09-23-2020, 21:02 | #6213 (permalink) |
No Life Poster Join Date: May 2005 Location: Tirana Age: 43
Member: 143851 Status: Offline Thanks Meter: 162 | Q730TM successfully unlocked Welcome to Octoplus/Octopus Box LG Software version 3.0.4 Card S/N : 000000xxxx -------------------------------------------------------------------------------- Platform: LG MTK Selected port: COM3 Selected baudrate: 921600 Selected model: Q730TM Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM112 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Android version: 10 SW version: LMQ730TM3AT-00-V10i-310-120-JUL-02-2020-ARB00+0 LAF Version: 1.1 Product ID: VH03S200429000525 IMEI: 354527-11-046367-0 Target operator: LAO Hardware: rev_11 Battery level: 22% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354527-11-046367-0 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Performed by 3.0.4 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 921600 Selected model: Q730TM Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM112 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Android version: 10 SW version: LMQ730TM3AT-00-V10i-310-120-JUL-02-2020-ARB00+0 LAF Version: 1.1 Product ID: VH03S200429000525 IMEI: 354527-11-046367-0 Target operator: LAO Hardware: rev_11 Battery level: 22% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354527-11-046367-0 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "Q730TM_354527110463670_23-09-2020_21-56-30.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: xxxxxxxxxxx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 312 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area... Initializing flash...OK Writing security area...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.4 Software version. |
09-23-2020, 22:12 | #6214 (permalink) |
Member: 143851 Status: Offline Thanks Meter: 162 | Q730MM unlocked successfully -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM160 Selected baudrate: 921600 Selected model: Q730MM Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable.Canceled! Performed by 3.0.4 Software version. -------------------------------------------------------------------------------- Connecting to server ...OK Username: xxxxxxxxxxx Authorizing...OK Checking balance...OK Your balance: 212 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM160 Selected baudrate: 921600 Selected model: Q730MM Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM112 Mode: Emergency Initializing flash...OK Model ID: LM-Q730MM Platform: mt6765 Android version: 10 SW version: LMQ730MMAT-02-V10i-310-160-JUL-02-2020-ARB00+0 LAF Version: 1.1 Product ID: VH03S200506003060 IMEI: 354525-11-037433-5 Target operator: LAO Hardware: rev_11 Battery level: 23% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354525-11-037433-5 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "Q730MM_354525110374335_23-09-2020_23-03- 16.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: xxxxxxxxxxxx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 212 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area... Initializing flash...OK Writing security area...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.4 Software version. |
10-19-2020, 12:24 | #6217 (permalink) |
Freak Poster Join Date: Jun 2017 Location: GH, AF
Member: 2730784 Status: Offline Thanks Meter: 20 | LG K51-K500MM UNLOCK DONE BY GREAT OCTOPLUS Welcome to Octoplus/Octopus Box LG Software version 3.0.5.06 Card S/N : 000101657E -------------------------------------------------------------------------------- Connecting to server ...OK Username: droidmobitech Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000000125166 Checking data...OK Platform: LG MTK Selected port: COM59 Selected baudrate: 921600 Selected model: K500MM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM29 Mode: Emergency Initializing flash...OK Model ID: LM-K500MM Platform: mt6765 Android version: 10 SW version: LMK500MMAT-02-V10f-310-160-JUN-10-2020-ARB00+0 LAF Version: 1.1 Product ID: WI17S200613004618 IMEI: 355041-61-054104-2 Target operator: LAO Hardware: rev_10 Battery level: 45% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 355041-61-054104-2 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "K500MM_355041610541042_19-10-2020_04-16-41.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: droidmobitech Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.5.06 Software version. |
10-22-2020, 18:30 | #6218 (permalink) |
Freak Poster Join Date: Apr 2008 Location: A_1st™ Support Age: 38
Member: 758981 Status: Offline Sonork: 100.1592091 Thanks Meter: 232 | LM-K500MM Unlock Done Welcome to Octoplus/Octopus Box LG Software version 3.0.5.06 Card S/N : 00000***** -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000000162DE4 Checking data...OK Platform: LG MTK Selected port: COM10 Selected baudrate: 921600 Selected model: K500MM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM101 Mode: Emergency Initializing flash...OK Model ID: LM-K500MM Platform: mt6765 Android version: 10 SW version: LMK500MMAT-02-V10d-310-160-APR-13-2020- ARB00+0 LAF Version: 1.1 Product ID: WI17S200613004392 IMEI: 354544-11-********* Target operator: LAO Hardware: rev_10 Battery level: 30% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354544-11-361970-3 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "K500MM_354544113******_22-10-2020_19- 03-19.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: zayat73 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.5.06 Software version. |
11-07-2020, 16:13 | #6220 (permalink) |
