12-10-2020, 19:20 | #6241 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Work ID: 00000000003D59A9 Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: K500MM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM321 Mode: Emergency Initializing flash...OK Model ID: LM-K500MM Platform: mt6765 Android version: 10 SW version: LMK500MMAT-02-V10k-310-160-OCT-14-2020- ARB00+0 LAF Version: 1.1 Product ID: VP01S201015003870 IMEI: 354544-11-674750-1 Target operator: LAO Hardware: rev_10 Battery level: 100% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354544-11-674750-1 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "K500MM_354544116747501_10-12-2020_14- 14-08.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: xxxxxxx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 200 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.7.06 Software version. |
12-10-2020, 19:21 | #6242 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Selected USB connection type Work ID: 00000000003D27B2 Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: K500MM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM274 Mode: Emergency Initializing flash...OK Model ID: LM-K500MM Platform: mt6765 Android version: 10 SW version: LMK500MMAT-02-V10j-310-160-AUG-25-2020-ARB00 +0 LAF Version: 1.1 Product ID: VP01S200816004147 IMEI: 354544-11-433582-0 Target operator: LAO Hardware: rev_10 Battery level: 79% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354544-11-433582-0 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "K500MM_354544114335820_10-12-2020_11- 53-14.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: xxxxxxx Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.7.06 Software version. |
12-11-2020, 18:21 | #6243 (permalink) |
Freak Poster Join Date: Apr 2008 Location: A_1st™ Support Age: 38
Member: 758981 Status: Offline Sonork: 100.1592091 Thanks Meter: 232 | Unlock LMX410MK Metro Pcs Work ID: 00000000003E7F34 Checking data...11/12/2020 06:53:17 م > OK Platform: LG Qualcomm Selected port: COM17 Selected model: LMX410MK Reading info... Model ID: LM-X410MK IMEI: 355380-09********** Android version: 8.1.0 Battery level: 37% Mode: Emergency Initializing flash...11/12/2020 06:53:22 م > OK Platform: msm8937 SW version: 11/12/2020 06:53:23 م > LMX410MKAT-00-V20b-LAO-OSU-NOV-06-2018-ARB00+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: CB42S181116002707 IMEI: 355380-09-2******** Target operator: LAO Hardware: rev_10 Unlock operation for LMX410MK will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server...1 OK Octopus smart card is present. Checking smart card... OK Username: za***** Authorizing... OK Checking balance... OK Checking operation... OK Sending device information... OK Get credits, needed for current operation... OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Downloading... Check FTP file List FTP file List is obtained! Step 2... Extracting... Step 3... Initializing... Copying on SD Card... Found 1 portable devices transfer to E: Please, insert / reinsert SD Card into Phone. Then press "OK" button. Reading partitions... Checking data... Reconnecting phone... Initializing flash... Sending loader... Calculating. Please Wait... Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 3.0.7.08 Software version. |
