Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 10-19-2018, 15:45   #5671 (permalink)
chipscell25's Avatar
Member: 1537078
Sonork: celular center
Thanks Meter: 522
VS995 Reset FRP successfully done
FRP LG VS995 DONE
Welcome to Octoplus/Octopus Box LG Software version 2.8.9
Platform: LG Qualcomm
Selected port: COM81
Selected model: VS995
Reading info...
Model ID: VS995
IMEI: 000000-00-000000-0
Android version: 7.0
Battery level: 71%
SW Version: VS99512A
Mode: Emergency
Initializing flash...OK
Platform: msm8996
SW version: VS99518A_00
LAF Version: 1.1
Product ID: PT03S161129003714
IMEI: 359968-07-165399-7
Target operator: VZW
Hardware: rev_10
Performed by 2.8.9 Software version.
Checking data...OK
Please, put the phone into download mode manually (Power phone OFF,
press and hold "Vol+" button and connect the cable).
Reading info...
Model ID: VS995
Battery level: 71%
Mode: Emergency
Platform: msm8996
LAF Version: 1.1
Hardware: rev_10
Reading partitions...OK
Resetting FRP Lock...
Detecting writing method...
Trying third method...OK
Formating FRP partition...OK
Checking data...
Resetting FRP lock successfully completed!
The Following User Says Thank You to chipscell25 For This Useful Post:
Old 10-20-2018, 05:18   #5672 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,597
Thumbs up M154 remove FRP successfully done
Checking data...OK
Selected port: COM101
Selected model: M154
(reconnect battery), press and hold "Vol+" button and connect the cable
(or P999 cable)).
Reading info...
Model ID: LG-M154
IMEI: 355171-08-291768-3
Android version: 6.0.1
Battery level: 69%
SW Version: M15411d
Mode: Emergency
Platform: msm8909
SW version: LGM154AT-00-V11d-CRK-US-DEC-05-2017-ARB00+0
LAF Version: 1.1
Product ID: CW83S180122003097
Target operator: CRK
Hardware: rev_10
LAF Error: 80000121.
Trying second method...
Trying third method...Failed!
Trying second method...Failed!
LAF Error: 0F0F0F0F.
Please, reflash with "M150x-M160x_Android_6.0.x_for_Reset_FRP.oct"
firmware from Support Area ("LG/FOR UNLOCK AND REPAIR" folder), and
try to perform Reset FRP operation again.
Connecting to server support2.octoplusbox.com:82...OK
Authorizing...OK
Checking data...OK
Reading info...
Model ID: LG-M154
Battery level: 69%
SW Version: M15411d
Mode: Emergency
Platform: msm8909
LAF Version: 1.1
Hardware: rev_10
Writing phone firmware without real necessity is at your own risk.
Downgrade may lead to phone damage!
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones,
modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without any
installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to your
computer during the flashing!
Opening "M150x-M160x_Android_6.0.x_for_Reset_FRP.oct"...OK
Setting options...OK
Formating USERDATA...OK
Formating ENCRYPT...OK
Sending signature...OK
Writing 1/2...OK
Writing 2/2...OK
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
Writing firmware done!
Checking data...OK
(or P999 cable)).
Reading info...
Model ID: LG-M154
Battery level: 70%
SW Version: M15411d
Mode: Emergency
Platform: msm8909
LAF Version: 1.1
Target operator: GLOBAL
Hardware: rev_10
Trying second method...OK
Resetting FRP Lock...OK
If the phone hang on logo or is restarting afetr performing the operation,
please re-flash it using the same or higher version of firmware
files available on support M150x-M160x_Android_6.0.x_for_Reset_FRP
The Following User Says Thank You to ghacks For This Useful Post:
Old 10-20-2018, 23:20   #5673 (permalink)
Super Moderator
Braycel's Avatar
Member: 813309
Sonork: 100.1684834
Thanks Meter: 1,867
Q6 M700F Reset FRP Successfully Done
Welcome to Octoplus/Octopus Box LG Software version 2.8.8
Please select Reset FRP Method!
Canceled!
Performed by 2.8.8 Software version.
Checking data...OK
Selected port: COM239
Selected model: M700
(or P999 cable)).
Reading info...
