06-05-2020, 20:47 | #1 (permalink) |
Junior Member Join Date: Jun 2019 Location: Chile
Member: 2912652 Status: Offline Thanks Meter: 1 | LG Q60 X525HA imei not repaired [Solved] Welcome to Octoplus/Octopus Box LG Software version 3.0.2.02 Card S/N : 0000008F0E -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM110 Selected baudrate: 921600 Selected model: X525HA Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM111 Mode: Emergency Initializing flash...OK Model ID: LM-X525HA Platform: mt6765 Android version: 9 SW version: LMX525HAAT-00-V10c-SCA-XXX-SEP-18-2019+0 LAF Version: 1.1 Product ID: 971EAN67BJ6P02BW7 IMEI: 355498-10-132584-0 Target operator: LAO Hardware: rev_10 Battery level: 43% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 355498-10-132584-0 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: yw6zlyc Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 350 credits. To perform "Repair IMEI" operation you need to have 100 credits. Fixing IMEI... New IMEI A: 353109-08-217408-9 Patching security... Writing security area... Reconnecting phone... Phone found at port COM111 Mode: Emergency Initializing flash...OK Prepairing for change protect status... Reconnecting phone... Phone found at port COM111 Mode: Emergency Initializing flash...OK Removing write protection...OK Reconnecting phone... Phone found at port COM111 Mode: Emergency Initializing flash...OK Reading partitions...OK Erasing part 1...OK Reconnecting phone... Phone found at port COM111 Mode: Emergency Initializing flash...Failed! Reconnecting phone... Please, perform the following steps: 1. Press and hold "Vol-", "Vol+" and "Power" buttons. 2. When the image disappears, release "Vol-" and "Power" buttons. 3. Hold "Vol+" until phone enter in Download mode, then press "OK" button. Phone found at port COM111 Mode: Emergency Initializing flash...OK Prepairing for change protect status... Reconnecting phone... Phone found at port COM111 Mode: Emergency Initializing flash...OK Restore write protection...OK Reconnecting phone... Phone found at port COM111 Mode: Emergency Initializing flash...OK Reading partitions...OK IMEI successfully fixed! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.2.02 Software version. |
06-06-2020, 08:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Hello. We've added You one more attempt, please download and install Octoplus LG tool 3.0.2.3 version from Support Area and repeat operation again |