12-12-2020, 03:07 | #6244 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Lg ls676 unlocked done Welcome to Octoplus/Octopus Box LG Software version 3.0.7 Card S/N : XXXXXXXXXX -------------------------------------------------------------------------------- Work ID: 00000000003EF190 Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: LS676 Reading info... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 3.0.7 Software version. -------------------------------------------------------------------------------- Work ID: 00000000003EF1C5 Checking data...OK Platform: LG Qualcomm Selected port: COM3 Selected model: LS676 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: LGLS676 Phone firmware version: LGLS676AT-00-ZV5-SPR-US-JUL-06- 2017+06 Short firmware version: ZV5 Kernel version: 3.10.49-gf2315c3 (lgmobile@LGEACI5R13) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Thu Jul 6 13:57:38 KST 201 Android version: 6.0.1 Hardware: Qualcomm Technologies, Inc MSM8909 0 Sending exploit...OK Executing exploit...OK Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 3.0.7 Software version. |
12-15-2020, 22:54 | #6245 (permalink) |
Junior Member Join Date: Nov 2008 Location: LIMA PERU
Member: 899787 Status: Offline Sonork: 1656438 Thanks Meter: 0 | Problem with this model LM-Q730TM Boost Mobile. It looks like OK but it didnt work. Help please. My credist were consumed. Welcome to Octoplus/Octopus Box LG Software version 3.0.6 Card S/N : 0001096C77 -------------------------------------------------------------------------------- Connecting to server ...OK Username: Lobito123 Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 000000000043CFCE Checking data...OK Platform: LG MTK Selected port: COM20 Selected baudrate: 921600 Selected model: Q730TM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM48 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Android version: 10 SW version: LMQ730TM3AT-00-V10i-310-120-JUL-02-2020-ARB00+0 LAF Version: 1.1 Product ID: VP01S200718003212 IMEI: 354527-11-510954-2 Target operator: LAO Hardware: rev_11 Battery level: 49% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354527-11-510954-2 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "Q730TM_354527115109542_15-12-2020_16-40-52.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Lobito123 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Reading partitions... Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.6 Software version------------------------------------------------------------------------------ Connecting to server ...OK Username: Lobito123 Authorizing...OK Checking balance...OK Your balance: 0 credits. |
12-21-2020, 13:01 | #6246 (permalink) |
Insane Poster Join Date: Dec 2018 Location: Venezuela
Member: 2885644 Status: Offline Thanks Meter: 29 | Unlock Phone pattern lock LG Stylo 2 Work ID: 00000000004B1513 Checking data...OK Plataforma: LG Qualcomm Puerto seleccionado: COM13 Modelo seleccionado: K450 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Lectura de la información... Model ID: LG-K540 IMEI: 000000-00-000000-0 Android version: 6.0.1 Battery level: 100% Mode: Emergency Initializing flash...OK Plataforma: msm8916 Versión de SW: LGK540AT-01-V10c-310-150-MAR-25-2016-ARB00+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT69S160622000568 IMEI: 357630-07-147706-4 Target operator: CRK Hardware: rev_10 Resetting Screen Lock... Reading partitions...OK Detecting writing method...OK Resetting screen lock successfully completed! Performed by 3.0.7.08 Software version. |
