10-19-2018, 15:45 | #5671 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | VS995 Reset FRP successfully done Welcome to Octoplus/Octopus Box LG Software version 2.8.9 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM81 Selected model: VS995 Reading info... Model ID: VS995 IMEI: 000000-00-000000-0 Android version: 7.0 Battery level: 71% SW Version: VS99512A Mode: Emergency Initializing flash...OK Platform: msm8996 SW version: VS99518A_00 Android version: 7.0 LAF Version: 1.1 Product ID: PT03S161129003714 IMEI: 359968-07-165399-7 Target operator: VZW Hardware: rev_10 Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM81 Selected model: VS995 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: VS995 IMEI: 000000-00-000000-0 Android version: 7.0 Battery level: 71% SW Version: VS99512A Mode: Emergency Initializing flash...OK Platform: msm8996 SW version: VS99518A_00 Android version: 7.0 LAF Version: 1.1 Product ID: PT03S161129003714 IMEI: 359968-07-165399-7 Target operator: VZW Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Detecting writing method... Trying third method...OK Formating FRP partition...OK Checking data... Resetting FRP lock successfully completed! Performed by 2.8.9 Software version. Last edited by Octopus box; 10-20-2018 at 09:10. |
The Following User Says Thank You to chipscell25 For This Useful Post: |
10-20-2018, 05:18 | #5672 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | M154 remove FRP successfully done Welcome to Octoplus/Octopus Box LG Software version 2.8.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM101 Selected model: M154 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M154 IMEI: 355171-08-291768-3 Android version: 6.0.1 Battery level: 69% SW Version: M15411d Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGM154AT-00-V11d-CRK-US-DEC-05-2017-ARB00+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CW83S180122003097 IMEI: 355171-08-291768-3 Target operator: CRK Hardware: rev_10 Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Resetting FRP Lock... LAF Error: 80000121. Trying second method...Failed! LAF Error: 0F0F0F0F. Please, reflash with "M150x-M160x_Android_6.0.x_for_Reset_FRP.oct" firmware from Support Area ("LG/FOR UNLOCK AND REPAIR" folder), and try to perform Reset FRP operation again. Performed by 2.8.9 Software version. Connecting to server support2.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM101 Selected model: M154 Reading info... Model ID: LG-M154 IMEI: 355171-08-291768-3 Android version: 6.0.1 Battery level: 69% SW Version: M15411d Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGM154AT-00-V11d-CRK-US-DEC-05-2017-ARB00+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CW83S180122003097 IMEI: 355171-08-291768-3 Target operator: CRK Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "M150x-M160x_Android_6.0.x_for_Reset_FRP.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing 1/2...OK Writing 2/2...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM101 Selected model: M154 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M154 IMEI: 355171-08-291768-3 Android version: 6.0.1 Battery level: 70% SW Version: M15411d Mode: Emergency Initializing flash...OK Platform: msm8909 SW version: LGM154AT-00-V11d-CRK-US-DEC-05-2017-ARB00+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CW83S180122003097 IMEI: 355171-08-291768-3 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method...OK Resetting FRP Lock...OK Resetting FRP lock successfully completed! If the phone hang on logo or is restarting afetr performing the operation, please re-flash it using the same or higher version of firmware Performed by 2.8.9 Software version. files available on support M150x-M160x_Android_6.0.x_for_Reset_FRP Last edited by Octopus box; 10-20-2018 at 09:24. |
The Following User Says Thank You to ghacks For This Useful Post: |
10-20-2018, 23:20 | #5673 (permalink) |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,912 | Q6 M700F Reset FRP Successfully Done Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.8 Please select Reset FRP Method! Canceled! Performed by 2.8.8 Software version. Please select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM239 Selected model: M700 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Mode: Emergency Initializing flash...OK SW version: LGM700FAT-00-V12s-GLOBAL-SCA-FEB-03-2018-16G+0 Android version: 7.1.1 LAF Version: 1.1 Product ID: CY19S171015001374 IMEI: 357722-08-651321-3 Target operator: GLOBAL Hardware: rev_11 Reset FRP operation for M700 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...OK Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 6... Step 7... Step 8... Step 9... Step 10...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.8 Software version.
