08-28-2018, 11:12 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Canada Toronto
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | LM-X210CM Unlock Successfully Done Welcome to Octoplus/Octopus Box LG Software version 2.8.8 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM222 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09-102189-5 Android version: 7.1.2 Battery level: 73% SW Version: X210CM10c Mode: Normal Performed by 2.8.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM222 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09-102189-5 Android version: 7.1.2 Battery level: 73% SW Version: X210CM10c Trying to enable Diagnostics ports... Found model LMX210CM: ÿh at port COM222 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210CM_354376091021895_28-08-2018_15-00- 13.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "LMX210CM_354376091021895_28-08-2018_15-06- 34.SEC" Writing security area...OK Switching to Normal mode... Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Found model LMX210CM* ÿh at port COM222 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! Rebooting phone... Performed by 2.8.8 Software version. Br.Ah$an. Last edited by Octopus box; 08-28-2018 at 11:53. |
The Following 4 Users Say Thank You to pak555 For This Useful Post: |
09-13-2018, 15:07 | #2 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Middle-Earth
Member: 190274 Status: Offline Thanks Meter: 47 | Did same phone but successful, still locked. Welcome to Octoplus/Octopus Box LG Software version 2.8.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM640 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09-230227-8 Android version: 7.1.2 Battery level: 47% SW Version: X210CM10h Mode: Normal Firmware compiled date: Jun 20 2018 Firmware compiled time: 06:00:00 Firmware released date: Jul 5 2018 Firmware released time: 20:00:53 SW Version: MPSS.JO.3.0.c12-00013-8937_GENNS_PACK-1 IMEI: 354376-09-230227-8 Bluetooth address: 084:6A:4B:BB:42 Wi-Fi MAC address: 084:6A:B7:5D:19 SPC: 000000 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210CM_354376092302278_13-09-2018_13-50- 23.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "LMX210CM_354376092302278_13-09-2018_13-57- 24.SEC" Writing security area...OK Switching to Normal mode... Found model LMX210CM: ÿh at port COM640 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! Rebooting phone... Performed by 2.8.8 Software version. |
The Following User Says Thank You to hiroprotagonist For This Useful Post: |
09-13-2018, 15:23 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | As i can see from the Software log You have higher firmware version V10h, we are continue to work on new and improve our solutions, please stay tuned for future updates. |
10-24-2018, 06:32 | #5 (permalink) |
Freak Poster Join Date: Sep 2014 Location: islamabad pakistan Age: 39
Member: 2266425 Status: Offline Thanks Meter: 58 | Unfortunately, still no solution at the moment. Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09- Android version: 7.1.2 Battery level: 85% SW Version: X210CM10c Trying to enable Diagnostics ports... Found model LMX210CM: ÿh at port COM36 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210CM_3543760900 _23-10-2018_05-30- 06.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "LMX210CM_3543760900 _23-10-2018_05-37- 17.SEC" Writing security area...OK Switching to Normal mode... Found model at port COM36 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! Rebooting phone... Performed by 2.8.9 Software version. |
The Following User Says Thank You to bilal khan12345 For This Useful Post: |
10-29-2018, 21:45 | #8 (permalink) |
No Life Poster Join Date: Jun 2006 Location: united states
Member: 296215 Status: Offline Thanks Meter: 56 | octopus log process done but still asking unlock code.... any news for this model? Checking data...OK Platform: LG Qualcomm Selected port: COM18 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09-047315-4 Android version: 7.1.2 Battery level: 100% SW Version: X210CM10h Mode: Normal Firmware compiled date: Jun 20 2018 Firmware compiled time: 06:00:00 Firmware released date: Jul 5 2018 Firmware released time: 20:00:53 SW Version: MPSS.JO.3.0.c12-00013-8937_GENNS_PACK-1 IMEI: 354376-09-047315-4 Bluetooth address: 48:60:5F:E2:28:0B Wi-Fi MAC address: 48:60:5F:55:C3:CC SPC: 000000 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210CM_354376090473154_29-10-2018_16-29- 30.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "LMX210CM_354376090473154_29-10-2018_16-35- 35.SEC" Writing security area...OK Switching to Normal mode... Found model LMX210CM: ÿh at port COM18 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! Rebooting phone... Performed by 2.8.9 Software version. Last edited by Octopus box; 10-30-2018 at 05:59. |
11-16-2018, 19:24 | #10 (permalink) |
Freak Poster Join Date: Jan 2007 Location: <Al hind al Garbiyya> Barbados
Member: 430155 Status: Offline Thanks Meter: 40 | LM-X210CM Unlock Successfully unlocked . Welcome to Octoplus/Octopus Box LG Software version 2.8.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM179 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09-104778-3 Android version: 7.1.2 Battery level: 20% SW Version: X210CM10c Trying to enable Diagnostics ports... Found model LMX210CM: ÿh at port COM179 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210CM_354376091047783_16-11-2018_13-59- 34.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "LMX210CM_354376091047783_16-11-2018_14-08- 51.SEC" Writing security area...OK Switching to Normal mode... Found model at port COM179 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! Rebooting phone... Performed by 2.8.9 Software version. |
The Following User Says Thank You to miftahuljawwal For This Useful Post: |
11-22-2018, 06:05 | #12 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Quote:
"Unlock" is supported via Server (require 50 Octoplus Server Credits). Please use the latest Software version from the Support Area (here is direct link for You: https://drive.google.com/open?id=1It...BWjf1Ry82KzPUe). | |
11-25-2018, 08:07 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Yes, as I have written above, "Unlock" is supported via Server (require 50 Octoplus Server Credits). Please use the latest Software version from the Support Area (here is direct link for You: https://drive.google.com/open?id=1It...BWjf1Ry82KzPUe). |
The Following 4 Users Say Thank You to Octopus box For This Useful Post: |