Mode: Emergency
SW version: LGM700FAT-00-V12s-GLOBAL-SCA-FEB-03-2018-16G+0
Android version: 7.1.1
LAF Version: 1.1
Product ID: CY19S171015001374
IMEI: 357722-08-651321-3
Hardware: rev_11
Reset FRP operation for M700 will delete all user data on the phone
(contacts, pictures and others)!
Do You want to continue?
Writing loader...
Step 1...
Step 2...
Step 3...
Step 6...
Step 7...
Step 8...
Step 9...
Step 10...OK
Writing userdata...OK
Formating encrypt...OK
Restoring loader...OK
Rebooting phone...
To complete the operation, please make Factory Reset (Go to "Settings" ->
"General" -> "Backup & reset" -> "Factory data reset", press "Reset
phone" and "Erase everything" buttons).
__________________
Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums!
The Following User Says Thank You to Braycel For This Useful Post:
Old 10-22-2018, 14:08   #5674 (permalink)
YMS-RYK's Avatar
Member: 1489718
Sonork: 100.1652829 QQ 3237590752
Thanks Meter: 1,493
Thumbs up VS987 Reset FRP successfully done by only one click with Octopus Box
Selected port: COM75
Selected model: VS987
Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable).
Reading info...
Mode: Emergency
Platform: msm8996
SW version: VS9872EA_00
LAF Version: 1.1
Product ID: HD54S170310001933
IMEI: ******-**-******-*
Hardware: rev_10
Checking data...
The Following User Says Thank You to YMS-RYK For This Useful Post:
Old 10-23-2018, 13:55   #5675 (permalink)
Member: 2266425
Thanks Meter: 49
Thumbs up Octoplus LG 2.8.9 LG-LM x210CM successfully unlocked done
Checking data...OK
Selected port: COM36
Selected model: LMX210CM
Reading info...
Model ID: LM-X210CM
IMEI: 354376-09-
Android version: 7.1.2
Battery level: 85%
SW Version: X210CM10c
Trying to enable Diagnostics ports...
Found model LMX210CM: h at port COM36
Unlocking...
Write security backup function doesn't work for this device with latest
firmware versions. If you'll encounter any problem during Unlock operation
- you won't be able to restore the phone to it's initial state, so proceed at
your own risk.
Continue?
Reading QCN...
Send SPC...OK
Reading Mobile Property...OK
Reading Feature Mask...OK
Reading Roaming List 0...OK
Reading NV_Numbered Items...OK
Reading NV_Numbered SIM1 Items...OK
Reading NV_Numbered SIM2 Items...OK
Reading NV Items...OK
Reading EFS...OK
Reading Provisioning Items...OK
Reading QCN done!
Backup saved to "LMX210CM_3543760900 _23-10-2018_05-30-
06.qcn"
Switching to Download mode...OK
Reading security area...OK
Backup saved to "LMX210CM_3543760900 _23-10-2018_05-37-
17.SEC"
Writing security area...OK
Switching to Normal mode...
Found model at port COM36
Send SPC...OK
Writing QCN...
Writing NV_Numbered Items...OK
Writing NV_Numbered SIM1 Items...OK
Writing NV_Numbered SIM2 Items...OK
Writing QCN done!
Phone successfully unlocked!
Rebooting phone...
The Following User Says Thank You to bilal khan12345 For This Useful Post:
Old 10-23-2018, 15:17   #5676 (permalink)
Unlocker AL's Avatar
Member: 3617
Thanks Meter: 502
LG H345 T mobile usa unlocked ok
The Following User Says Thank You to Unlocker AL For This Useful Post:
Old 10-23-2018, 16:49   #5677 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,022
Thumbs up LG-LS755 ZVF last firmware version unlock done add NEW APN SUCCESS
Checking data...OK
Platform: LG MTK
Selected port: COM1
Selected baudrate: 921600
Selected model: LS755
Selected USB connection type
Power phone OFF (reconnect battery), press and hold "Vol+" button and
connect the cable (or P999 cable)
Phone found at port COM461
Mode: Emergency
Model ID: LGLS755
Platform: mt6755
SW version: LS755ZVF_02
LAF Version: 1.1
Product ID: CT67S161013004126
IMEI: 358756-07-300085-8
Target operator: SPR
Hardware: rev_11
Battery level: 50%
Checking security...
Checking security passed!