__________________ Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums! Last edited by Octopus box; 10-21-2018 at 10:29. |
The Following User Says Thank You to Braycel For This Useful Post: |
10-22-2018, 14:08 | #5674 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Pakistan
Member: 1489718 Status: Offline Sonork: 100.1652829 QQ 3237590752 Thanks Meter: 1,495 | VS987 Reset FRP successfully done by only one click with Octopus Box Code: Platform: LG Qualcomm Selected port: COM75 Selected model: VS987 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Mode: Emergency Initializing flash...OK Platform: msm8996 SW version: VS9872EA_00 Android version: 7.0 LAF Version: 1.1 Product ID: HD54S170310001933 IMEI: ******-**-******-* Target operator: VZW Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Detecting writing method... Trying third method...OK Formating FRP partition...OK Checking data... Resetting FRP lock successfully completed! Performed by 2.8.9 Software version. Last edited by Octopus box; 10-22-2018 at 14:18. |
The Following User Says Thank You to YMS-RYK For This Useful Post: |
10-23-2018, 13:55 | #5675 (permalink) |
Freak Poster Join Date: Sep 2014 Location: islamabad pakistan Age: 39
Member: 2266425 Status: Offline Thanks Meter: 58 | Octoplus LG 2.8.9 LG-LM x210CM successfully unlocked done Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: LMX210CM Reading info... Model ID: LM-X210CM IMEI: 354376-09- Android version: 7.1.2 Battery level: 85% SW Version: X210CM10c Trying to enable Diagnostics ports... Found model LMX210CM: ÿh at port COM36 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "LMX210CM_3543760900 _23-10-2018_05-30- 06.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "LMX210CM_3543760900 _23-10-2018_05-37- 17.SEC" Writing security area...OK Switching to Normal mode... Found model at port COM36 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! Rebooting phone... Performed by 2.8.9 Software version. Last edited by Octopus box; 10-23-2018 at 14:10. |
The Following User Says Thank You to bilal khan12345 For This Useful Post: |
10-23-2018, 15:17 | #5676 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 578 | LG H345 T mobile usa unlocked ok LG H345 T mobile usa unlocked ok |
The Following User Says Thank You to Unlocker AL For This Useful Post: |
10-23-2018, 16:49 | #5677 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,102 | LG-LS755 ZVF last firmware version unlock done add NEW APN SUCCESS Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: LS755 Selected USB connection type Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable) Phone found at port COM461 Mode: Emergency Initializing flash...OK Model ID: LGLS755 Platform: mt6755 Android version: 6.0.1 SW version: LS755ZVF_02 LAF Version: 1.1 Product ID: CT67S161013004126 IMEI: 358756-07-300085-8 Target operator: SPR Hardware: rev_11 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 358756-07-300085-8 MEID: 358756-07-300085 Bluetooth address: 80:5A:04:7F:A0:93 Wi-Fi MAC address: 2C:59:8A:1D:61:32 SPC: 330806 -------------------------------------------------------------------------------- Detecting writing method...OK Reading Carrier...OK Unlocking...OK Writing Carrier...OK Phone successfully unlocked! Performed by 2.8.9 Software version. Last edited by Octopus box; 10-24-2018 at 04:53. |
The Following User Says Thank You to rebainoor For This Useful Post: |
10-23-2018, 22:42 | #5678 (permalink) |
Freak Poster Join Date: Jul 2009 Location: Dominican Republic Age: 35
Member: 1078865 Status: Offline Sonork: 100.1626549 Thanks Meter: 83 | LG SP200 Unlock successfully done, 4G LTE LG SP200 Unlock done, 4G LTE: Enviado desde mi Redmi Note 5 mediante Tapatalk Last edited by Octopus box; 10-24-2018 at 04:50. |
