11-18-2020, 20:03 | #1 (permalink) |
Major Poster Join Date: Apr 2017
Member: 2704016 Status: Offline Thanks Meter: 9 | STYLO 6 Unlock question [Answered] second time it unlocked but credits charged again please refund 100 credits user:virtualvlep thanks in advance -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000000228AEF Checking data...OK Platform: LG MTK Selected port: Selected baudrate: 921600 Selected model: Q730MM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM261 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Android version: 10 SW version: LMQ730TM3AT-00-V10i-310-120-JUL-02-2020-ARB00+0 LAF Version: 1.1 Product ID: VP01S200710004262 IMEI: 354527-11-182372-4 Target operator: LAO Hardware: rev_11 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354527-11-182372-4 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "Q730MM_354527111823724_18-11-2020_12-41-25.EEP" Connecting to server...OK Octopus smart card is not present. Checking Activations...OK Username: virtualvlep Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 602 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Reading partitions...OK Prepairing for change protect status...Failed! Could not detect mode. Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.6.02 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000000228F8C Checking data...OK Platform: LG MTK Selected port: Selected baudrate: 921600 Selected model: Q730MM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM604 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Android version: 10 SW version: LMQ730TM3AT-00-V10i-310-120-JUL-02-2020-ARB00+0 LAF Version: 1.1 Product ID: VP01S200710004262 IMEI: 354527-11-182372-4 Target operator: LAO Hardware: rev_11 Battery level: 97% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354527-11-182372-4 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "Q730MM_354527111823724_18-11-2020_12-58-06.EEP" Connecting to server...OK Octopus smart card is not present. Checking Activations...OK Username: virtualvlep Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 502 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Reading partitions...OK Prepairing for change protect status... Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.6.02 Software version. |
01-06-2021, 08:39 | #3 (permalink) |
Junior Member Join Date: Mar 2005 Age: 44
Member: 125062 Status: Offline Thanks Meter: 7 | stylo 6 q730mm unlock error??? Welcome to Octoplus/Octopus Box LG Software version 3.0.8 Card S/N : 000001B22C -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000005FDC57 Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 921600 Selected model: Q730MM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM49 Mode: Emergency Initializing flash...OK Model ID: LM-Q730MM Platform: mt6765 Android version: 10 SW version: LMQ730MMAT-02-V10l-310-160-SEP-08-2020-ARB00 +0 LAF Version: 1.1 Product ID: VP01S201017001928 IMEI: 354525-11-778484-1 Target operator: LAO Hardware: rev_11 Battery level: 29% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354525-11-778484-1 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OKCanceled!Failed! Performed by 3.0.8 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000005FDD74 Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 921600 Selected model: K500MM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM49 Mode: Emergency Initializing flash...OK Model ID: LM-K500MM Platform: mt6765 Android version: 10 SW version: LMK500MMAT-02-V10l-310-160-NOV-21-2020-ARB00 +0 LAF Version: 1.1 Product ID: VP01S201005001021 IMEI: 354544-11-649496-3 Target operator: LAO Hardware: rev_10 Battery level: 75% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354544-11-649496-3 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OKFailed! Could not detect mode.Failed! Performed by 3.0.8 Software version. |