MEID: 358756-07-300085
Bluetooth address: 80:5A:04:7F:A0:93
Wi-Fi MAC address: 2C:59:8A:1D:61:32
SPC: 330806
Detecting writing method...OK
Reading Carrier...OK
Unlocking...OK
Writing Carrier...OK
The Following User Says Thank You to rebainoor For This Useful Post:
Old 10-23-2018, 22:42   #5678 (permalink)
Member: 1078865
Sonork: 100.1626549
Thanks Meter: 74
LG SP200 Unlock successfully done, 4G LTE
LG SP200 Unlock done, 4G LTE:
Enviado desde mi Redmi Note 5 mediante Tapatalk
The Following User Says Thank You to lizandropc For This Useful Post:
Old 10-24-2018, 08:16   #5679 (permalink)
Member: 1420095
Thanks Meter: 210
LG M150 FRP Done!
Selected port: COM197
Selected model: M150
(or P999 cable)).
Reading info...
Model ID: LG-M150
IMEI:
Battery level: 30%
SW Version: M15020e
Mode: Normal
Platform: msm8909
SW version: LGM150AT-01-V20e-310-410-AUG-11-2017-ARB00+0
LAF Version: 1.1
Product ID: CB42S170527003344
IMEI:
Target operator: ATT
Hardware: rev_10
Reset FRP operation for M150 will delete all user data on the phone
Writing loader...
Step 1...
Step 2...
Step 3...
Step 4...
Step 5...
Step 6...
Step 7...
Step 8...
Step 9...
Step 10...OK
Rebooting phone...
The Following User Says Thank You to himig_natin For This Useful Post:
Old 10-24-2018, 16:21   #5680 (permalink)
successnbd's Avatar
Member: 2766801
Thanks Meter: 182
LG-M150 v20e Unlock successfully done
Welcome to Octoplus/Octopus Box LG Software version 2.8.7
Selected port: COM162
Selected model: K428
Reading info...
Model ID: LGMS210
Incompatible model ID!
Battery level: 12%
SW Version: MS21010i
Mode: Emergency
SW version: LGMS210AT-02-V10v-310-160-DEC-21-2017-ARB00+0
LAF Version: 1.1
Product ID: CY11S171007003040
IMEI: 353191-09-258409-3
Target operator: MPCS
Hardware: rev_10
Performed by 2.8.7 Software version.
Checking data...OK
Selected port: COM170
Reading info...
Model ID: LG-M150
IMEI: xxxxxxxxxxxxxxxxxxxxxxxxx
Battery level: 97%
SW Version: M15020e
Found model LGM150AT: h ` at port COM170
Unlocking...
Reading QCN...
Send SPC...OK
Reading EFS...OK
Reading QCN done!
Backup saved to "M150_3xxxxxxxxxxxxxx_24-10-2018_15-58-01.qcn"
Backup saved to "M150_xxxxxxxxxxxxxxxxxxxx_24-10-2018_16-04-05.SEC"
Found model LGM150AT* h ` at port COM170
Send SPC...OK
Writing QCN...
Writing QCN done!
Rebooting phone...
The Following User Says Thank You to successnbd For This Useful Post:
Old 10-24-2018, 17:49   #5681 (permalink)
ThePhoneTechDoc's Avatar
Member: 2673816
Thanks Meter: 593
Smile LG LM-M210MA Aristo 2 firmware write done
Checking data...OK
Selected port: COM652
Selected model: LMX210MA
Reading info...
