need lg v490 flash file Platform: LG Qualcomm Selected port: COM48 Selected model: V490 Reading info... Model ID: LG-V490 IMEI: 354665-06-335742-2 Android version: 4.4.2 Battery level: 100% Mode: Normal Firmware compiled date: Jun 19 2014 Firmware compiled time: 10:00:00 Firmware released date: Sep 3 2014 Firmware released time: 18:33:02 SW Version: MPSS.DI.2.0.1.c1.15-00013-M8926DAAAANAZM-1 IMEI: 354665-06-335742-2 SPC: 000000 need flash file |
Unfortunately, for this phone model V490 firmware isn't available at the Support Area, we will try to find it and upload to the Support Area, if You can get the firmware for this phone, You can convert firmware via Octoplus LG Tool( Firwmare convertor button in Software) into *.oct file format that You can reflash the phone. |
Welcome to Octoplus/Octopus Box LG Software version 2.1.7 Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM48 Selected model: V490 Reading info... Model ID: LG-V490 IMEI: 354665-06-335742-2 Android version: 4.4.2 Battery level: 100% Mode: Normal Firmware compiled date: Jun 19 2014 Firmware compiled time: 10:00:00 Firmware released date: Sep 3 2014 Firmware released time: 18:33:02 SW Version: MPSS.DI.2.0.1.c1.15-00013-M8926DAAAANAZM-1 IMEI: 354665-06-335742-2 SPC: 000000 Converting files... Unpacking "C:\Users\rimasha\Downloads\V49020b_00.kdz"... OK Opening "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\V4 9020b_00.dz"...OK Unpacking "PrimaryGPT_0.bin"...OK Unpacking "modem_16384.bin"...OK Unpacking "sbl1_147456.bin"...OK Unpacking "rpm_149504.bin"...OK Unpacking "tz_150528.bin"...OK Unpacking "sdi_151552.bin"...OK Unpacking "aboot_152576.bin"...OK Unpacking "rpmb_156672.bin"...OK Unpacking "tzb_157696.bin"...OK Unpacking "abootb_158720.bin"...OK Unpacking "persist_212992.bin"...OK Unpacking "laf_278528.bin"...OK Unpacking "boot_327680.bin"...OK Unpacking "recovery_376832.bin"...OK Unpacking "sbl1b_444416.bin"...OK Unpacking "rct_447488.bin"...OK Unpacking "factory_492544.bin"...OK Unpacking "cust_688128.bin"...OK Unpacking "system_901120.bin"...OK Unpacking "system_1164296.bin"...OK Unpacking "system_1168408.bin"...OK Unpacking "system_1429520.bin"...OK Unpacking "system_1692696.bin"...OK Unpacking "system_1953808.bin"...OK Unpacking "system_2216984.bin"...OK Unpacking "system_2478096.bin"...OK Unpacking "system_2741272.bin"...OK Unpacking "system_3002384.bin"...OK Unpacking "system_3265560.bin"...OK Unpacking "system_3526672.bin"...OK Unpacking "system_3788816.bin"...OK Unpacking "system_4050960.bin"...OK Unpacking "system_4313104.bin"...OK Unpacking "system_4571136.bin"...OK Unpacking "system_4833280.bin"...OK Unpacking "BackupGPT_30776320.bin"...OK Unpacking done. Processing files... Identifying sub-files...OK Creating destination file...OK Deleting temporary files... Deleting directory "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\". .. Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\ab oot.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\ab ootb.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\Ba ckupGPT.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\bo ot.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\cu st.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\fa ctory.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\la f.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\mo dem.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\pa rts.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\pe rsist.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\Pr imaryGPT.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\rc t.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\re covery.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\rp m.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\rp mb.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\sb l1.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\sb l1b.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\sd i.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\sy stem.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\tz .bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\tz b.bin"...OK Deleting file "C:\Users\rimasha\AppData\Local\Temp\V49020b_00\V4 9020b_00.dz"...OK Directory "C:\Users\rimasha\AppData\Local\Temp\V49020b_0 0\" succesfully deleted! Firmware convert done! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: V490 Reading info...Failed! Port busy -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: V490 Reading info...Failed! Port busy -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: V490 Reading info...Failed! Port busy -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: V490 Reading info...Failed! Port busy -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: V490 Reading info...Failed! Port busy -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM48 Selected model: V490 Reading info... Model ID: LG-V490 IMEI: 354665-06-335742-2 Android version: 4.4.2 Battery level: 100% Mode: Normal Opening "V49020b_00.oct"...OK Switching to Download mode...OK Initializing flash...OK Setting options...OK Reading partition...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing rpmb...OK Writing tzb...OK Writing abootb...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing sbl1b...OK Writing factory...OK Writing cust...OK Writing system...OK Writing BackupGPT...OK Reading partition...OK Formating RCT...OK Formating MPT...OK Resetting FRP Lock... Finalizing...OK Writing firmware done! thanx problame solved |
Thanks for good report! Firmwares for LG V490 are now available in the Support Area. |
