02-08-2017, 10:03 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | LG H790 FRP stuck on LG nexus logo [Solved] Code: 8/02/2017 4:16:01 PM > Selected port: COM127 8/02/2017 4:16:01 PM > Selected model: H790 8/02/2017 4:16:01 PM > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). 8/02/2017 4:16:01 PM > Reading info... 8/02/2017 4:16:04 PM > Model ID: LGH790 8/02/2017 4:16:04 PM > IMEI: 353626-07-428352-9 8/02/2017 4:16:04 PM > Android version: 8/02/2017 4:16:04 PM > Battery level: 37% 8/02/2017 4:16:04 PM > SW Version: 8/02/2017 4:16:04 PM > LGH790AT-00-V10f-NXS-XXX-OCT-0 8/02/2017 4:16:06 PM > Mode: Emergency 8/02/2017 4:16:06 PM > Initializing flash...8/02/2017 4:16:09 PM > OK 8/02/2017 4:16:10 PM > SW version: 8/02/2017 4:16:10 PM > LGH790AT-00-V10f-NXS-XXX-OCT-03-2015-32G-MDA89E-US 8/02/2017 4:16:10 PM > Android version: 6.0 8/02/2017 4:16:10 PM > LAF Version: 1.2 8/02/2017 4:16:10 PM > Product ID: PT02S151001001526 8/02/2017 4:16:10 PM > IMEI: 353626-07-428352-9 8/02/2017 4:16:10 PM > Target operator: GOOGLE 8/02/2017 4:16:10 PM > Hardware: 8/02/2017 4:16:10 PM > Reading partitions...8/02/2017 4:16:12 PM > OK 8/02/2017 4:16:12 PM > Resetting FRP Lock...8/02/2017 4:16:13 PM > OK 8/02/2017 4:16:13 PM > Resetting screen lock successfully completed! 8/02/2017 4:16:13 PM > Performed by 2.4.7 Software version. Code: Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: H790 Reading info...Failed! Could not detect mode! Performed by 2.4.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM127 Selected model: H790 Reading info... Model ID: LGH790 IMEI: 353626-07-428352-9 Android version: Battery level: 69% SW Version: LGH790AT-00-V10f-NXS-XXX-OCT-0 Mode: Emergency Initializing flash...OK SW version: LGH790AT-00-V10f-NXS-XXX-OCT-03-2015-32G-MDA89E-US Android version: 6.0 LAF Version: 1.2 Product ID: PT02S151001001526 IMEI: 353626-07-428352-9 Target operator: GOOGLE Hardware: Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "LGH790AT-00-V10f-NXS-XXX-OCT-03-2015-16G-MDA89E-US- TOT.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing pmic...OK Writing sbl1...OK Writing tz...OK Writing sdi...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing pmicbak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing sec...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing system...OK Reading partitions...OK Formating RCT...Failed! Formating MPT...Failed! Finalizing...OK Writing firmware done! Performed by 2.4.7 Software version. Code: Checking data...OK Platform: LG Qualcomm Selected port: COM127 Selected model: H790 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LGH790 IMEI: 353626-07-428352-9 Android version: Battery level: 69% SW Version: LGH790AT-00-V10f-NXS-XXX-OCT-0 Mode: Emergency Initializing flash...OK SW version: LGH790AT-00-V10f-NXS-XXX-OCT-03-2015-32G-MDA89E-US Android version: 6.0 LAF Version: 1.2 Product ID: PT02S151001001526 IMEI: 353626-07-428352-9 Target operator: GOOGLE Hardware: Reading partitions...OK Resetting FRP Lock...OK Resetting screen lock successfully completed! Performed by 2.4.7 Software version. Last edited by Octopus box; 02-08-2017 at 10:25. |