The Following User Says Thank You to lizandropc For This Useful Post: |
10-24-2018, 08:16 | #5679 (permalink) |
Freak Poster Join Date: Oct 2010 Location: USA
Member: 1420095 Status: Offline Thanks Meter: 216 | LG M150 FRP Done! Platform: LG Qualcomm Selected port: COM197 Selected model: M150 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M150 IMEI: Android version: 7.0 Battery level: 30% SW Version: M15020e Mode: Normal Switching to Download mode...OK Initializing flash...OK Platform: msm8909 SW version: LGM150AT-01-V20e-310-410-AUG-11-2017-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CB42S170527003344 IMEI: Target operator: ATT Hardware: rev_10 Reset FRP operation for M150 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method...OK Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 4... Step 5... Step 6... Step 7... Step 8... Step 9... Step 10...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.9 Software version. |
The Following User Says Thank You to himig_natin For This Useful Post: |
10-24-2018, 16:21 | #5680 (permalink) |
No Life Poster Join Date: Oct 2017
Member: 2766801 Status: Offline Thanks Meter: 182 | LG-M150 v20e Unlock successfully done Welcome to Octoplus/Octopus Box LG Software version 2.8.7 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM162 Selected model: K428 Reading info... Model ID: LGMS210 Incompatible model ID! IMEI: 000000-00-000000-0 Android version: 7.0 Battery level: 12% SW Version: MS21010i Mode: Emergency Initializing flash...OK SW version: LGMS210AT-02-V10v-310-160-DEC-21-2017-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CY11S171007003040 IMEI: 353191-09-258409-3 Target operator: MPCS Hardware: rev_10 Performed by 2.8.7 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM170 Selected model: M150 Reading info... Model ID: LG-M150 IMEI: xxxxxxxxxxxxxxxxxxxxxxxxx Android version: 7.0 Battery level: 97% SW Version: M15020e Trying to enable Diagnostics ports... Found model LGM150AT: ÿh `î at port COM170 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "M150_3xxxxxxxxxxxxxx_24-10-2018_15-58-01.qcn" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method...OK Reading security area...OK Backup saved to "M150_xxxxxxxxxxxxxxxxxxxx_24-10-2018_16-04-05.SEC" Writing security area...OK Switching to Normal mode... Found model LGM150AT* ÿh `– at port COM170 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! Rebooting phone... Performed by 2.8.7 Software version. |
The Following User Says Thank You to successnbd For This Useful Post: |
10-24-2018, 17:49 | #5681 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Jamaica
Member: 2673816 Status: Offline Thanks Meter: 612 | LG LM-M210MA Aristo 2 firmware write done Welcome to Octoplus/Octopus Box LG Software version 2.8.9 Checking data...OK Platform: LG Qualcomm Selected port: COM652 Selected model: LMX210MA Reading info... Model ID: LM-X210MA IMEI: 35XX33-09-XX267X-3 Android version: 7.1.2 Battery level: 91% SW Version: X210MA10j Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX210MAAT-02-V10j-310-160-JUL-06-2018-ARB00+0 Android version: 7.1.2 LAF Version: 1.1 Product ID: CY11S180227003042 IMEI: 35XX33-09-XX267X-3 Target operator: LAO Hardware: rev_10 Opening "X210MA10k_00_MPCS_US_OP_0816(1).kdz"...OK Firmware version: LMX210MAAT-00-V10k-LAO-COM-AUG-16-2018- ARB00+0 Firmware model: LM-X210MA Firmware type: 0100 Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Prepairing firmware...