12-23-2020, 16:42 | #6247 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | LG K100 Read codes done: Code: Selected USB connection type Work ID: 00000000004EBB1F Checking data...OK Platform: LG MTK Selected port: Selected baudrate: 921600 Selected model: K100 Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM87 Mode: Emergency Initializing flash...OK Model ID: LG-K100 Platform: mt6737m Android version: 6.0.1 SW version: LGK100AT-00-V10b-222-01-FEB-17-2017+0 LAF Version: 1.1 Product ID: CB46S160829002425 IMEI: 351618-08-040055-3 Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI: 351618-08-040055-3 Bluetooth address: 2C:59:8A:CC:EE:25 Wi-Fi MAC address: 2C:59:8A:28:7A:89 SPC: 000000 -------------------------------------------------------------------------------- Reading codes...OK NCK: 6585 3673 4241 8015 NSCK: 6554 7725 5915 7928 SPCK: 0789 2436 6511 5220 CCK: 2329 2326 6354 2874 SIM: 3725 1871 9376 3084 HCK: 0000 0000 0000 0000 To finish the operation, please perform the following steps: 1. Insert the original SIM card or Motorola Test card and type 2945#*100# 2. Enter code. Performed by 3.0.7.03 Software version. |
12-24-2020, 17:22 | #6249 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Lg q730tm android 10 unlocked done Selected USB connection type Work ID: 0000000000506265 Checking data...OK Platform: LG MTK Selected port: COM3 Selected baudrate: 921600 Selected model: Q730TM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM65 Mode: Emergency Initializing flash...OK Model ID: LM-Q730TM Platform: mt6765 Android version: 10 SW version: LMQ730TM9AT-00-V10l-310-240-SEP-08-2020-ARB00+0 LAF Version: 1.1 Product ID: LS01S200926001338 IMEI: 354590-11-378357-7 Target operator: LAO Hardware: rev_11 Battery level: 45% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 354590-11-378357-7 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "Q730TM_354590113783577_24-12-2020_17-14-11.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: yuslamunique Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.7 Software version. |
12-26-2020, 14:24 | #6250 (permalink) |
No Life Poster Join Date: Apr 2006 Location: cameroon
Member: 260658 Status: Offline Thanks Meter: 184 | Welcome to Octoplus/Octopus Box LG Software version 3.0.7.08 Card S/N : 0000068869 -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000000520E89 Checking data...OK Platform: LG MTK Selected port: COM4 Selected baudrate: 460800 Selected model: K410EMW Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable.Canceled! Performed by 3.0.7.08 Software version. -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000000520FAB Checking data...OK Platform: LG MTK Selected port: COM4 Selected baudrate: 460800 Selected model: K410EMW Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM40 Mode: Emergency Initializing flash...OK Model ID: LM-K410EMW Platform: mt6765 Android version: 9 SW version: LMK410EMWAT-64-V10e-EEA-XX-AUG-20-2020+0 LAF Version: 1.1 Product ID: LCL1S200930312594 IMEI: 353671-11-445695-8 Target operator: LAO Hardware: rev_10 Battery level: 83% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 353671-11-445695-8 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "K410EMW_353671114456958_26-12-2020_14- 13-21.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: nyakamXXXX Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 230 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area... Initializing flash...OK Writing security area...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.7.08 Software version. |
12-26-2020, 14:24 | #6251 (permalink) |
01-07-2021, 17:38 | #6252 (permalink) |
Freak Poster Join Date: Mar 2013 Location: Pakistan