Freak Poster Join Date: Feb 2017 Location: D.R
Member: 2684440 Status: Offline Thanks Meter: 218 | Connecting to server ...OK Username: ************* Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 000000000015B89F Checking data...OK Platform: LG MTK Selected port: Selected baudrate: 921600 Selected model: K500UM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM202 Mode: Emergency Initializing flash...OK Model ID: LM-K500UM Platform: mt6765 Android version: 9 SW version: LMK500UM3AT-00-V10g-310-120-SEP-07-2020-ARB00+0 LAF Version: 1.1 Product ID: VS01S200616010345 IMEI: 35****************** Target operator: LAO Hardware: rev_10 Battery level: 19% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: ************** MEID: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "K500UM_35**************_07-11-2020_11-03-07.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: ********** Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.5.07 Software version. |
11-09-2020, 18:15 | #6221 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | LG M703 unlock frp done Platform: LG Qualcomm Selected port: COM19 Selected model: M703 Reading info... Model ID: LG-M703 IMEI: 000000-00-000000-0 Android version: 7.1.1 Battery level: 89% Mode: Normal Performed by 3.0.5.07 Software version. -------------------------------------------------------------------------------- Work ID: 000000000017D2CE Please, select Reset FRP Method! Canceled! Performed by 3.0.5.07 Software version. -------------------------------------------------------------------------------- Work ID: 000000000017D2FC Please, select Reset FRP Method! Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: M703 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Could not detect mode! Performed by 3.0.5.07 Software version. -------------------------------------------------------------------------------- Work ID: 000000000017D31C Please, select Reset FRP Method! Checking data...OK Platform: LG Qualcomm Selected port: COM19 Selected model: M703 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-M703 IMEI: 000000-00-000000-0 Android version: 7.1.1 Battery level: 89% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LGM703AT-00-V10f-CAN-XX-DEC-15-2017-ARB00+0 Android version: 7.1.1 LAF Version: 1.1 Product ID: CY21S170928005061 IMEI: 359637-08-097773-5 Target operator: GLOBAL Hardware: rev_10 Reset FRP operation for M703 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...OK Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 6... Step 7... Step 8... Step 9... Step 10...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 3.0.5.07 Software version. |
11-09-2020, 19:53 | #6222 (permalink) |
Insane Poster Join Date: Dec 2018 Location: Venezuela
Member: 2885644 Status: Offline Thanks Meter: 29 | Unlock LG M150 done! Welcome to Octoplus/Octopus Box LG Software version 3.0.5 Card S/N : 0000***** -------------------------------------------------------------------------------- Work ID: 1567653 Checking data...OK Platform: LG Qualcomm Selected port: COM15 Selected model: M150 Reading info... Model ID: LG-M150 IMEI: 353712-09-9*****-0 Android version: 7.0 Battery level: 100% Mode: Normal Firmware compiled date: Jul 06 2017 Firmware compiled time: 04:00:00 Firmware released date: Mar 22 2018 Firmware released time: 11:43:37 SW Version: MPSS.JO.2.0.c1.2-00020-8909_GEN_PACK-1.92496.1.104247.1 IMEI: 353712-09-945162-0 Bluetooth address: 48:60:5F:C0:F0:B5 Wi-Fi MAC address: 48:60:5F:342:41 SPC: 000000 Unlocking... Initializing ADB...OK Waiting for phone...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Tecnoservicel Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 340 credits. To perform "Unlock" operation you need to have 50 credits. Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...OK Reading security area...OK Backup saved to "M150_3537120994*****_09-11-2020_04-54-20.SEC" Writing security area...OK Switching to Normal mode... Found model LGM150AT* ÿh `ø at port COM15 Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Tecnoservicel Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 340 credits. To perform "Unlock" operation you need to have 50 credits.OK Finalizing... Phone successfully unlocked! Rebooting phone... Performed by 3.0.5 Software version. |
11-12-2020, 21:12 | #6223 (permalink) |
Member: 758981 Status: Offline Sonork: 100.1592091 Thanks Meter: 232 | LG K410EMW Unlock Done Code: Welcome to Octoplus/Octopus Box LG Software version 3.0.6 Card S/N : 0000066169 -------------------------------------------------------------------------------- Connecting to server ...OK Username: ********** Authorizing...OK Checking balance...OK Your balance: 100 credits. Connecting to server support2.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Selected USB connection type Platform: LG MTK Selected port: COM10 Selected baudrate: 921600 Selected model: K410EMW Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM159 Mode: Emergency Initializing flash...OK Model ID: LM-K410EMW Platform: mt6765 Android version: 9 SW version: LMK410EMWAT-64-V10e-EEA-XX-AUG-20-2020+0 LAF Version: 1.1 Product ID: LCL1S200916318562 IMEI: 353671-11********** Target operator: LAO Hardware: rev_10 Battery level: 94% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 353671************** IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Performed by 3.0.6 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000001BD117 Checking data...OK Platform: LG MTK Selected port: COM10 Selected baudrate: 921600 Selected model: K410EMW Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM159 Mode: Emergency Initializing flash...OK Model ID: LM-K410EMW Platform: mt6765 Android version: 9 SW version: LMK410EMWAT-64-V10e-EEA-XX-AUG-20-2020+0 LAF Version: 1.1 Product ID: LCL1S200916318562 IMEI: 353671-11-369393-2 Target operator: LAO Hardware: rev_10 Battery level: 94% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 353671*********** IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "K410EMW_3536711*********_12-11-2020_22-06-34.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: zayat73 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area... Initializing flash...OK Writing security area...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.6 Software version. |