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing 1/72 PrimaryGPT_0.bin...OK Writing 2/72 modem_16384.bin...OK Writing 3/72 aboot_196608.bin...OK Writing 4/72 abootbak_200704.bin...OK Writing 5/72 tz_204800.bin...OK Writing 6/72 tzbak_208896.bin...OK Writing 7/72 sbl1_212992.bin...OK Writing 8/72 sbl1bak_215040.bin...OK Writing 9/72 rpm_217088.bin...OK Writing 10/72 rpmbak_218112.bin...OK Writing 11/72 devcfg_219136.bin...OK Writing 12/72 devcfgbak_220160.bin...OK Writing 13/72 cmnlib_221184.bin...OK Writing 14/72 cmnlibbak_222208.bin...OK Writing 15/72 cmnlib64_223232.bin...OK Writing 16/72 cmnlib64bak_224256.bin...OK Writing 17/72 keymaster_225280.bin...OK Writing 18/72 keymasterbak_226304.bin...OK Writing 19/72 dsp_278528.bin...OK Writing 20/72 sec_397312.bin...OK Writing 22/72 apdp_402432.bin...OK Writing 23/72 msadp_403456.bin...OK Writing 24/72 boot_409600.bin...OK Writing 25/72 laf_475136.bin...OK Writing 26/72 lafbak_540672.bin...OK Writing 27/72 recovery_606208.bin...OK Writing 28/72 recoverybak_671744.bin...OK Writing 29/72 factory_737280.bin...OK Writing 30/72 raw_resources_851968.bin...OK Writing 31/72 raw_resourcesbak_860160.bin...OK Writing 32/72 persist_868352.bin...OK Writing 33/72 system_1064960.bin...OK Writing 34/72 system_1328904.bin...OK Writing 35/72 system_1332904.bin...OK Writing 36/72 system_1593248.bin...OK Writing 37/72 system_1853192.bin...OK Writing 38/72 system_1857192.bin...OK Writing 39/72 system_2117536.bin...OK Writing 40/72 system_2377480.bin...OK Writing 41/72 system_2381480.bin...OK Writing 42/72 system_2641824.bin...OK Writing 43/72 system_2901768.bin...OK Writing 44/72 system_2905768.bin...OK Writing 45/72 system_3166112.bin...OK Writing 46/72 system_3426056.bin...OK Writing 47/72 system_3430056.bin...OK Writing 48/72 system_3690400.bin...OK Writing 49/72 system_3948544.bin...OK Writing 50/72 system_3952544.bin...OK Writing 51/72 system_4214688.bin...OK Writing 52/72 system_4476832.bin...OK Writing 53/72 system_4738976.bin...OK Writing 54/72 system_5001120.bin...OK Writing 55/72 system_5263264.bin...OK Writing 56/72 system_5525408.bin...OK Writing 57/72 system_5787552.bin...OK Writing 58/72 system_6049696.bin...OK Writing 59/72 system_6311840.bin...OK Writing 60/72 system_6573984.bin...OK Writing 61/72 system_6836128.bin...OK Writing 62/72 system_7098272.bin...OK Writing 63/72 system_7360416.bin...OK Writing 64/72 system_7620360.bin...OK Writing 65/72 system_7624360.bin...OK Writing 66/72 system_7884704.bin...OK Writing 67/72 system_8144648.bin...OK Writing 68/72 system_8147968.bin...OK Writing 69/72 BackupGPT_20970496.bin...OK Writing 70/72 0_OP_MPCS_US.img...OK Writing 71/72 1_OP_MPCS_US.img...OK Writing 72/72 2_OP_MPCS_US.img...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.9 Software version. Last edited by Octopus box; 10-25-2018 at 04:54. |
The Following User Says Thank You to ThePhoneTechDoc For This Useful Post: |
10-24-2018, 19:10 | #5682 (permalink) |
Member: 2673816 Status: Offline Thanks Meter: 612 | LG Aristo 2 unlock done Welcome to Octoplus/Octopus Box LG Software version 2.8.9 Checking data...OK Platform: LG Qualcomm Selected port: COM662 Selected model: LMX210MA Reading info... Model ID: LM-X210MA IMEI: 35XX93-09-XX148X-7 Android version: 7.1.2 Battery level: 83% SW Version: X210MA10k Mode: Normal Firmware compiled date: Jun 20 2018 Firmware compiled time: 06:00:00 Firmware released date: Aug 16 2018 Firmware released time: 14:13:43 SW Version: MPSS.JO.3.0.c12-00013-8937_GENNS_PACK-1 IMEI: 35XX93-09-XX148X-7 SPC: 000000 Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is already rooted. Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: the.phone.tech.doc Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 250 credits. To perform "Unlock" operation you need to have 100 credits. Sending exploit...OK Executing exploit...OK Sending data to server...OK Calculating. Please Wait...OK Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 2.8.9 Software version. Last edited by Octopus box; 10-25-2018 at 04:56. |
