🐙 Octoplus/Octopus Box LG v.2.6.8 - Reset FRP for Android 7.0 - Exclusive! 🐙 https://www.gsmserver.com/nfs/conten...le/774x400.jpg Octoplus/Octopus Box LG v.2.6.8 - exclusive "Reset FRP" for Android 7.x firmwares!Exclusive! Added world's first "Reset FRP" for Android 7.x firmwares! Octoplus/Octopus Box LG Software v.2.6.8 Release Notes: 🐙 Added world's first "Reset FRP"* operation for the following models with Android 7.x firmwares: - M200N, M200E,You can also perform "Reset FRP" operation for other, not listed above models with Android 7.x firmwares and post the result for all Octoplus users. * Note: "Reset FRP" operation will delete all user data on the phone (contacts, pictures and others)! 🐙 Added support for the following models: - M154 - added Direct Unlock, Repair IMEI, Reset FRP, Write Firmware, Read/Write NVM, Read/Write QCN, Read/Write/Reset Security, Read Full Flash, Repair BT/Wi-Fi MAC Address (thanks to mr. Jay da). 🐙 Improved "Reset FRP" for the following models: - K530, K530AR, K530DY, K530F, K530T 🐙 Improved "Write Firmware" operation for K410x series. 🐙 All supported operations are described in details in the manual ("Cable & Manual" button in the software) Download Octoplus/Octopus Box LG v.2.6.8 http://gsmserver.com/nfs/mail-templa...am_channel.pngFind out more at: www.octoplusbox.com http://gsmserver.com/nfs/content/614...lus_follow.pnghttp://gsmserver.com/nfs/content/614...s_facebook.pnghttp://gsmserver.com/nfs/content/614...us_twitter.pnghttp://gsmserver.com/nfs/content/614...us_youtube.pnghttp://gsmserver.com/nfs/content/614...lus_g_plus.pnghttp://gsmserver.com/nfs/content/6149/file/plus_rss.pnghttp://gsmserver.com/nfs/content/6149/file/plus_dis.pnghttp://gsmserver.com/nfs/content/614.../plus_mail.pnghttp://gsmserver.com/nfs/content/614...ttom_right.png |
Nexux 5x test Welcome to Octoplus/Octopus Box LG Software version 2.6.8 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM30 Selected model: H791 Reading info... IMEI: 353627-07-335490-7 Android version: Battery level: 4% SW Version: LGH791AT-00-V10f-NXS-XXX-OCT-0 Mode: Emergency Initializing flash...OK SW version: LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-16G-MDA89E-US Android version: 6.0 LAF Version: 1.2 Product ID: HD54S151021001190 IMEI: 353627-07-335490-7 Target operator: GOOGLE Hardware: Performed by 2.6.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM30 Selected model: H791 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... IMEI: 353627-07-335490-7 Android version: Battery level: 4% SW Version: LGH791AT-00-V10f-NXS-XXX-OCT-0 Mode: Emergency Initializing flash...OK SW version: LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-16G-MDA89E-US Android version: 6.0 LAF Version: 1.2 Product ID: HD54S151021001190 IMEI: 353627-07-335490-7 Target operator: GOOGLE Hardware: After performing Reset FRP operation the phone may stuck on logo. To fix this problem You shall reflash the phone with the latest firmare. Perform Reset FRP operation at your own risk. Continue? Reading partitions...OK Resetting FRP Lock...OK Resetting FRP lock successfully completed! Performed by 2.6.8 Software version. |
MS210 FRP Remove Done!! Welcome to Octoplus/Octopus Box LG Software version 2.6.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM345 Selected model: MS210 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LGMS210 IMEI: 353662-08-xxxxxxx Android version: 7.0 Battery level: 31% SW Version: MS21010h Mode: Emergency Initializing flash...OK SW version: LGMS210AT-02-V10h-310-160-MAR-16-2017-ARB00+1 Android version: 7.0 LAF Version: 1.1 Product ID: CD26S170122002801 IMEI: 353662-08-xxxxxx Target operator: MPCS Hardware: rev_10 Reset FRP operation for MS210 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock... Writing loader...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.6.8 Software version. Thanks! |
K20 plus Tmobile (TP260) RFP Remove Done! Checking data...OK Platform: LG Qualcomm Selected port: COM1246 Selected model: MS210 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-TP260 Incompatible model ID! IMEI: 355265-08-xxxxx Android version: 7.0 Battery level: 6% SW Version: TP26010k Mode: Emergency Initializing flash...OK SW version: LGTP260AT-01-V10k-310-260-MAR-16-2017-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CY20S170327000291 IMEI: 355265-08-xxxxx Target operator: TMO Hardware: rev_10 Reset FRP operation for MS210 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock... Writing loader...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.6.8 Software version. Thanks!! |
Good Update Team.. You Are Tooo Good.. Keep It Up.. :):) |
Checking data...6/9/2017 2:31:49 PM > OK 6/9/2017 2:31:49 PM > Platform: LG MTK 6/9/2017 2:31:49 PM > Selected port: COM66 6/9/2017 2:31:49 PM > Selected baudrate: 0 6/9/2017 2:31:49 PM > Selected model: M400Y 6/9/2017 2:31:49 PM > Selected USB connection type 6/9/2017 2:31:50 PM > Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) 6/9/2017 2:31:50 PM > or 6/9/2017 2:31:50 PM > Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. 6/9/2017 2:32:18 PM > Phone found at port COM66 6/9/2017 2:32:34 PM > Mode: Emergency 6/9/2017 2:32:34 PM > Initializing flash...6/9/2017 2:32:36 PM > OK 6/9/2017 2:32:37 PM > Model ID: LG-M400Y 6/9/2017 2:32:37 PM > SW version: LGM400YAT-00-V10a-ZAF-XX-FEB-20-2017+0 6/9/2017 2:32:37 PM > LAF Version: 1.1 6/9/2017 2:32:37 PM > Product ID: CD21S170403001770 6/9/2017 2:32:37 PM > IMEI: 6/9/2017 2:32:37 PM > Target operator: GLOBAL 6/9/2017 2:32:37 PM > Hardware: rev_10 6/9/2017 2:32:37 PM > Battery level: 50% 6/9/2017 2:32:37 PM > Reading partitions...6/9/2017 2:32:37 PM > OK 6/9/2017 2:32:39 PM > Checking security... 6/9/2017 2:32:40 PM > Checking security passed! 6/9/2017 2:32:40 PM > -------------------------------------------------------------------------------- 6/9/2017 2:32:40 PM > IMEI: 355959xxxxxxxxxxx 6/9/2017 2:32:40 PM > Bluetooth address: A8:B8:6E:DE:00:A9 6/9/2017 2:32:40 PM > Wi-Fi MAC address: A8:B8:6E:38:92:62 6/9/2017 2:32:40 PM > SPC: 000000 6/9/2017 2:32:40 PM > -------------------------------------------------------------------------------- 6/9/2017 2:32:40 PM > Reset FRP operation for M400Y will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? 6/9/2017 2:32:42 PM > Resetting FRP Lock... 6/9/2017 2:32:42 PM > Writing loader...6/9/2017 2:32:42 PM > OK 6/9/2017 2:32:42 PM > Writing userdata...6/9/2017 2:32:42 PM > OK 6/9/2017 2:32:42 PM > Formating encrypt...6/9/2017 2:32:46 PM > OK 6/9/2017 2:32:46 PM > Restoring loader...6/9/2017 2:32:46 PM > OK 6/9/2017 2:32:46 PM > Resetting FRP lock successfully completed! 6/9/2017 2:32:46 PM > Rebooting phone... 6/9/2017 2:32:48 PM > To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). 6/9/2017 2:32:48 PM > Performed by 2.6.8 Software version |
m250f not done Welcome to Octoplus/Octopus Box LG Software version 2.6.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: MS210 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M250F Incompatible model ID! Canceled! Performed by 2.6.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM41 Selected baudrate: 0 Selected model: M250F Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM41 Mode: Emergency Initializing flash...OK Model ID: LG-M250F SW version: LGM250FAT-00-V10a-GLOBAL-SCA-JAN-19-2017+0 LAF Version: 1.1 Product ID: CY17S170420001048 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 354953-08-990114-6 Bluetooth address: 04:1B:6D:10:9C:D1 Wi-Fi MAC address: A8:B8:6E:61:BB:C9 SPC: 000000 -------------------------------------------------------------------------------- Reset FRP operation for M250F will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Writing loader...Failed! Error code: A09ASDSDAX Performed by 2.6.8 Software version. |
@cdmagsm03 Unfortunately, Reset FRP operation is not supported on V10a firmware version. Please, try to reflash your device with higher firmware version, then repeat reset FRP operation. |
Thank´s for this update Team Octopus,but dont forget update for Repair Network on MS345 and H345(LG Leon Serie´s),because in my country this cell have this problem. |
Checking data...6/9/2017 4:23:40 PM > OK 6/9/2017 4:23:41 PM > Platform: LG MTK 6/9/2017 4:23:41 PM > Selected port: COM66 6/9/2017 4:23:41 PM > Selected baudrate: 0 6/9/2017 4:23:41 PM > Selected model: M250Y 6/9/2017 4:23:41 PM > Selected USB connection type 6/9/2017 4:23:41 PM > Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) 6/9/2017 4:23:41 PM > or 6/9/2017 4:23:41 PM > Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. 6/9/2017 4:23:53 PM > Phone found at port COM66 6/9/2017 4:24:09 PM > Mode: Emergency 6/9/2017 4:24:09 PM > Initializing flash...6/9/2017 4:24:11 PM > OK 6/9/2017 4:24:12 PM > Model ID: LG-M250Y 6/9/2017 4:24:12 PM > SW version: LGM250YAT-00-V10a-ZAF-XX-JAN-20-2017+0 6/9/2017 4:24:12 PM > LAF Version: 1.1 6/9/2017 4:24:12 PM > Product ID: CY19S170218000739 6/9/2017 4:24:12 PM > IMEI: 6/9/2017 4:24:12 PM > Target operator: GLOBAL 6/9/2017 4:24:12 PM > Hardware: rev_10 6/9/2017 4:24:12 PM > Battery level: 50% 6/9/2017 4:24:12 PM > Reading partitions...6/9/2017 4:24:12 PM > OK 6/9/2017 4:24:14 PM > Checking security... 6/9/2017 4:24:15 PM > Checking security passed! 6/9/2017 4:24:15 PM > -------------------------------------------------------------------------------- 6/9/2017 4:24:15 PM > IMEI: 354xxxxxxxxxx 6/9/2017 4:24:15 PM > Bluetooth address: B8:1D:AA:5A:3B:DC 6/9/2017 4:24:15 PM > Wi-Fi MAC address: B8:1D:AA:C3:43:7F 6/9/2017 4:24:15 PM > SPC: 000000 6/9/2017 4:24:15 PM > -------------------------------------------------------------------------------- 6/9/2017 4:24:15 PM > Reset FRP operation for M250Y will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? 6/9/2017 4:24:17 PM > Resetting FRP Lock... 6/9/2017 4:24:17 PM > Writing loader...6/9/2017 4:24:17 PM > Failed! 6/9/2017 4:24:17 PM > Error code: A09ASDSDAX 6/9/2017 4:24:17 PM > Performed by 2.6.8 Software version. |
Please read 2 posts above. |
Wow OCTOPUS BOX RULES THE LG PHONES ! Nice Update;) |
gracias equipo excelente trabajo siempre a la vanguardia con las actualizaciones |
after flash ................... Welcome to Octoplus/Octopus Box LG Software version 2.6.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM7 Selected baudrate: 921600 Selected model: M250Y Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM66 Mode: Emergency Initializing flash...OK Model ID: LG-M250Y SW version: LGM250YAT-00-V10a-ZAF-XX-JAN-20-2017+0 LAF Version: 1.1 Product ID: CY19S170218000739 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 354xxxxxxxxxxxx Bluetooth address: B8:1D:AA:5A:3B:DC Wi-Fi MAC address: B8:1D:AA:C3:43:7F SPC: 000000 -------------------------------------------------------------------------------- Opening "M250Y10b_00_OPEN_TR_OP_0308.kdz"...OK Firmware version: LGM250AT-00-V10w-GLOBAL-COM-MAR-08-2017+0 Firmware model: LG-M250 Sending signature...OK Prepairing firmware...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/62 preloader_0.bin...OK Writing 2/62 pgpt_0.bin...OK Writing 3/62 lk_98304.bin...OK Writing 4/62 lk2_100352.bin...OK Writing 5/62 laf_102400.bin...OK Writing 6/62 boot_160768.bin...OK Writing 7/62 recovery_196608.bin...OK Writing 8/62 logo_274432.bin...OK Writing 9/62 secro_360448.bin...OK Writing 10/62 tee1_393216.bin...OK Writing 11/62 tee2_403456.bin...OK Writing 12/62 rct_507904.bin...OK Writing 13/62 factory_509952.bin...OK Writing 14/62 efuse_624640.bin...OK Writing 15/62 md1img_884736.bin...OK Writing 16/62 md1dsp_933888.bin...OK Writing 17/62 md1arm7_942080.bin...OK Writing 18/62 md3img_948224.bin...OK Writing 19/62 cust_958464.bin...OK Writing 20/62 system_1179648.bin...OK Writing 21/62 system_1442816.bin...OK Writing 22/62 system_1446912.bin...OK Writing 23/62 system_1707008.bin...OK Writing 24/62 system_1967104.bin...OK Writing 25/62 system_1971200.bin...OK Writing 26/62 system_2231296.bin...OK Writing 27/62 system_2491392.bin...OK Writing 28/62 system_2495488.bin...OK Writing 29/62 system_2755584.bin...OK Writing 30/62 system_3014656.bin...OK Writing 31/62 system_3015680.bin...OK Writing 32/62 system_3019776.bin...OK Writing 33/62 system_3279872.bin...OK Writing 34/62 system_3539968.bin...OK Writing 35/62 system_3544064.bin...OK Writing 36/62 system_3804160.bin...OK Writing 37/62 system_4063232.bin...OK Writing 38/62 system_4066304.bin...OK Writing 39/62 system_4328448.bin...OK Writing 40/62 system_4590592.bin...OK Writing 41/62 system_4852736.bin...OK Writing 42/62 system_5114880.bin...OK Writing 43/62 system_5377024.bin...OK Writing 44/62 system_5639168.bin...OK Writing 45/62 system_5901312.bin...OK Writing 46/62 system_6163456.bin...OK Writing 47/62 system_6425600.bin...OK Writing 48/62 system_6687744.bin...OK Writing 49/62 system_6949888.bin...OK Writing 50/62 system_7212032.bin...OK Writing 51/62 system_7474176.bin...OK Writing 52/62 system_7733248.bin...OK Writing 53/62 system_7734272.bin...OK Writing 54/62 system_7738368.bin...OK Writing 55/62 system_8257536.bin...OK Writing 56/62 system_8258560.bin...OK Writing 57/62 system_8262656.bin...OK Writing 58/62 system_8781824.bin...OK Writing 59/62 system_9043968.bin...OK Writing 60/62 system_9047040.bin...OK Writing 62/62 0_OP_OPEN_TR.img...OK Formating RCT...OK Finalizing...OK Performed by 2.6.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM7 Selected baudrate: 0 Selected model: M250Y Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM66 Mode: Emergency Initializing flash...OK Model ID: LG-M250Y SW version: LGM250YAT-00-V10b-ZAF-XX-MAR-08-2017+0 LAF Version: 1.1 Product ID: CY19S170218000739 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 35494xxxxxxxxxx Bluetooth address: B8:1D:AA:5A:3B:DC Wi-Fi MAC address: B8:1D:AA:C3:43:7F SPC: 000000 -------------------------------------------------------------------------------- Reset FRP operation for M250Y will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Writing loader...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.6.8 Software version. |
https://mega.nz/#!VaByiSab!zC6dawLwW...925NzC7xDoJ_A8 SERVER VERY SLOW FOR THE MOMENT.. LATEST LG OCTOPUS |
