Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 12-30-2017, 14:20   #1 (permalink)
Y2ksalman's Avatar
Member: 194511
Sonork: 100.1577836
Thanks Meter: 1,591
Thumbs up M255 successfully unlocked
Welcome to Octoplus/Octopus Box LG Software version 2.7.8
Checking data...OK
Platform: LG Qualcomm
Selected port: COM13
Selected model: M255
Reading info...
Model ID: LG-M255
IMEI: 355574-08-181629-5
Android version: 7.0
Battery level: 21%
SW Version: M25510l
Trying to enable Diagnostics ports...
Found model LGM255AT: h at port COM13
Unlocking...
Reading QCN...
Send SPC...OK
Reading Mobile Property...OK
Reading Feature Mask...OK
Reading Roaming List 0...OK
Reading NV_Numbered Items...OK
Reading NV_Numbered SIM1 Items...OK
Reading NV_Numbered SIM2 Items...OK
Reading NV Items...OK
Reading EFS...OK
Reading Provisioning Items...OK
Reading QCN done!
Backup saved to "M255_355574081816295_30-12-2017_18-11-59.qcn"
Switching to Download mode...OK
Initializing flash...OK
Reading partitions...OK
Reading security area...OK
Backup saved to "M255_355574081816295_30-12-2017_18-18-22.SEC"
Writing security area...OK
Switching to Normal mode...
Trying to enable Diagnostics ports...Failed!
Initializing ADB...OK
ADB Server was found. Trying to kill...
Waiting for phone...
Please, reconnect phone, enable USB debugging, and try again.
To enable USB debugging, please perform the following steps:
1. Disconnect cable
2. Install LG Android ADB drivers
3. Go to "Settings" -> "About phone" -> "Software information"
4. Click on Build number 5 times
5. Enable "Settings" -> "Developer options" -> "USB debugging" option
6. Connect the cable and check, whether ADB interface has appeared in
PC Device Manager.OK
Diagnostics ports are enbled!
Switching to Serial Port...
Found model LGM255AT* h at port COM13
Send SPC...OK
Writing QCN...
Writing NV_Numbered Items...OK
Writing NV_Numbered SIM1 Items...OK
Writing NV_Numbered SIM2 Items...OK
Writing QCN done!
Phone successfully unlocked!
Rebooting phone...
Performed by 2.7.8 Software version.
The Following User Says Thank You to Y2ksalman For This Useful Post:
Old 03-10-2018, 01:42   #2 (permalink)
Member: 2703155
Thanks Meter: 6
BUT HOW TO ROOT
Welcome to Octoplus/Octopus Box LG Software version 2.7.6
Checking data...OK
Selected port: COM17
Reading info...
Could not detect mode!
Performed by 2.7.6 Software version.
Checking data...OK
Selected port: COM418
Reading info...
Model ID: LG-M255
IMEI: 000000-00-000000-0
Battery level: 7%
SW Version: M25510l
Mode: Emergency
SW version: LGM255AT-01-V10l-310-410-OCT-23-2017-ARB00+0
LAF Version: 1.1
Product ID: CY15S171118003154
IMEI: 355574-08-207987-7
Target operator: ATT
Hardware: rev_10
Unlocking...
1. Disconnect cable
6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.
Please perform the following steps:
1. Disconnect cable
2. Put phone into Normal mode manually
3. Press "Ok" button
Waiting for phone...OK
Switching to Serial Port...Failed!
Checking root access...
Phone is not rooted.
Please, root the phone manually!
Old 03-10-2018, 06:29   #3 (permalink)
Member: 2080559
Thanks Meter: 23
Please share root, i have 2 that require unlock.
Old 06-13-2019, 14:02   #4 (permalink)
Member: 2267293
Thanks Meter: 62
Also got succesful but using m257 model after failing with m255 model
I TRIED TO SELECT THE REAL MODEL M255 BUT I DID NOT GET SUCCESS, UNTIL I READ SOMEONE'S POST SOMEWHERE AND HE SUGGESTED TO SELECT M257 MODEL AND EVERYTHING WENT FINE..
6/13/2019 3:42:37 PM > Checking data...6/13/2019 3:42:38 PM > OK
6/13/2019 3:42:38 PM > Platform: LG Qualcomm
6/13/2019 3:42:38 PM > Selected port: COM47
6/13/2019 3:42:38 PM > Selected model: M257
6/13/2019 3:42:38 PM > Reading info...
6/13/2019 3:42:39 PM > Model ID: LG-M255
6/13/2019 3:42:39 PM > IMEI: 355574-08-281106-3
6/13/2019 3:42:39 PM > Android version: 8.1.0
6/13/2019 3:42:39 PM > Battery level: 94%
6/13/2019 3:42:40 PM > Mode: Normal
6/13/2019 3:42:40 PM > Firmware compiled date: May 07 2018
6/13/2019 3:42:40 PM > Firmware compiled time: 06:00:00
6/13/2019 3:42:40 PM > Firmware released date: Aug 24 2018
6/13/2019 3:42:40 PM > Firmware released time: 16:08:31
6/13/2019 3:42:40 PM > SW Version: 6/13/2019 3:42:40 PM > MPSS.JO.2.0.c1.2-00044-8937_GENNS_PACK-1
6/13/2019 3:42:40 PM > IMEI: 355574-08-281106-3
6/13/2019 3:42:40 PM > Bluetooth address: 00:3D:E8:34:1A:AE
6/13/2019 3:42:40 PM > Wi-Fi MAC address: 00:3D:E8:BA:E9:5A
6/13/2019 3:42:40 PM > SPC: 000000
6/13/2019 3:42:41 PM > Unlocking...