Model ID: LM-X210MA
IMEI: 35XX33-09-XX267X-3
Battery level: 91%
SW Version: X210MA10j
Mode: Emergency
Platform: msm8937
SW version: LMX210MAAT-02-V10j-310-160-JUL-06-2018-ARB00+0
LAF Version: 1.1
Product ID: CY11S180227003042
Target operator: LAO
Hardware: rev_10
Opening "X210MA10k_00_MPCS_US_OP_0816(1).kdz"...OK
Firmware version: LMX210MAAT-00-V10k-LAO-COM-AUG-16-2018-
ARB00+0
Firmware model: LM-X210MA
Firmware type: 0100
Prepairing firmware...OK
Writing 1/72 PrimaryGPT_0.bin...OK
Writing 2/72 modem_16384.bin...OK
Writing 3/72 aboot_196608.bin...OK
Writing 4/72 abootbak_200704.bin...OK
Writing 5/72 tz_204800.bin...OK
Writing 6/72 tzbak_208896.bin...OK
Writing 7/72 sbl1_212992.bin...OK
Writing 8/72 sbl1bak_215040.bin...OK
Writing 9/72 rpm_217088.bin...OK
Writing 10/72 rpmbak_218112.bin...OK
Writing 11/72 devcfg_219136.bin...OK
Writing 12/72 devcfgbak_220160.bin...OK
Writing 13/72 cmnlib_221184.bin...OK
Writing 14/72 cmnlibbak_222208.bin...OK
Writing 15/72 cmnlib64_223232.bin...OK
Writing 16/72 cmnlib64bak_224256.bin...OK
Writing 17/72 keymaster_225280.bin...OK
Writing 18/72 keymasterbak_226304.bin...OK
Writing 19/72 dsp_278528.bin...OK
Writing 20/72 sec_397312.bin...OK
Writing 22/72 apdp_402432.bin...OK
Writing 23/72 msadp_403456.bin...OK
Writing 24/72 boot_409600.bin...OK
Writing 25/72 laf_475136.bin...OK
Writing 26/72 lafbak_540672.bin...OK
Writing 27/72 recovery_606208.bin...OK
Writing 28/72 recoverybak_671744.bin...OK
Writing 29/72 factory_737280.bin...OK
Writing 30/72 raw_resources_851968.bin...OK
Writing 31/72 raw_resourcesbak_860160.bin...OK
Writing 32/72 persist_868352.bin...OK
Writing 33/72 system_1064960.bin...OK
Writing 34/72 system_1328904.bin...OK
Writing 35/72 system_1332904.bin...OK
Writing 36/72 system_1593248.bin...OK
Writing 37/72 system_1853192.bin...OK
Writing 38/72 system_1857192.bin...OK
Writing 39/72 system_2117536.bin...OK
Writing 40/72 system_2377480.bin...OK
Writing 41/72 system_2381480.bin...OK
Writing 42/72 system_2641824.bin...OK
Writing 43/72 system_2901768.bin...OK
Writing 44/72 system_2905768.bin...OK
Writing 45/72 system_3166112.bin...OK
Writing 46/72 system_3426056.bin...OK
Writing 47/72 system_3430056.bin...OK
Writing 48/72 system_3690400.bin...OK
Writing 49/72 system_3948544.bin...OK
Writing 50/72 system_3952544.bin...OK
Writing 51/72 system_4214688.bin...OK
Writing 52/72 system_4476832.bin...OK
Writing 53/72 system_4738976.bin...OK
Writing 54/72 system_5001120.bin...OK
Writing 55/72 system_5263264.bin...OK
Writing 56/72 system_5525408.bin...OK
Writing 57/72 system_5787552.bin...OK
Writing 58/72 system_6049696.bin...OK
Writing 59/72 system_6311840.bin...OK
Writing 60/72 system_6573984.bin...OK
Writing 61/72 system_6836128.bin...OK
Writing 62/72 system_7098272.bin...OK
Writing 63/72 system_7360416.bin...OK
Writing 64/72 system_7620360.bin...OK
Writing 65/72 system_7624360.bin...OK
Writing 66/72 system_7884704.bin...OK
Writing 67/72 system_8144648.bin...OK
Writing 68/72 system_8147968.bin...OK
Writing 69/72 BackupGPT_20970496.bin...OK
Writing 70/72 0_OP_MPCS_US.img...OK
Writing 71/72 1_OP_MPCS_US.img...OK
Writing 72/72 2_OP_MPCS_US.img...OK
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
The Following User Says Thank You to ThePhoneTechDoc For This Useful Post:
Old 10-24-2018, 19:10   #5682 (permalink)
Member: 2673816
Thanks Meter: 593
Smile LG Aristo 2 unlock done
Checking data...OK
Selected port: COM662
Reading info...
Model ID: LM-X210MA
IMEI: 35XX93-09-XX148X-7
Battery level: 83%
SW Version: X210MA10k
Mode: Normal
Firmware compiled date: Jun 20 2018
Firmware compiled time: 06:00:00
Firmware released date: Aug 16 2018
Firmware released time: 14:13:43
SW Version: MPSS.JO.3.0.c12-00013-8937_GENNS_PACK-1
SPC: 000000
Checking root access...
Initializing ADB...OK
Waiting for phone...OK
Phone is already rooted.
