10-09-2020, 19:27 | #17 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2357398 Status: Offline Thanks Meter: 0 | In this new update I tried to free a classic LG A270 and it does not connect to the LG A180a and it also does not connect to the COM port, just wait and there is no response from the UART port, I hope you are not forgetting the old models since some follow us coming for flash and imei repair |
10-10-2020, 08:21 | #18 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2756205 Status: Offline Sonork: family Thanks Meter: 1 | Hi octopus team . i am using octopus box lg tool after update can.t unlock lg l01e and more old model. tool hang on reading security area . and i can.t run old version . in old version coming this error . this card firmware version is unsupported please update your card and use the latest software version. help me |
10-13-2020, 21:30 | #19 (permalink) |
Banned Join Date: Mar 2019 Location: Gsm-Boss Age: 46
Member: 2902804 Status: Offline Sonork: 100.1660513 Thanks Meter: 928 | nice K71: - Q730BAW - added world’s first Direct Unlock, Repair IMEI, Reset FRP, Write Firmware, Factory Reset - Q730HA - added world’s first Direct Unlock, Repair IMEI, Reset FRP, Write Firmware, Factory Reset - Q730QN - added world’s first Direct Unlock, Repair IMEI, Reset FRP, Write Firmware, Factory Reset Note: Direct Unlock/ Reset FRP/ Repair IMEI are credit-based operations (you need Octoplus credits), please check Credits consumption 🐙 Improved smart card applet 🐙 Card update is required! 🐙 Improved server side (old software version will not work, use only actual software version) |
10-15-2020, 20:07 | #21 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: GT
Member: 44659 Status: Offline Thanks Meter: 363 | I already using latest version ... Quote:
The Following User Says Thank You to luzer For This Useful Post: |
10-15-2020, 21:46 | #23 (permalink) | ||
Member: 44659 Status: Offline Thanks Meter: 363 | Quote:
"Please update Software Version!" | ||
10-15-2020, 23:20 | #25 (permalink) | |
Member: 44659 Status: Offline Thanks Meter: 363 | ........................... Quote:
10-18-2020, 00:29 | #26 (permalink) |
Freak Poster Join Date: Jun 2016 Location: coahuila mexico
Member: 2591842 Status: Offline Sonork: 1674297 Thanks Meter: 39 | Welcome to Octoplus/Octopus Box LG Software version 3.0.5 Card S/N : 000000xxxx Selected USB connection type -------------------------------------------------------------------------------- Work ID: 1135788 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 921600 Selected model: Q730MM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM32 Mode: Emergency Initializing flash...OK Model ID: LM-Q730MM Platform: mt6765 Android version: 10 SW version: LMQ730MMAT-02-V10i-310-160-JUL-02-2020-ARB00 +0 LAF Version: 1.1 Product ID: LS03S200815000123 IMEI: 352769-72-014336-5 Target operator: LAO Hardware: rev_11 Battery level: 5% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 352769-72-014xxxxx5 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "Q730MM_3527697201xxxxx_17-10-2020_16- 24-13.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: romero2015natal Authorizing...OK Checking balance...OK Checking operation...Failed! Please update Software Version! Performed by 3.0.5 Software version. i have problem unlocking STYLO 6 METRO PCS, I TRYED TO REINSTALL SOFTWARE, UPDATE CARD AND STILL GET THE SAME MESSAGE. IVE UNINSTALLED THE WHOLE SOFTWARE AND TRY WITH NO LUCK |
