01-19-2024, 13:46 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | lg x230i flashing error [Answered] i deside to flash but its giveing error i already select diffrent mode but same Code: Welcome to Octoplus/Octopus Box LG Software version 3.2.3.02 Card S/N : 000203706B Connecting to server ...OK Authorizing...OK -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000001E765F8 Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: X230I Press and hold "Vol-" and connect cable.OK Phone found. CPU name: MT6737M CPU revision: 8A00.CA00.0000.0000 Prepairing loader...OK Sending loader...OK Synchronizing with loader... Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Reading partitions...Failed! Error code: PQLNVCFREW Opening "LGX230AT-00-V10b-CIS-XX-MAR-07-2017+0.oct"... Writing Firmware... Reading partitions...Failed! Error code: PQLNVCFREW Performed by 3.2.3.02 Software version. Processing scatter file... platform: MT6735 Added pgpt.bin. Added proinfo.bin. Added misc2.bin. Added nvram.bin. Added protect1.bin. Added protect2.bin. Added lk.bin. Added para.bin. Added boot.bin. Added recovery.bin. Added logo.bin. Added mpt.bin. Added expdb.bin. Added seccfg.bin. Added oemkeystore.bin. Added secro.bin. Added keystore.bin. Added tee1.bin. Added tee2.bin. Added lk2.bin. Added persist.bin. Added frp.bin. Added nvdata.bin. Added metadata.bin. Added ecid.bin. Added system.bin. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000018E4A4E Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: X230I Press and hold "Vol-" and connect cable.OK Phone found. CPU name: MT6737M CPU revision: 8A00.CA00.0000.0000 Prepairing loader...OK Sending loader...OK Synchronizing with loader... Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Reading partitions...Failed! Error code: PQLNVCFREW Opening "LGX230AT-00-V10b-CIS-XX-MAR-07-2017+0.oct"... Writing Firmware... Reading partitions...Failed! Error code: PQLNVCFREW Performed by 3.2.3.02 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000001E76748 Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: X230Z Press and hold "Vol-" and connect cable.OK Phone found. CPU name: MT6737M CPU revision: 8A00.CA00.0000.0000 Prepairing loader...OK Sending loader...OK Synchronizing with loader... Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Reading partitions...Failed! Error code: PQLNVCFREW Opening "LGX230AT-00-V10b-CIS-XX-MAR-07-2017+0.oct"... Writing Firmware... Reading partitions...Failed! Error code: PQLNVCFREW Performed by 3.2.3.02 Software version. |
01-19-2024, 15:18 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Unfortunately, due to the fact that the phone is now a brick, you will not be able to flash it and you will not restore it to a normal state. You can try to restore it with a Medusa software if you have it. |
01-19-2024, 16:07 | #3 (permalink) | |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
BTW - its flashing with other tool,but not getting on before preloder was erase now preloader alive and can flash with other tool but nothing help do you have any idea or if ou have scattor file? | |
