Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 10-01-2020, 10:11   #1 (permalink)
Gsmserver's Avatar
Member: 21077
Thanks Meter: 107,579
Post 🐙 Octoplus/Octopus Box LG Software 3.0.5 is out! 🐙
Octoplus/Octopus Box LG Software version 3.0.5 is out!
Octoplus/Octopus Box LG Software v.3.0.5 Release Notes:
🐙 K71:
- Q730BAW - added world’s first Direct Unlock, Repair IMEI, Reset FRP, Write Firmware, Factory Reset
- Q730HA - added world’s first Direct Unlock, Repair IMEI, Reset FRP, Write Firmware, Factory Reset
- Q730QN - added world’s first Direct Unlock, Repair IMEI, Reset FRP, Write Firmware, Factory Reset
Note: Direct Unlock/ Reset FRP/ Repair IMEI are credit-based operations (you need Octoplus credits), please check Credits consumption
Improved smart card applet
🐙 Card update is required!
🐙 Improved server side (old software version will not work, use only actual software version)
Download Octoplus/Octopus Box LG v.3.0.5
Find out more at: www.octoplusbox.com
The Following 23 Users Say Thank You to Gsmserver For This Useful Post:
Old 10-01-2020, 10:19   #2 (permalink)
Member: 2171001
Thanks Meter: 101
good update....always number 1 in LG
Old 10-01-2020, 10:19   #3 (permalink)
Member: 2171001
Thanks Meter: 101
Old 10-01-2020, 10:33   #4 (permalink)
Member: 5926
Thanks Meter: 273
updating card firmware success, but software says card needs update.
Same with FRPtool module
Searching for server...
Server greeting: "Card updates server v.2.2"
Searching installed cards...
Found card with s/n 000xxxxx
Selected card: 00000xxxxx
Updates count: 40
Updates limit: 42
Activations:
 - LG - FULL (ver 2.6)
 - Samsung - FULL (ver 2.6)
 - Medusa - NO
 - Huawei - NO
 - FRP - FULL (ver 2.6)
Creating secure connection...
Requesting firmware...
Writing card firmware...
Card firmware successfully updated!
Old 10-01-2020, 10:40   #5 (permalink)
gunit1's Avatar
Member: 2041210
Thanks Meter: 514
i have same probleme after download last version and update smart card pls help we ...
Old 10-01-2020, 10:42   #6 (permalink)
Member: 2771307
Thanks Meter: 545
I got same problem after card update still newest software not work still ask for update and go on without end.
Old 10-01-2020, 10:43   #7 (permalink)
Member: 5926
Thanks Meter: 273
server reports v2.2, on card v2.6,
I presume on server side something is wrong
Old 10-01-2020, 10:48   #8 (permalink)
umerkhalid1992's Avatar
Member: 2696842
Sonork: 100.1683002
Thanks Meter: 224
Lm-850em frp supported i cant see models
Old 10-01-2020, 11:39   #9 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 25,788
We're sorry for inconviences.There was a problem with new update, please re-download latest Software version from the Octoplus , then install it and everything should work properly
Besides, You can download latest Octoplus LG Tool 3.0.5
Old 10-01-2020, 11:40   #10 (permalink)
Member: 1575111
Sonork: chris259
Thanks Meter: 33
guys fix that mess please i cant find from where to download the 3.0.5 lg and lots of people having problems updating there cards
The Following User Says Thank You to chris259 For This Useful Post:
Old 10-01-2020, 11:41   #11 (permalink)
Member: 1146942
Sonork: 100.1587278
Old 10-01-2020, 13:24   #12 (permalink)
zeeshan ali 786's Avatar
Member: 2711874
Sonork: 100.650600
Thanks Meter: 435
Good update Octoplus Team.... Thanks ❤️
The Following User Says Thank You to zeeshan ali 786 For This Useful Post:
Old 10-01-2020, 13:26   #13 (permalink)
Malik Shani G's Avatar
Member: 2963610
Thanks Meter: 408
Good work Team..........
The Following User Says Thank You to Malik Shani G For This Useful Post:
Old 10-02-2020, 16:21   #14 (permalink)
Member: 2117710
Thanks Meter: 59
Q730QN unlock successfully
lg stylo 6 successfully unlocked
Welcome to Octoplus/Octopus Box LG Software version 3.0.5
Card S/N : 00000xxxxx
Selected USB connection type
Work ID: 262228
Checking data...OK
Platform: LG MTK
Selected port: COM912
Selected baudrate: 921600
Selected model: Q730QN
Please, disconnect cable, power phone OFF, connect P999 cable
(with 910k resistor)
or
Power OFF phone, press and hold "Vol+" for 10 seconds and
connect USB cable.
Phone found at port COM1577
Mode: Emergency
Initializing flash...OK
Model ID: LM-Q730QN
Platform: mt6765
Android version: 10
SW version: LMQ730QNAT-01-V10a-330-110-JUL-15-2020+1
LAF Version: 1.1
Product ID: VH01S200805000596
IMEI: 356351xxxxxxx
Target operator: LAO
Hardware: rev_11
Battery level: 13%
Reading partitions...OK
LAF Error: 80000119.
Checking security...OK
IMEI: 356351xxxxxxx
Bluetooth address: Unknown
Wi-Fi MAC address: Unknown
Write security backup function doesn't work for this device with
latest firmware versions. If you'll encounter any problem during
Unlock operation - you won't be able to restore the phone to it's
initial state, so proceed at your own risk.
Continue?
Creating EEPROM backup...OK
Reading security area...
Backup saved to "Q730QN_356351xxxxxxx_02-10-2020_10-
06-15.EEP"
Connecting to server...OK
Octopus smart card is present.
Checking smart card...OK
Username: mlyzgui
Authorizing...OK
Checking balance...OK
Checking operation...OK
Sending device information...OK
Get credits, needed for current operation...OK
Your balance: 102 credits.
To perform "Unlock" operation you need to have 100 credits.
Unlocking...OK
Writing security area...
Writing security area...OK
Prepairing for change protect status...
Removing write protection...OK
Erasing part 1...OK
Erasing part 2...OK
Restore write protection...OK
Phone successfully unlocked!
Warning: If your device were stuck at logo, after operation was
completed, then please, don't reflash your device, first contact with
Support via Skype or create thread at forum!
Performed by 3.0.5 Software version.
The Following 2 Users Say Thank You to sbtech For This Useful Post:
Old 10-05-2020, 06:17   #15 (permalink)
Member: 2312966
Thanks Meter: 6
Can't use old method of FRP on phones. Old version has frp remove method for LG G6, X6 etc some models now asking for credits. Fix this ASAP pls. I can remove LG G6 frp on android 9 with download mode free before, now i can't cuz tool asks for credit lol.
The Following User Says Thank You to Bayasal For This Useful Post:
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.20925 seconds with 8 queries