Member: 1908841 Status: Offline Sonork: 1654814 Thanks Meter: 48 | Lg G Stylo 6 lm-q730tm Unlocked Successfully Log file "C:\Program Files (x86)\Octoplus\Octoplus_LG\LOG\07-01-2021_20-17-07.log" created. 07/01/2021 8:17:11 pm > Searching for server... 07/01/2021 8:17:11 pm > Trying to ping server...07/01/2021 8:17:11 pm > ok 07/01/2021 8:17:11 pm > Trying connect to server... 07/01/2021 8:17:12 pm > Searching installed cards... 07/01/2021 8:17:12 pm > Found card with s/n: 100038963 07/01/2021 8:17:12 pm > Server check... 07/01/2021 8:17:13 pm > Server Check succesfull! 07/01/2021 8:17:13 pm > Server Check succesfull! 07/01/2021 8:17:17 pm > Welcome to Octoplus/Octopus Box LG Software version 3.0.8 07/01/2021 8:17:17 pm > Card S/N : 0100038963 07/01/2021 8:17:26 pm > INI FUpdateInfo Done! 07/01/2021 8:17:26 pm > INI FShowUpdateInfo start 07/01/2021 8:17:26 pm > INI FShowInfo start 07/01/2021 8:17:26 pm > INI FShowInfo show News Form 07/01/2021 8:27:07 pm > -------------------------------------------------------------------------------- 07/01/2021 8:27:07 pm > Selected USB connection type 07/01/2021 8:27:08 pm > Transport: Connected 07/01/2021 8:27:10 pm > Authorized. 07/01/2021 8:27:12 pm > Work ID: 000000000062280D 07/01/2021 8:27:12 pm > Checking data...07/01/2021 8:27:13 pm > OK 07/01/2021 8:27:13 pm > Platform: LG MTK 07/01/2021 8:27:13 pm > Selected port: COM1 07/01/2021 8:27:13 pm > Selected baudrate: 921600 07/01/2021 8:27:13 pm > Selected model: Q730TM 07/01/2021 8:27:14 pm > Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) 07/01/2021 8:27:14 pm > or 07/01/2021 8:27:14 pm > Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. 07/01/2021 8:27:45 pm > Phone found at port COM55 07/01/2021 8:27:45 pm > Mode: Emergency 07/01/2021 8:27:45 pm > Initializing flash...07/01/2021 8:27:48 pm > OK 07/01/2021 8:27:49 pm > Model ID: LM-Q730TM 07/01/2021 8:27:49 pm > Platform: mt6765 07/01/2021 8:27:49 pm > Android version: 10 07/01/2021 8:27:49 pm > SW version: LMQ730TM9AT-00-V10l-310-240-SEP-08-2020-ARB00+0 07/01/2021 8:27:49 pm > LAF Version: 1.1 07/01/2021 8:27:49 pm > Product ID: LS02S201029000992 07/01/2021 8:27:49 pm > IMEI: 354590-11-463381-3 07/01/2021 8:27:49 pm > Target operator: LAO 07/01/2021 8:27:49 pm > Hardware: rev_11 07/01/2021 8:27:49 pm > Battery level: 51% 07/01/2021 8:27:49 pm > Reading partitions...07/01/2021 8:27:49 pm > OK 07/01/2021 8:27:49 pm > LAF Error: 80000119. 07/01/2021 8:27:50 pm > Checking security...07/01/2021 8:27:50 pm > OK 07/01/2021 8:27:50 pm > Reading is Blocked! 07/01/2021 8:27:50 pm > -------------------------------------------------------------------------------- 07/01/2021 8:27:50 pm > IMEI: 354590-11-463381-3 07/01/2021 8:27:50 pm > Bluetooth address: Unknown 07/01/2021 8:27:50 pm > Wi-Fi MAC address: Unknown 07/01/2021 8:27:50 pm > -------------------------------------------------------------------------------- 07/01/2021 8:27:50 pm > Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? 07/01/2021 8:27:55 pm > Creating EEPROM backup... 07/01/2021 8:27:57 pm > Execute : 0x00AE 07/01/2021 8:27:57 pm > Writing cmd... 07/01/2021 8:27:57 pm > reading cmd... 07/01/2021 8:27:57 pm > reading cmd... 07/01/2021 8:27:58 pm > reading cmd... 07/01/2021 8:27:58 pm > reading cmd... 07/01/2021 8:27:58 pm > reading cmd... 07/01/2021 8:27:58 pm > reading cmd... 07/01/2021 8:27:58 pm > reading cmd... 07/01/2021 8:27:59 pm > reading cmd... 07/01/2021 8:27:59 pm > reading cmd... 07/01/2021 8:27:59 pm > reading cmd... 07/01/2021 8:27:59 pm > reading cmd...07/01/2021 8:27:59 pm > OK 07/01/2021 8:27:59 pm > Reconnecting phone... 