Connecting to server...OK
Octopus smart card is present.
Checking smart card...OK
Username: the.phone.tech.doc
Authorizing...OK
Checking balance...OK
Checking operation...OK
Sending device information...OK
Get credits, needed for current operation...OK
Your balance: 250 credits.
To perform "Unlock" operation you need to have 100 credits.
Sending exploit...OK
Executing exploit...OK
Sending data to server...OK
Calculating. Please Wait...OK
Unlocking...
Rebooting phone...
Old 10-25-2018, 08:26   #5683 (permalink)
Member: 2537939
Sonork: 100.1670350
Thanks Meter: 701
Thumbs up VS500PP Unlock successfully done
Selected port:
Selected model: VS500PP
Reading info...
Could not detect mode!
Selected port: COM89
Reading info...
Model ID: VS500PP
IMEI: 354437-08-685976-2
Battery level: 55%
SW Version: VS500PP5
Mode: Normal
Checking data...OK
Reading info...
Model ID: VS500PP
Battery level: 55%
Mode: Normal
Selecting output file...OK
Destination file: "VS500PP_Bad_25-10-2018_00-05-26.SEC"
Backup saved to "VS500PP_Bad_25-10-2018_00-05-26.sec"
Rebooting phone...
Checking data...OK
Reading info...
Model ID: VS500PP
Battery level: 59%
Found model VS500PP5: ` at port COM89
Destination file: "VS500PP_Bad_25-10-2018_00-12-16.qcn"
Reading QCN...
Send SPC...OK
Reading EFS...OK
Reading QCN done!
Checking data...OK
Reading info...
Model ID: VS500PP
Battery level: 62%
Mode: Normal
Firmware compiled date: Jul 06 2017
Firmware compiled time: 05:00:00
Firmware released date: Nov 2 2017
Firmware released time: 14:20:37
SW Version: MPSS.JO.1.0.c5.7-00033-M8909EAAAANVZM-1.102965.1
SPC: 000000
MEID: 3544370*******
Mobile ESN: 8064585C
SSD_A: 0000000000000000
SSD_B: 0000000000000000
NAM Name: NAM1
User Lock Code: 9868
Unlocking...
Skip Read/Write QCN
Do you want to create security backup?
Rebooting phone...
Rebooting phone...
The Following User Says Thank You to lerner_ For This Useful Post:
Old 10-25-2018, 10:30   #5684 (permalink)
s a dot com's Avatar
Member: 1779651
Sonork: 100.1603336
Thanks Meter: 96
LG f430L unknown basband repair succes
Lg f430L unknown basband repair succes with ocotopus box
Welcome to Octoplus/Octopus Box LG Software version 2.8.4
Selected port: COM265
Selected model: F430L
Reading info...
Model ID: LG-F430L
IMEI: 353870-06-148810-1
Android version: 4.4.2
Battery level: 100%
SW Version: F430L10h
Mode: Emergency
SW version: LGF430LAT-00-V10h-LGU-KR-SEP-14-2015+0
LAF Version: 1.0
Product ID: YE08S150415000153
Target operator: LGU
Hardware: rev_10
Performed by 2.8.4 Software version.
Checking data...OK
Reading info...
Model ID: LG-F430L
Battery level: 100%
Mode: Emergency
LAF Version: 1.0
Hardware: rev_10
Opening "F430L08J_00.oct"...OK
Writing PrimaryGPT...OK
Writing modem...OK
Writing sbl1...OK
Writing rpm...OK
Writing tz...OK
Writing sdi...OK
Writing aboot...OK
Writing rpmb...OK
Writing tzb...OK
Writing abootb...OK
Writing persist...OK
Writing laf...OK
Writing boot...OK
Writing recovery...OK
Writing factory...OK
Writing sbl1b...OK
Writing system...OK
Writing BackupGPT...OK
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
BR.
USMAN
SOFTWARE
The Following 2 Users Say Thank You to s a dot com For This Useful Post:
Old 10-25-2018, 11:43   #5685 (permalink)
successnbd's Avatar
Member: 2766801
Thanks Meter: 182
Thumbs up MS210 flash done
Checking data...OK
Selected model: MS210
Reading info...