6/13/2019 3:42:43 PM > Reading QCN...
6/13/2019 3:42:43 PM > Send SPC...6/13/2019 3:42:43 PM > OK
6/13/2019 3:42:43 PM > Reading Mobile Property...6/13/2019 3:42:43 PM > OK
6/13/2019 3:42:43 PM > Reading Feature Mask...6/13/2019 3:42:44 PM > OK
6/13/2019 3:42:44 PM > Reading Roaming List 0...6/13/2019 3:42:44 PM > OK
6/13/2019 3:42:44 PM > Reading NV_Numbered Items...6/13/2019 3:44:46 PM > OK
6/13/2019 3:44:46 PM > Reading NV_Numbered SIM1 Items...6/13/2019 3:46:48 PM > OK
6/13/2019 3:46:48 PM > Reading NV_Numbered SIM2 Items...6/13/2019 3:48:57 PM > OK
6/13/2019 3:48:57 PM > Reading NV Items...6/13/2019 3:49:01 PM > OK
6/13/2019 3:49:01 PM > Reading EFS...6/13/2019 3:49:01 PM > OK
6/13/2019 3:49:01 PM > Reading Provisioning Items...6/13/2019 3:49:11 PM > OK
6/13/2019 3:49:11 PM > Reading QCN done!
6/13/2019 3:49:11 PM > Backup saved to "M257_355574082811063_13-06-2019_15-42-43.qcn"
6/13/2019 3:49:11 PM > Switching to Download mode...6/13/2019 3:49:36 PM > OK
6/13/2019 3:49:36 PM > Initializing flash...6/13/2019 3:49:38 PM > OK
6/13/2019 3:49:38 PM > Reading partitions...6/13/2019 3:49:38 PM > OK
6/13/2019 3:49:38 PM > Detecting writing method...
6/13/2019 3:49:39 PM > LAF Error: 80000121.
6/13/2019 3:49:39 PM > Trying second method...
6/13/2019 3:49:39 PM > Trying third method...
6/13/2019 3:49:39 PM > Eroor: Reading at first PARTITION block6/13/2019 3:49:39 PM > Failed!
6/13/2019 3:49:39 PM > Reading security area...6/13/2019 3:49:39 PM > Failed!
6/13/2019 3:49:39 PM > LAF Error: 80000119.
6/13/2019 3:49:39 PM > Writing security area...6/13/2019 3:49:51 PM > OK
6/13/2019 3:49:51 PM > Switching to Normal mode...
6/13/2019 3:50:28 PM > Found model LGM255AT* h at port COM47
6/13/2019 3:50:28 PM > Send SPC...6/13/2019 3:50:28 PM > OK
6/13/2019 3:50:28 PM > Writing QCN...
6/13/2019 3:50:28 PM > Writing NV_Numbered Items...6/13/2019 3:50:48 PM > OK
6/13/2019 3:50:48 PM > Writing NV_Numbered SIM1 Items...6/13/2019 3:51:21 PM > OK
6/13/2019 3:51:21 PM > Writing NV_Numbered SIM2 Items...6/13/2019 3:51:56 PM > OK
6/13/2019 3:51:56 PM > Writing QCN done!
6/13/2019 3:51:56 PM > Phone successfully unlocked!
6/13/2019 3:51:56 PM > Rebooting phone...
6/13/2019 3:51:56 PM > Performed by 2.9.5 Software version.
6/13/2019 3:51:56 PM > Elapsed Time: 12:09:21 AM
THANKS TO OCTOPLUS TEAM:
Old 06-14-2019, 05:31   #5 (permalink)
Member: 2420481
Sonork: none
Thanks Meter: 17
only edge after unlock cant go to 4g connection,,pls help
Old 06-18-2019, 13:10   #6 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 25,654
Please, post here full Software log of perfomed operation
Old 09-02-2019, 22:25   #7 (permalink)
Member: 320108
Thanks Meter: 18
i unlocked one but NO SERVICE...please help
Old 09-03-2019, 08:07   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
Old 09-03-2019, 14:33   #9 (permalink)
Member: 2420481
Sonork: none
Thanks Meter: 17
ihave same problem also..edge only not in 4G
Old 10-15-2019, 21:38   #10 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 780
another lg k20 m25510q
7.0 without root:
Welcome to Octoplus/Octopus Box LG Software version 2.9.6
Checking data...OK
Selected port:
Reading info...
Performed by 2.9.6 Software version.
Checking data...OK
Selected port: COM257
Reading info...
Model ID: LG-M255
IMEI: 355574-08-289507-4
Battery level: 100%
Mode: Normal
Firmware compiled date: Apr 17 2017
Firmware compiled time: 03:00:00
Firmware released date: Dec 6 2017
Firmware released time: 13:00:09
SW Version: MPSS.JO.2.0.c1.2-00029-8937_GENNS_PACK-1
Bluetooth address: 00:3D:E8:4B:52:04
Wi-Fi MAC address: 00:3D:E8:C9:18:90
SPC: 000000
Unlocking...
Reading QCN...
Send SPC...OK
Reading EFS...OK
Reading QCN done!
Backup saved to "M255_355574082895074_15-10-2019_16-22-
55.qcn"
Trying third method...OK
Backup saved to "M255_355574082895074_15-10-2019_16-30-
24.SEC"
Found model LGM255AT* h at port COM257
Send SPC...OK
Writing QCN...
Writing QCN done!
Rebooting phone...
The Following User Says Thank You to mrfixit For This Useful Post:
Page generated in 0.20184 seconds with 8 queries
