Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: algeria
Member: 217891 Status: Offline Thanks Meter: 237 | ![]() -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM113 Selected model: M160 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Could not detect mode! Performed by 2.8.9.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM59 Selected model: M160 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M160 IMEI: 000000-00-000000-0 Android version: 6.0.1 Battery level: 64% SW Version: M16010b Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGM160AT-00-V10c-222-01-DEC-07-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB45S170722001873 IMEI: 354xxxxxxxxxxxxx Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Resetting FRP Lock... LAF Error: 80000121. Trying second method...Failed! LAF Error: 0F0F0F0F. Please, reflash with "M150x-M160x_Android_6.0.x_for_Reset_FRP.oct" firmware from Support Area ("LG/FOR UNLOCK AND REPAIR" folder), and try to perform Reset FRP operation again. Performed by 2.8.9.1 Software version. Connecting to server support2.octoplusbox.com:82...OK Authorizing...OK Last edited by Octopus box; 11-08-2018 at 06:11. |
![]() | #2 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Oct 2009
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 26,755 | Hello. Please read attentively Software instructions in log: Quote:
![]() | #3 (permalink) |
Member: 217891 Status: Offline Thanks Meter: 237 | thanks its work good Welcome to Octoplus/Octopus Box LG Software version 2.8.9.1 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM113 Selected model: M160 Reading info... Could not detect mode! Performed by 2.8.9.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM59 Selected model: M160 Reading info... Model ID: LG-M160 IMEI: 000000-00-000000-0 Android version: 6.0.1 Battery level: 66% SW Version: M16010b Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGM160AT-00-V10c-222-01-DEC-07-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB45S170722001873 IMEI: 35xxxxxxxxxxxx Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "M150x-M160x_Android_6.0.x_for_Reset_FRP.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing 1/2...OK Writing 2/2...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.9.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM113 Selected model: M160 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Could not detect mode! Performed by 2.8.9.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM59 Selected model: M160 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M160 IMEI: 354xxxxxxxxxxxxxxxxx Android version: 6.0.1 Battery level: 67% SW Version: M16010c Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGM160AT-00-V10c-222-01-DEC-07-2017+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CB45S170722001873 IMEI: 354xxxxxxxxxxxxxx Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method...OK Resetting FRP Lock...OK Resetting FRP lock successfully completed! If the phone hang on logo or is restarting afetr performing the operation, please re-flash it using the same or higher version of firmware Performed by 2.8.9.1 Software version. |
The Following 2 Users Say Thank You to moh_boulk17 For This Useful Post: |