Model ID: LGMS210
Battery level: 16%
Mode: Emergency
LAF Version: 1.1
Hardware: rev_10
Opening "MS21011a_00_0807.kdz"...OK
Firmware version: LGMS210AT-00-V11a-MPCS-US-AUG-07-2018-ARB00+0
Firmware model: LGMS210
Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to your computer during the flashing!
Writing 1/68 PrimaryGPT_0.bin...OK
Writing 2/68 modem_16384.bin...OK
Writing 3/68 aboot_196608.bin...OK
Writing 4/68 abootbak_200704.bin...OK
Writing 5/68 tz_204800.bin...OK
Writing 6/68 tzbak_208896.bin...OK
Writing 7/68 sbl1_212992.bin...OK
Writing 8/68 sbl1bak_215040.bin...OK
Writing 9/68 rpm_217088.bin...OK
Writing 10/68 rpmbak_218112.bin...OK
Writing 11/68 devcfg_219136.bin...OK
Writing 12/68 devcfgbak_220160.bin...OK
Writing 13/68 cmnlib_221184.bin...OK
Writing 14/68 cmnlibbak_222208.bin...OK
Writing 15/68 cmnlib64_223232.bin...OK
Writing 16/68 cmnlib64bak_224256.bin...OK
Writing 17/68 keymaster_225280.bin...OK
Writing 18/68 keymasterbak_226304.bin...OK
Writing 19/68 dsp_278528.bin...OK
Writing 20/68 sec_397312.bin...OK
Writing 22/68 apdp_402432.bin...OK
Writing 23/68 msadp_403456.bin...OK
Writing 24/68 boot_409600.bin...OK
Writing 25/68 laf_475136.bin...OK
Writing 26/68 lafbak_540672.bin...OK
Writing 27/68 recovery_606208.bin...OK
Writing 28/68 recoverybak_671744.bin...OK
Writing 29/68 factory_737280.bin...OK
Writing 30/68 raw_resources_851968.bin...OK
Writing 31/68 raw_resourcesbak_860160.bin...OK
Writing 32/68 persist_868352.bin...OK
Writing 33/68 system_950272.bin...OK
Writing 34/68 system_1214152.bin...OK
Writing 35/68 system_1218208.bin...OK
Writing 36/68 system_1478616.bin...OK
Writing 37/68 system_1738440.bin...OK
Writing 38/68 system_1742496.bin...OK
Writing 39/68 system_2002904.bin...OK
Writing 40/68 system_2262728.bin...OK
Writing 41/68 system_2266784.bin...OK
Writing 42/68 system_2527192.bin...OK
Writing 43/68 system_2785280.bin...OK
Writing 44/68 system_2787016.bin...OK
Writing 45/68 system_2791072.bin...OK
Writing 46/68 system_3051480.bin...OK
Writing 47/68 system_3309568.bin...OK
Writing 48/68 system_3311304.bin...OK
Writing 49/68 system_3315360.bin...OK
Writing 50/68 system_3575768.bin...OK
Writing 51/68 system_3837912.bin...OK
Writing 52/68 system_4100056.bin...OK
Writing 53/68 system_4362200.bin...OK
Writing 54/68 system_4624344.bin...OK
Writing 55/68 system_4886488.bin...OK
Writing 56/68 system_5148632.bin...OK
Writing 57/68 system_5410776.bin...OK
Writing 58/68 system_5672920.bin...OK
Writing 59/68 system_5935064.bin...OK
Writing 60/68 system_6197208.bin...OK
Writing 61/68 system_6459352.bin...OK
Writing 62/68 system_6721496.bin...OK
Writing 63/68 system_6983640.bin...OK
Writing 64/68 system_7245784.bin...OK
Writing 65/68 system_7505608.bin...OK
Writing 66/68 system_7509664.bin...OK
Writing 67/68 system_7769088.bin...OK
Writing 68/68 BackupGPT_20970496.bin...OK
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
Post here successfully unlocked a2 phones 3lsheikh SETool2 10 03-04-2011 02:48
Successfully Unlock Z240 Phone Freeze jhepoy_org UST Pro II 13 12-02-2009 06:03
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 0 11-29-2008 14:13
Successfully unlock BB5 phones with bb5king Mjabbar BB5KING 2 11-26-2008 11:54
PB2 - Successfully unlocked LG phones CU/KU ... DOUHAL PolarBox 3 72 11-05-2008 18:21
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.35201 seconds with 9 queries