11-13-2020, 10:52 | #6224 (permalink) |
No Life Poster Join Date: Jul 2006 Location: uk
Member: 306676 Status: Offline Thanks Meter: 148 | LG K120E reset screenlock and FRP succesfully Reset screen lock succesfully Code: Welcome to Octoplus/Octopus Box LG Software version 3.0.5 Card S/N : 0000xxxxxx Selected USB connection type -------------------------------------------------------------------------------- Work ID: xxxxxxxx -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM5 Selected baudrate: 921600 Selected model: K120E Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM43 Mode: Emergency Initializing flash...OK Model ID: LG-K120E Platform: mt6735m Android version: 5.1.1 SW version: LGK120EAT-00-V10r-EUR-XX-APR-23-2018+0 LAF Version: 1.2 Product ID: CB45S170704002524 IMEI: xxxxxx-xx-xxxxxx-x Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: xxxxxx-xx-xxxxxx-x Bluetooth address: 88:36:5F:2D:CF:45 Wi-Fi MAC address: 88:36:5F:B0:DB:DE -------------------------------------------------------------------------------- Resetting Screen Lock... Resetting screen lock successfully completed! Performed by 3.0.5 Software version. Code: Selected USB connection type -------------------------------------------------------------------------------- Work ID: xxxxxxx -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM5 Selected baudrate: 0 Selected model: K120E Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM43 Mode: Emergency Initializing flash...OK Model ID: LG-K120E Platform: mt6735m Android version: 5.1.1 SW version: LGK120EAT-00-V10r-EUR-XX-APR-23-2018+0 LAF Version: 1.2 Product ID: CB45S170704002524 IMEI: xxxxxx-xx-xxxxxx-x Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: xxxxxx-xx-xxxxxx-x Bluetooth address: 88:36:5F:2D:CF:45 Wi-Fi MAC address: 88:36:5F:B0:DB:DE -------------------------------------------------------------------------------- Reading partitions...OK Resetting FRP Lock...OK Resetting FRP lock successfully completed! Performed by 3.0.5 Software version. |
11-15-2020, 14:51 | #6225 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | Lm-x510zw reset frp done Code: Welcome to Octoplus/Octopus Box LG Software version 3.0.6 Card S/N : 0000046C83 -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000001EA03F Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 0 Selected model: X510L Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM17 Mode: Emergency Initializing flash...OK Model ID: LM-X510ZW Platform: mt6750 Android version: 8.0.0 SW version: LMX510ZWAT-00-V10c-AME-XX-MAR-14-2019+0 LAF Version: 1.1 Product ID: CT68S180811000658 IMEI: 355389-09-005765-2 Target operator: LAO Hardware: rev_10 Battery level: 55% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 355389-09-005765-2 Bluetooth address: 00:57:C1:07:BE:33 Wi-Fi MAC address: 00:57:C1:A8:27:FC SPC: 000000 -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Authorizing...Failed! Login error: Wrong username! Performed by 3.0.6 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM28 Selected model: H830 Reading info... Model ID: LG-H830 IMEI: 356729-07-181170-1 Android version: 7.0 Battery level: 45% Mode: Normal Firmware compiled date: Sep 14 2017 Firmware compiled time: 23:00:00 Firmware released date: Feb 5 2018 Firmware released time: 22:05:41 SW Version: MPSS.TH.2.0.c1.4-00060-M8996FAAAANAZM- 1.114941.2a IMEI: 356729-07-181170-1 Bluetooth address: 5C:70:A3:F5:36:C4 Wi-Fi MAC address: 5C:70:A3:5F:F3:B3 SPC: 000000 Performed by 3.0.6 Software version. -------------------------------------------------------------------------------- Connecting to server ...OK Username: haki1969 Authorizing...OK Checking balance...OK Your balance: 200 credits. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000001EA683 Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 0 Selected model: X510L Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM17 Mode: Emergency Initializing flash...OK Model ID: LM-X510ZW Platform: mt6750 Android version: 8.0.0 SW version: LMX510ZWAT-00-V10c-AME-XX-MAR-14-2019+0 LAF Version: 1.1 Product ID: CT68S180811000658 IMEI: 355389-09-005765-2 Target operator: LAO Hardware: rev_10 Battery level: 55% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 355389-09-005765-2 Bluetooth address: 00:57:C1:07:BE:33 Wi-Fi MAC address: 00:57:C1:A8:27:FC SPC: 000000 -------------------------------------------------------------------------------- Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: haki1969 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 200 credits. To perform "Reset FRP" operation you need to have 100 credits. Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Resetting FRP Lock...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Resetting FRP lock successfully completed! Performed by 3.0.6 Software version. |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