07/01/2021 8:28:09 pm > Phone found at port COM63 07/01/2021 8:28:09 pm > Mode: Emergency 07/01/2021 8:28:09 pm > Initializing flash...07/01/2021 8:28:11 pm > OK 07/01/2021 8:28:11 pm > Reading security area... 07/01/2021 8:28:15 pm > Backup saved to "Q730TM_354590114633813_07-01-2021_20-27-55.EEP" 07/01/2021 8:28:15 pm > Connecting to server...07/01/2021 8:28:16 pm > OK 07/01/2021 8:28:16 pm > Octopus smart card is present. 07/01/2021 8:28:16 pm > Checking smart card...07/01/2021 8:28:23 pm > OK 07/01/2021 8:28:23 pm > Username: 07/01/2021 8:28:23 pm > Authorizing...07/01/2021 8:28:25 pm > Failed! 07/01/2021 8:28:25 pm > Login error: Wrong username! 07/01/2021 8:28:25 pm > Performed by 3.0.8 Software version. 07/01/2021 8:28:25 pm > Elapsed Time: 12:01:18 am 07/01/2021 8:28:40 pm > -------------------------------------------------------------------------------- 07/01/2021 8:28:40 pm > Connecting to server ...07/01/2021 8:28:42 pm > OK 07/01/2021 8:28:42 pm > Username: mnaveed 07/01/2021 8:28:42 pm > Authorizing...07/01/2021 8:28:45 pm > OK 07/01/2021 8:28:45 pm > Checking balance...07/01/2021 8:28:46 pm > OK 07/01/2021 8:28:46 pm > Your balance: 100 credits. 07/01/2021 8:28:54 pm > -------------------------------------------------------------------------------- 07/01/2021 8:28:54 pm > Selected USB connection type 07/01/2021 8:28:55 pm > Transport: Connected 07/01/2021 8:28:57 pm > Authorized. 07/01/2021 8:28:58 pm > Work ID: 00000000006228B7 07/01/2021 8:28:58 pm > Checking data...07/01/2021 8:28:59 pm > OK 07/01/2021 8:28:59 pm > Platform: LG MTK 07/01/2021 8:28:59 pm > Selected port: COM1 07/01/2021 8:28:59 pm > Selected baudrate: 921600 07/01/2021 8:28:59 pm > Selected model: Q730TM 07/01/2021 8:28:59 pm > Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) 07/01/2021 8:28:59 pm > or 07/01/2021 8:28:59 pm > Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. 07/01/2021 8:29:00 pm > Phone found at port COM63 07/01/2021 8:29:00 pm > Mode: Emergency 07/01/2021 8:29:00 pm > Initializing flash...07/01/2021 8:29:03 pm > OK 07/01/2021 8:29:04 pm > Model ID: LM-Q730TM 07/01/2021 8:29:04 pm > Platform: mt6765 07/01/2021 8:29:04 pm > Android version: 10 07/01/2021 8:29:04 pm > SW version: LMQ730TM9AT-00-V10l-310-240-SEP-08-2020-ARB00+0 07/01/2021 8:29:04 pm > LAF Version: 1.1 07/01/2021 8:29:04 pm > Product ID: LS02S201029000992 07/01/2021 8:29:04 pm > IMEI: 354590-11-463381-3 07/01/2021 8:29:04 pm > Target operator: LAO 07/01/2021 8:29:04 pm > Hardware: rev_11 07/01/2021 8:29:04 pm > Battery level: 51% 07/01/2021 8:29:04 pm > Reading partitions...07/01/2021 8:29:04 pm > OK 07/01/2021 8:29:04 pm > LAF Error: 80000119. 07/01/2021 8:29:05 pm > Checking security...07/01/2021 8:29:05 pm > OK 07/01/2021 8:29:05 pm > Reading is Blocked! 07/01/2021 8:29:05 pm > -------------------------------------------------------------------------------- 07/01/2021 8:29:05 pm > IMEI: 354590-11-463381-3 07/01/2021 8:29:05 pm > Bluetooth address: Unknown 07/01/2021 8:29:05 pm > Wi-Fi MAC address: Unknown 07/01/2021 8:29:05 pm > -------------------------------------------------------------------------------- 07/01/2021 8:29:05 pm > Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? 07/01/2021 8:29:09 pm > Creating EEPROM backup... 