02-20-2018, 20:42 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | M250F Wifi problem after FRP [Solved] Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: M250F Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM28 Mode: Emergency Initializing flash...OK Model ID: LG-M250F SW version: LGM250FAT-00-V10b-SCA-XXX-MAR-20-2017+0 LAF Version: 1.1 Product ID: VS04S170616000144 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Performed by 2.7.8 Software version. Last edited by Octopus box; 03-09-2018 at 21:45. |
02-21-2018, 08:07 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | Hello. Post here full Software log with "Reset FRP" operation, we will check. Also after performing "Reset FRP" operation, You should do "factory reset" from phone's menu. This is necessary to complete "Reset FRP" operation. |
02-21-2018, 14:30 | #3 (permalink) |
Member: 189984 Status: Offline Thanks Meter: 112 | 1/11/2018 7:25:21 PM > Checking data...1/11/2018 7:25:22 PM > OK 1/11/2018 7:25:22 PM > Platform: LG MTK 1/11/2018 7:25:22 PM > Selected port: COM1 1/11/2018 7:25:22 PM > Selected baudrate: 0 1/11/2018 7:25:22 PM > Selected model: M250F 1/11/2018 7:25:22 PM > Selected USB connection type 1/11/2018 7:25:23 PM > Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) 1/11/2018 7:25:23 PM > or 1/11/2018 7:25:23 PM > Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. 1/11/2018 7:26:31 PM > Phone found at port COM11 1/11/2018 7:26:36 PM > Mode: Emergency 1/11/2018 7:26:36 PM > Initializing flash...1/11/2018 7:26:38 PM > OK 1/11/2018 7:26:39 PM > Model ID: LG-M250F 1/11/2018 7:26:39 PM > SW version: LGM250FAT-00-V10b-SCA-XXX-MAR-20-2017+0 1/11/2018 7:26:39 PM > LAF Version: 1.1 1/11/2018 7:26:39 PM > Product ID: VS04S170616000144 1/11/2018 7:26:39 PM > IMEI: 1/11/2018 7:26:39 PM > Target operator: GLOBAL 1/11/2018 7:26:39 PM > Hardware: rev_10 1/11/2018 7:26:39 PM > Battery level: 50% 1/11/2018 7:26:39 PM > Reading partitions...1/11/2018 7:26:39 PM > OK 1/11/2018 7:26:41 PM > Checking security... 1/11/2018 7:26:41 PM > Checking security passed! 1/11/2018 7:26:41 PM > -------------------------------------------------------------------------------- 1/11/2018 7:26:41 PM > IMEI: 1/11/2018 7:26:41 PM > Bluetooth address: 88:36:5F:09:FC:A6 1/11/2018 7:26:41 PM > Wi-Fi MAC address: 04:1B:6D:F99:EF 1/11/2018 7:26:41 PM > SPC: 000000 1/11/2018 7:26:41 PM > -------------------------------------------------------------------------------- 1/11/2018 7:26:41 PM > Reset FRP operation for M250F will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? 1/11/2018 7:26:44 PM > Resetting FRP Lock... 1/11/2018 7:26:44 PM > Writing loader...1/11/2018 7:26:44 PM > OK 1/11/2018 7:26:44 PM > Writing userdata...1/11/2018 7:26:44 PM > OK 1/11/2018 7:26:44 PM > Formating encrypt...1/11/2018 7:26:48 PM > OK 1/11/2018 7:26:48 PM > Restoring loader...1/11/2018 7:26:48 PM > OK 1/11/2018 7:26:48 PM > Resetting FRP lock successfully completed! 1/11/2018 7:26:48 PM > Rebooting phone... 1/11/2018 7:26:50 PM > To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). 1/11/2018 7:26:50 PM > Performed by 2.7.8 Software version. |
02-21-2018, 14:43 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | Yes, do Factory Reset as this is written in Software log: Quote:
