Member: 21077
Thanks Meter: 108,095 | 🐙 Octoplus/Octopus Box LG v.2.8.8 is out! 🐙  Octoplus/Octopus Box LG Software version 2.8.8 is out! New models added! Octoplus/Octopus Box LG Software v.2.8.8 Release Notes: 🐙 Added support for the following models: - AS992 - added Write Firmware, Repair IMEI, Repair BT/Wi-Fi MAC Address, Repair MEID, Read/Write PRL, Repair AKEY/SSD_A/SSD_B/OTKSL/SPC, Read/Reset Security, Read/Write QCN, Read/Write NVM, Reset FRP, Read Full Flash (thanks to Mr. Ismail khan1978)
- LMX212TA - added Direct Unlock (via server), Repair IMEI, Reset FRP, Read/Write Security, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash (thanks to Mr. mobilaemmanuel)
- LMX212TAL - added Direct Unlock (via server), Repair IMEI, Reset FRP, Read/Write Security, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash
- LMX210YMW - added Unlock, Read/Write/Reset Security, Repair IMEI (A/B), Reset FRP, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash
- US998U (V30+) - added Repair IMEI/MEID, Repair BT/Wi-Fi Mac Address, Repair AKEY/SSDA/SSDB/OTKSL/SPC, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Write Firmware, Read Full Flash
- US998R (V30S ThinQ) - added Repair IMEI/MEID, Repair BT/Wi-Fi Mac Address, Repair AKEY/SSDA/SSDB/OTKSL/SPC, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Reset Security, Write Firmware, Read Full Flash
- V300KR (V30S ThinQ) - added Direct Unlock, Repair IMEI, Reset FRP, Read/Reset Security, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash
- V300KW (V30S+ ThinQ) - added Direct Unlock, Repair IMEI, Reset FRP, Read/Reset Security, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash
- V300LW (V30S+ ThinQ) - added Direct Unlock, Repair IMEI, Reset FRP, Read/Reset Security, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash
- V300SW (V30S+ ThinQ) - added Direct Unlock, Repair IMEI, Reset FRP, Read/Reset Security, Read/Write QCN, Read/Write NVM, Write Firmware, Read Full Flash
- D850, D850PR - added Factory Reset (for reset status 2, 3)
- D851, D851TN, D851WH - added Factory Reset (for reset status 2, 3)
- D852, D852G - added Factory Reset (for reset status 2, 3) 🐙 Added Reset FRP for Android 8.x firmwares* w/o Test Point for the next devices:
- H930, H930DS, H930G, H930K
- AS998
- LS998 (thanks to Mr. maxpatri9)
- US998
- VS996
- V300K, V300L, V300S
- H870, H870K, H870S, H870V, H870DS, H870AR, H870I
- H873
- G600K, G600L, G600S, G600KP, G600LP, G600SP, G600KR, G600LR, G600SR
- AS993
- LS993
- VS988 *Note: Operation may not work for some Android 8.x firmwares. In this case you can perform “Reset FRP” operation via Test Point. 🐙 “Write Firmware” operation improved for most devices - from now on up to 40% faster! 🐙 Improved “Reset FRP” operation for SP200, SP320, US601, X210ULMA. 🐙 All supported operations are described in details in Software manual ("Cable & Manual" button in Software) Download Octoplus/Octopus Box LG v.2.8.8
Find out more at: www.octoplusbox.com