07/01/2021 8:29:11 pm > Execute : 0x00AE 07/01/2021 8:29:11 pm > Writing cmd... 07/01/2021 8:29:11 pm > reading cmd... 07/01/2021 8:29:12 pm > reading cmd... 07/01/2021 8:29:12 pm > reading cmd... 07/01/2021 8:29:13 pm > reading cmd... 07/01/2021 8:29:13 pm > reading cmd... 07/01/2021 8:29:13 pm > reading cmd... 07/01/2021 8:29:13 pm > reading cmd... 07/01/2021 8:29:13 pm > reading cmd... 07/01/2021 8:29:14 pm > reading cmd... 07/01/2021 8:29:14 pm > reading cmd... 07/01/2021 8:29:14 pm > reading cmd...07/01/2021 8:29:14 pm > OK 07/01/2021 8:29:14 pm > Reconnecting phone... 07/01/2021 8:29:21 pm > Phone found at port COM63 07/01/2021 8:29:21 pm > Mode: Emergency 07/01/2021 8:29:21 pm > Initializing flash...07/01/2021 8:29:23 pm > OK 07/01/2021 8:29:23 pm > Reading security area... 07/01/2021 8:29:27 pm > Backup saved to "Q730TM_354590114633813_07-01-2021_20-29-09.EEP" 07/01/2021 8:29:27 pm > Connecting to server...07/01/2021 8:29:28 pm > OK 07/01/2021 8:29:28 pm > Octopus smart card is present. 07/01/2021 8:29:28 pm > Checking smart card...07/01/2021 8:29:35 pm > OK 07/01/2021 8:29:35 pm > Username: mnaveed 07/01/2021 8:29:35 pm > Authorizing...07/01/2021 8:29:38 pm > OK 07/01/2021 8:29:38 pm > Checking balance...07/01/2021 8:29:40 pm > OK 07/01/2021 8:29:40 pm > Checking operation...07/01/2021 8:29:44 pm > OK 07/01/2021 8:29:44 pm > Sending device information...07/01/2021 8:29:47 pm > OK 07/01/2021 8:29:47 pm > Get credits, needed for current operation...07/01/2021 8:29:49 pm > OK 07/01/2021 8:29:49 pm > Your balance: 100 credits. 07/01/2021 8:29:49 pm > To perform "Unlock" operation you need to have 100 credits. 07/01/2021 8:29:57 pm > Unlocking...07/01/2021 8:29:57 pm > OK 07/01/2021 8:29:58 pm > Reading partitions...07/01/2021 8:29:58 pm > OK 07/01/2021 8:29:58 pm > Prepairing for change protect status... 07/01/2021 8:30:04 pm > Execute : 0x0040 07/01/2021 8:30:05 pm > Writing cmd... 07/01/2021 8:30:05 pm > reading cmd... 07/01/2021 8:30:05 pm > reading cmd... 07/01/2021 8:30:05 pm > Reconnecting phone... 07/01/2021 8:30:14 pm > Phone found at port COM63 07/01/2021 8:30:14 pm > Mode: Emergency 07/01/2021 8:30:14 pm > Initializing flash...07/01/2021 8:30:17 pm > OK 07/01/2021 8:30:17 pm > Removing write protection... 07/01/2021 8:30:19 pm > Execute : 0x00BF 07/01/2021 8:30:19 pm > Writing cmd... 07/01/2021 8:30:19 pm > reading cmd... 07/01/2021 8:30:20 pm > reading cmd...07/01/2021 8:30:20 pm > OK 07/01/2021 8:30:20 pm > Reconnecting phone... 07/01/2021 8:30:29 pm > Phone found at port COM63 07/01/2021 8:30:29 pm > Mode: Emergency 07/01/2021 8:30:29 pm > Initializing flash...07/01/2021 8:30:31 pm > OK 07/01/2021 8:30:33 pm > Reading partitions...07/01/2021 8:30:33 pm > OK 07/01/2021 8:30:33 pm > Erasing part 1... 07/01/2021 8:30:36 pm > Execute : 0x00C6 07/01/2021 8:30:36 pm > Writing cmd... 07/01/2021 8:30:36 pm > reading cmd... 07/01/2021 8:30:38 pm > Read: EXEC...07/01/2021 8:30:53 pm > OK 07/01/2021 8:30:53 pm > Reconnecting phone... 07/01/2021 8:30:56 pm > Phone found at port COM63 07/01/2021 8:30:56 pm > Mode: Emergency 07/01/2021 8:30:56 pm > Initializing flash...07/01/2021 8:30:58 pm > OK 07/01/2021 8:31:00 pm > Erasing part 2... 07/01/2021 8:31:03 pm > Execute : 0x00B0 07/01/2021 8:31:03 pm > Writing cmd... 07/01/2021 8:31:03 pm > reading cmd... 07/01/2021 8:31:04 pm > Read: EXEC...07/01/2021 8:31:19 pm > OK 07/01/2021 8:31:19 pm > Reconnecting phone... 07/01/2021 8:31:21 pm > Phone found at port COM63 07/01/2021 8:31:21 pm > Mode: Emergency 07/01/2021 8:31:21 pm > Initializing flash...07/01/2021 8:31:24 pm > OK 07/01/2021 8:31:25 pm > Reading partitions...07/01/2021 8:31:25 pm > OK 07/01/2021 8:31:27 pm > Prepairing for change protect status... 