01-03-2019, 05:32 | #1 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Puerto Rico
Member: 2549748 Status: Offline Thanks Meter: 212 | LS998 (v22a) successfully unlocked by special firmware Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.1 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM72 Selected model: LS998 Reading info... IMEI: 352457-09-180593-3 Android version: 8.0.0 Battery level: 65% Mode: Emergency Initializing flash...OK Platform: msm8998 SW version: LS99822a_01 Android version: 8.0.0 LAF Version: 1.1 Product ID: PT03S180526004614 IMEI: 352457-09-180593-3 Target operator: SPR Hardware: rev_10 Performed by 2.9.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM72 Selected model: LS998 Reading info... IMEI: 352457-09-180593-3 Android version: 8.0.0 Battery level: 66% Mode: Emergency Initializing flash...OK Platform: msm8998 SW version: LS99822a_01 Android version: 8.0.0 LAF Version: 1.1 Product ID: PT03S180526004614 IMEI: 352457-09-180593-3 Target operator: SPR Hardware: rev_10 Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "LS998V20a_to_US998V10d_for_unlock.oct"...OK Selecting firmware partitions...OK Selected default partitions! Setting options...OK Do you want to format User Data? Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing PrimaryGPT...OK Writing laf...OK Writing lafbak...OK Writing factory...OK Writing persist...OK Writing system...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing xbl...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing xbl2...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing boot...OK Writing recovery...OK Writing recoverybak...OK Writing tz...OK Writing tzbak...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing rpm...OK Writing rpmbak...OK Writing hyp...OK Writing hypbak...OK Writing pmic...OK Writing pmicbak...OK Writing devcfg...OK Writing devcfgbak...OK Writing modem...OK Writing sec...OK Writing keymaster...OK Writing keymasterbak...OK Writing cmnlib...OK Writing cmnlibbak...OK Writing cmnlib64...OK Writing cmnlib64bak...OK Writing apdp...OK Writing msadp...OK Writing abl...OK Writing ablbak...OK Writing logfs...OK Writing storsec...OK Writing storsecbak...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing BackupGPT...OK Writing PrimaryGPT...OK Writing BackupGPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.1 Software version. Last edited by Octopus box; 01-03-2019 at 05:56. |
The Following User Says Thank You to reyxito For This Useful Post: |
01-30-2019, 14:16 | #3 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | @Gsm Boiragi Hello. You can try unlocked your phone via special firmware "LS998V20a_to_US998V10d_for_unlock.oct". Quote:
The Following User Says Thank You to Octopus support For This Useful Post: |
05-29-2019, 22:29 | #4 (permalink) |
Crazy Poster Join Date: Jun 2014
Member: 2213224 Status: Offline Thanks Meter: 20 | “LS998V20a_to_US998V10d_for_unlock.oct” Firmware flashed, detected as "US998" The Unlock button is gray out. How can you enable "unlock" button ? Welcome to Octoplus/Octopus Box LG Software version 2.9.5 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1548 Selected model: US998 Reading info... Model ID: LG-US998 IMEI: 352457-09-058335-8 Android version: 7.1.2 Battery level: 100% Mode: Normal Performed by 2.9.5 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1548 Selected model: US998 Reading info... Model ID: LG-US998 IMEI: 352457-09-058335-8 Android version: 7.1.2 Battery level: 100% Mode: Normal Performed by 2.9.5 Software version. |
05-29-2019, 23:03 | #5 (permalink) | |
Insane Poster Join Date: Apr 2017 Location: Anaheim California
Member: 2710649 Status: Offline Thanks Meter: 47 | Quote:
he might of flashed that firmware and it unlock no need to preform unlock after that ... just input a different simcard and double check most of the new sprint LG's they simply flash a open firmware and no need to unlock ... | |
The Following 2 Users Say Thank You to Christina714 For This Useful Post: |
06-12-2019, 18:04 | #7 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Bolivia
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | my version is 28a I can pass the software : LS998V20a_to_US998V10d_for_unlock.oct ??? |
The Following User Says Thank You to tomelich For This Useful Post: |
08-21-2019, 07:29 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We don't test operation on 28x version of firmware, but on 26x version everything works fine |
The Following 3 Users Say Thank You to Octopus box For This Useful Post: |
11-22-2019, 04:08 | #12 (permalink) | |
Junior Member Join Date: Sep 2011 Location: ilocos norte philipines
Member: 1658253 Status: Offline Thanks Meter: 7 | Octopus support;13528268]@Gsm Boiragi Hello. You can try unlocked your phone via special firmware "LS998V20a_to_US998V10d_for_unlock.oct".[/QUOTE] big thanks for this thread i got one Done problem invalid sim Done via flashing using LS998V20a_to_US998V10d_for_unlock.oct"...OK Quote:
all working | |
The Following 2 Users Say Thank You to maco34 For This Useful Post: |
11-26-2020, 01:36 | #14 (permalink) |
Insane Poster Join Date: Oct 2016
Member: 2636022 Status: Offline Thanks Meter: 13 | Unlock done..Downgrade 30a Yes support downgrade ... You can do it without problem, I already tried it... white this file... LS998V20a_to_US998V10d_for_unlock.oct Platform: LG Qualcomm Selected port: COM48 Selected model: LS998 Reading info... Android version: 8.0.0 Battery level: 55% Mode: Emergency Initializing flash...OK Platform: msm8998 SW version: LS99830a_00 Android version: 8.0.0 LAF Version: 1.1 Target operator: SPR Hardware: rev_10 Performed by 3.0.5 Software version. |