10-25-2018, 08:26 | #5683 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | VS500PP Unlock successfully done Welcome to Octoplus/Octopus Box LG Software version 2.8.9 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: Selected model: VS500PP Reading info... Could not detect mode! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM89 Selected model: VS500PP Reading info... Model ID: VS500PP IMEI: 354437-08-685976-2 Android version: 6.0.1 Battery level: 55% SW Version: VS500PP5 Mode: Normal Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM89 Selected model: VS500PP Reading info... Model ID: VS500PP IMEI: 354437-08-685976-2 Android version: 6.0.1 Battery level: 55% SW Version: VS500PP5 Mode: Normal Selecting output file...OK Destination file: "VS500PP_Bad_25-10-2018_00-05-26.SEC" Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method...OK Reading security area...OK Backup saved to "VS500PP_Bad_25-10-2018_00-05-26.sec" Rebooting phone... Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM89 Selected model: VS500PP Reading info... Model ID: VS500PP IMEI: 354437-08-685976-2 Android version: 6.0.1 Battery level: 59% SW Version: VS500PP5 Trying to enable Diagnostics ports... Found model VS500PP5:ÿ® `Ù at port COM89 Selecting output file...OK Destination file: "VS500PP_Bad_25-10-2018_00-12-16.qcn" Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM89 Selected model: VS500PP Reading info... Model ID: VS500PP IMEI: 354437-08-685976-2 Android version: 6.0.1 Battery level: 62% SW Version: VS500PP5 Mode: Normal Firmware compiled date: Jul 06 2017 Firmware compiled time: 05:00:00 Firmware released date: Nov 2 2017 Firmware released time: 14:20:37 SW Version: MPSS.JO.1.0.c5.7-00033-M8909EAAAANVZM-1.102965.1 IMEI: 354437-08-685976-2 SPC: 000000 MEID: 3544370******* Mobile ESN: 8064585C SSD_A: 0000000000000000 SSD_B: 0000000000000000 NAM Name: NAM1 User Lock Code: 9868 Unlocking... Skip Read/Write QCN Do you want to create security backup? Writing security area...OK Rebooting phone... Found model VS500PP5:ÿ® `Ù at port COM89 Phone successfully unlocked! Rebooting phone... Performed by 2.8.9 Software version. Last edited by Octopus box; 10-25-2018 at 09:05. |
The Following User Says Thank You to lerner_ For This Useful Post: |
10-25-2018, 10:30 | #5684 (permalink) |
Freak Poster Join Date: Jul 2012 Location: karachi Age: 31
Member: 1779651 Status: Offline Sonork: 100.1603336 Thanks Meter: 97 | LG f430L unknown basband repair succes Lg f430L unknown basband repair succes with ocotopus box Welcome to Octoplus/Octopus Box LG Software version 2.8.4 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM265 Selected model: F430L Reading info... Model ID: LG-F430L IMEI: 353870-06-148810-1 Android version: 4.4.2 Battery level: 100% SW Version: F430L10h Mode: Emergency Initializing flash...OK SW version: LGF430LAT-00-V10h-LGU-KR-SEP-14-2015+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: YE08S150415000153 IMEI: 353870-06-148810-1 Target operator: LGU Hardware: rev_10 Performed by 2.8.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM265 Selected model: F430L Reading info... Model ID: LG-F430L IMEI: 353870-06-148810-1 Android version: 4.4.2 Battery level: 100% SW Version: F430L10h Mode: Emergency Initializing flash...OK SW version: LGF430LAT-00-V10h-LGU-KR-SEP-14-2015+0 Android version: 4.4.2 LAF Version: 1.0 Product ID: YE08S150415000153 IMEI: 353870-06-148810-1 Target operator: LGU Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "F430L08J_00.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing rpmb...OK Writing tzb...OK Writing abootb...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing factory...OK Writing sbl1b...OK Writing system...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.4 Software version. BR. USMAN SOFTWARE |