07/01/2021 8:31:31 pm > Execute : 0x0040 07/01/2021 8:31:31 pm > Writing cmd... 07/01/2021 8:31:31 pm > reading cmd... 07/01/2021 8:31:32 pm > reading cmd... 07/01/2021 8:31:32 pm > Reconnecting phone... 07/01/2021 8:31:41 pm > Phone found at port COM63 07/01/2021 8:31:41 pm > Mode: Emergency 07/01/2021 8:31:41 pm > Initializing flash...07/01/2021 8:31:43 pm > OK 07/01/2021 8:31:43 pm > Restore write protection... 07/01/2021 8:31:45 pm > Execute : 0x00BF 07/01/2021 8:31:45 pm > Writing cmd... 07/01/2021 8:31:46 pm > reading cmd... 07/01/2021 8:31:46 pm > reading cmd...07/01/2021 8:31:46 pm > OK 07/01/2021 8:31:46 pm > Reconnecting phone... 07/01/2021 8:31:55 pm > Phone found at port COM63 07/01/2021 8:31:55 pm > Mode: Emergency 07/01/2021 8:31:55 pm > Initializing flash...07/01/2021 8:31:57 pm > OK 07/01/2021 8:31:59 pm > Reading partitions...07/01/2021 8:31:59 pm > OK 07/01/2021 8:31:59 pm > Phone successfully unlocked! 07/01/2021 8:31:59 pm > Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! 07/01/2021 8:32:00 pm > Performed by 3.0.8 Software version. 07/01/2021 8:32:00 pm > Elapsed Time: 12:03:05 am |
01-07-2021, 19:40 | #6253 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Lg q730mm android 10 unlocked done Welcome to Octoplus/Octopus Box LG Software version 3.0.8 Card S/N : 0200086A77 -------------------------------------------------------------------------------- Selected USB connection type Work ID: 0000000000626CF8 Checking data...OK Platform: LG MTK Selected port: COM21 Selected baudrate: 921600 Selected model: Q730MM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM29 Mode: Emergency Initializing flash...OK Model ID: LM-Q730MM Platform: mt6765 Android version: 10 SW version: LMQ730MMAT-02-V10i-310-160-JUL-02-2020-ARB00 +0 LAF Version: 1.1 Product ID: VS02S200821009035 IMEI: XXXXXXXXXXXXXXX Target operator: LAO Hardware: rev_11 Battery level: 64% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: XXXXXXXXXXXXXXX Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "Q730MM_354525116509215_07-01-2021_19- 28-53.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: yuslamunique Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.8 Software version. |
01-11-2021, 13:43 | #6255 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Africa
Member: 1917743 Status: Offline Thanks Meter: 36 | LG Stylo 6 Q730MM unlock done -------------------------------------------------------------------------------- Selected USB connection type Work ID: 000000000066F4FE Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: Q730MM Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM442 Mode: Emergency Initializing flash...OK Model ID: LM-Q730MM Platform: mt6765 Android version: 10 SW version: LMQ730MMAT-02-V10l-310-160-SEP-08-2020-ARB00+0 LAF Version: 1.1 Product ID: LS03S201205001319 IMEI: 352769-xxxxxxxx8-1 Target operator: LAO Hardware: rev_11 Battery level: 92% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 3527xxxxxxxxx8-1 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Creating EEPROM backup...OK Initializing flash...OK Reading security area... Backup saved to "Q730MM_35xxxxxxxxxxxx1_11-01-2021_12-36-28.EEP" Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: 7nrpwvj Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Reading partitions...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.8 Software version. |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
