IMEI: 350305-26-000000-4 Android version: 4.4.2 Battery level: 0% SW Version: LS990ZV4 Mode: Emergency Initializing flash...OK SW version: LGD855AT-00-V10n-GLOBAL-COM-OCT-22-2014-32G+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: PT02S140925005646 IMEI: 352596-06-290703-6 Target operator: GLOBAL Hardware: rev_10 Performed by 2.8.4 Software version. Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM124 Selected model: LS990 Reading info... IMEI: 350305-26-000000-4 Android version: 4.4.2 Battery level: 0% SW Version: LS990ZV4 Mode: Emergency Initializing flash...OK SW version: LGD855AT-00-V10n-GLOBAL-COM-OCT-22-2014-32G+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: PT02S140925005646 IMEI: 352596-06-290703-6 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LS990ZV8_95_00.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.4 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: LS990 Reading info... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Cannot terminate an externally created thread Performed by 2.8.4 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM124 Selected model: LS990 Reading info... IMEI: 350305-26-000000-4 Android version: 4.4.2 Battery level: 4% SW Version: LS990ZV4 Mode: Emergency Initializing flash...OK SW version: LGD855AT-00-V10n-GLOBAL-COM-OCT-22-2014-32G+0 Android version: 5.0.1 LAF Version: 1.1 Product ID: PT02S140925005646 IMEI: 352596-06-290703-6 Target operator: SPR Hardware: rev_10 Performed by 2.8.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM124 Selected model: LS990 Reading info... IMEI: 350305-26-000000-4 Android version: 4.4.2 Battery level: 4% SW Version: LS990ZV4 Mode: Emergency Initializing flash...OK SW version: LGD855AT-00-V10n-GLOBAL-COM-OCT-22-2014-32G+0 Android version: 5.0.1 LAF Version: 1.1 Product ID: PT02S140925005646 IMEI: 352596-06-290703-6 Target operator: SPR Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "d855_v20i_00_32gb.oct"...Failed! File declared for different phone model! Performed by 2.8.4 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM124 Selected model: LS990 Reading info... IMEI: 350305-26-000000-4 Android version: 4.4.2 Battery level: 4% SW Version: LS990ZV4 Mode: Emergency Initializing flash...OK SW version: LGD855AT-00-V10n-GLOBAL-COM-OCT-22-2014-32G+0 Android version: 5.0.1 LAF Version: 1.1 Product ID: PT02S140925005646 IMEI: 352596-06-290703-6 Target operator: SPR Hardware: rev_10 Performed by 2.8.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM124 Selected model: D855 Reading info... Model ID: LGLS990 Incompatible model ID! IMEI: 350305-26-000000-4 Android version: 4.4.2 Battery level: 4% SW Version: LS990ZV4 Mode: Emergency Initializing flash...OK SW version: LGD855AT-00-V10n-GLOBAL-COM-OCT-22-2014-32G+0 Android version: 5.0.1 LAF Version: 1.1 Product ID: PT02S140925005646 IMEI: 352596-06-290703-6 Target operator: SPR Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "d855_v20i_00_32gb.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cust...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.4 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: D855 Reading info... Could not detect mode! Performed by 2.8.4 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM127 Selected model: D855 Reading info... Mode: Emergency Initializing flash...OK SW version: LGD855AT-00-V10n-GLOBAL-COM-OCT-22-2014-32G+0 Android version: 5.0 LAF Version: 1.1 Product ID: PT02S140925005646 IMEI: 352596-06-290703-6 Target operator: GLOBAL Hardware: rev_10 Performed by 2.8.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM127 Selected model: D855 Reading info... Model ID: LGLS990 Incompatible model ID! IMEI: 350305-26-000000-4 Android version: 4.4.2 Battery level: 4% SW Version: LS990ZV4 Mode: Emergency Initializing flash...OK SW version: LGD855AT-00-V10n-GLOBAL-COM-OCT-22-2014-32G+0 Android version: 5.0 LAF Version: 1.1 Product ID: PT02S140925005646 IMEI: 352596-06-290703-6 Target operator: GLOBAL Hardware: rev_10 Factory reset... Factory reset done! Performed by 2.8.4 Software version. Connecting to server support.octoplusbox.com:82...OK Authorizing...OK Converting files... Unpacking "PrimaryGPT"...OK Unpacking "modem"...OK Unpacking "sbl1"...OK Unpacking "dbi"...OK Unpacking "aboot"...OK Unpacking "rpm"...OK Unpacking "tz"...OK Unpacking "boot"...OK Unpacking "persist"...OK Unpacking "recovery"...OK Unpacking "rct"...OK Unpacking "misc"...OK Unpacking "laf"...OK Unpacking "factory"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "cache"...OK Unpacking "cache"...OK Unpacking "cache"...OK Unpacking "cache"...OK Unpacking "cache"...OK Unpacking "cache"...OK Unpacking "cache"...OK Unpacking "cache"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "BackupGPT"...OK Unpacking done. Processing files... Identifying sub-files...OK Creating destination file...OK Deleting temporary files... Deleting directory "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_ 00.51104\"... Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \aboot"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \BackupGPT"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \boot"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \cache"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \dbi"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \factory"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \laf"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \misc"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \modem"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \parts.bin"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \persist"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \PrimaryGPT"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \rct"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \recovery"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \rpm"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \sbl1"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \system"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \tz"...OK Deleting file "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104 \userdata"...OK Directory "C:\Users\naveed\AppData\Local\Temp\LS990ZVB_00.51 104\" succesfully deleted! Firmware convert done! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM127 Selected model: LS990 Reading info... IMEI: 352596-06-290703-6 Android version: 5.0 Battery level: 15% SW Version: D85520i Mode: Emergency Initializing flash...OK SW version: LGD855AT-00-V10n-GLOBAL-COM-OCT-22-2014-32G+0 Android version: 5.0 LAF Version: 1.1 Product ID: PT02S140925005646 IMEI: 352596-06-290703-6 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "LS990ZVB_00.51104.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing tz...OK Writing boot...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing factory...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.4 Software version. please help me its stuck at logo,some time recovery tiangle,some time logo then restart...help me its d855 or ls990 i flashed diff version of d55 and ls990 but same issue help. Last edited by Octopus box; 05-02-2018 at 08:02. |
05-02-2018, 08:53 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