The Following 2 Users Say Thank You to s a dot com For This Useful Post: |
10-25-2018, 11:43 | #5685 (permalink) |
Member: 2766801 Status: Offline Thanks Meter: 182 | MS210 flash done Checking data...OK Platform: LG Qualcomm Selected port: COM162 Selected model: MS210 Reading info... Model ID: LGMS210 IMEI: 000000-00-000000-0 Android version: 7.0 Battery level: 16% SW Version: MS21010i Mode: Emergency Initializing flash...OK SW version: LGMS210AT-02-V10v-310-160-DEC-21-2017-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: CY11S171007003040 IMEI: 353191-09-258409-3 Target operator: MPCS Hardware: rev_10 Opening "MS21011a_00_0807.kdz"...OK Firmware version: LGMS210AT-00-V11a-MPCS-US-AUG-07-2018-ARB00+0 Firmware model: LGMS210 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Prepairing firmware...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Sending signature...OK Writing 1/68 PrimaryGPT_0.bin...OK Writing 2/68 modem_16384.bin...OK Writing 3/68 aboot_196608.bin...OK Writing 4/68 abootbak_200704.bin...OK Writing 5/68 tz_204800.bin...OK Writing 6/68 tzbak_208896.bin...OK Writing 7/68 sbl1_212992.bin...OK Writing 8/68 sbl1bak_215040.bin...OK Writing 9/68 rpm_217088.bin...OK Writing 10/68 rpmbak_218112.bin...OK Writing 11/68 devcfg_219136.bin...OK Writing 12/68 devcfgbak_220160.bin...OK Writing 13/68 cmnlib_221184.bin...OK Writing 14/68 cmnlibbak_222208.bin...OK Writing 15/68 cmnlib64_223232.bin...OK Writing 16/68 cmnlib64bak_224256.bin...OK Writing 17/68 keymaster_225280.bin...OK Writing 18/68 keymasterbak_226304.bin...OK Writing 19/68 dsp_278528.bin...OK Writing 20/68 sec_397312.bin...OK Writing 22/68 apdp_402432.bin...OK Writing 23/68 msadp_403456.bin...OK Writing 24/68 boot_409600.bin...OK Writing 25/68 laf_475136.bin...OK Writing 26/68 lafbak_540672.bin...OK Writing 27/68 recovery_606208.bin...OK Writing 28/68 recoverybak_671744.bin...OK Writing 29/68 factory_737280.bin...OK Writing 30/68 raw_resources_851968.bin...OK Writing 31/68 raw_resourcesbak_860160.bin...OK Writing 32/68 persist_868352.bin...OK Writing 33/68 system_950272.bin...OK Writing 34/68 system_1214152.bin...OK Writing 35/68 system_1218208.bin...OK Writing 36/68 system_1478616.bin...OK Writing 37/68 system_1738440.bin...OK Writing 38/68 system_1742496.bin...OK Writing 39/68 system_2002904.bin...OK Writing 40/68 system_2262728.bin...OK Writing 41/68 system_2266784.bin...OK Writing 42/68 system_2527192.bin...OK Writing 43/68 system_2785280.bin...OK Writing 44/68 system_2787016.bin...OK Writing 45/68 system_2791072.bin...OK Writing 46/68 system_3051480.bin...OK Writing 47/68 system_3309568.bin...OK Writing 48/68 system_3311304.bin...OK Writing 49/68 system_3315360.bin...OK Writing 50/68 system_3575768.bin...OK Writing 51/68 system_3837912.bin...OK Writing 52/68 system_4100056.bin...OK Writing 53/68 system_4362200.bin...OK Writing 54/68 system_4624344.bin...OK Writing 55/68 system_4886488.bin...OK Writing 56/68 system_5148632.bin...OK Writing 57/68 system_5410776.bin...OK Writing 58/68 system_5672920.bin...OK Writing 59/68 system_5935064.bin...OK Writing 60/68 system_6197208.bin...OK Writing 61/68 system_6459352.bin...OK Writing 62/68 system_6721496.bin...OK Writing 63/68 system_6983640.bin...OK Writing 64/68 system_7245784.bin...OK Writing 65/68 system_7505608.bin...OK Writing 66/68 system_7509664.bin...OK Writing 67/68 system_7769088.bin...OK Writing 68/68 BackupGPT_20970496.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.8.7 Software version. Last edited by Octopus box; 10-25-2018 at 12:10. |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
