01-13-2017, 08:18 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hi. Unfortunately, Write Firmware is currently not supported for this phone mode and we have no firmware for it. What is the problem with your phone? Why do you want to re-flash it? You can try to write uploaded here full flash (http://forum.gsmhosting.com/vbb/f799...olved-1906846/. ) at your own risk. |
01-13-2017, 17:40 | #3 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: Ethiopia
Member: 449991 Status: Offline Thanks Meter: 933 | Quote:
thank u Octopus box after full flash problem solved security code also removed even if error on final stage Welcome to Octoplus/Octopus Box LG Software version 2.5.4 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM94 Selected baudrate: 115200 Selected model: T585 Selected USB connection type Please, disconnect battery and connect cable...OK Phone found. Setting power state...OK Sending loader...OK Synchronizing with loader...OK Detecting NOR flash chip...OK Detecting NAND flash chip...OK Reading info...OK Checking security...OK -------------------------------------------------------------------------------- IMEI A: 350305-26-000000-1 IMEI B: 350305-26-000000-1 Bluetooth address: 00:05:C9:00:00:00 Wi-Fi MAC address: 00:00:00:00:00:00 NAND flash chip: Micron NAND size: 256 Mb NAND page size: 2048 b NAND spare size: 64 b NAND pages per block: 64 -------------------------------------------------------------------------------- Opening "T585_357979054086610_25-07-2014_10-26-47.ful"...OK Writing Full flash... Error code: BE4 Block #07FFOK Performed by 2.5.4 Software version. | |
The Following User Says Thank You to dereje For This Useful Post: |
