Need help with d820 [Solved] Checking data...OK Platform: LG Qualcomm Selected port: COM11 Selected model: D820 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd59db4e ([email protected]) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Mar 17 15:16:36 PDT 201 Android version: 4.4.4 Hardware: Qualcomm MSM 8974 HAMMERHEAD (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Failed! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM84 Selected model: D820 Reading info...OK Mode: Normal Model ID: AAAAANAZ:ÿh°? Firmware compiled date: Mar 12 2014 Firmware compiled time: 20:00:00 Firmware released date: Jun 4 2014 Firmware released time: 17:04:20 SW Version: M8974A-2.0.50.1.16 IMEI: 359125-05-300508-0 SPC: 707121 Fixing IMEI... New IMEI: 359125-05-404455-9 Skip Read/Write QCN Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF and press and hold "Vol+" button) 3. Connect cable and press "Ok" button.Failed! |
Hello. What Software version do You use exactly? If You don't use the latest Software version, please install it. Then install these drivers (http://octoplusbox.com/files/drivers...Ver_3.12.3.exe, https://mega.co.nz/#!OlxHUKzC!j5qLEU..._sS4v0fK02kQUg), disconnect all devices from your PC, re-boot the PC, re-start the phone, turn on USB Debugging Mode and try to repeat the operation again. Post here the result. |
Definetly the problems are my drivers because I installed in another computer and is woring as a charm Big thank you octopus team |
