08-26-2019, 11:13 | #3 (permalink) | |
Junior Member Join Date: Nov 2016
Member: 2654550 Status: Offline Thanks Meter: 2 | Quote:
Please, select Reset FRP Method! To perform Reset FRP operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint. Found port COM593 Connecting...Failed! Performed by 2.9.2 Software version. Please, select Reset FRP Method! To perform Reset FRP operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint. Found port COM593 Connecting...Failed! Performed by 2.9.2 Software version. Please, select Reset FRP Method! To perform Reset FRP operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint. Found port COM593 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Searching signatures... Step 1... Step 2... Step 3... Step 4... Step 5... Error code: ASDQKEASDA Rebooting phone... Performed by 2.9.2 Software version. Please, select Reset FRP Method! To perform Reset FRP operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint. Found port COM593 Connecting...Failed! Performed by 2.9.2 Software version. Please, select Reset FRP Method! To perform Reset FRP operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint. Found port COM593 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Searching signatures... Step 1... Step 2... Step 3... Step 4... Step 5... Error code: ASDQKEASDA Rebooting phone... | |
08-26-2019, 11:16 | #4 (permalink) |
Member: 2654550 Status: Offline Thanks Meter: 2 | Welcome to Octoplus/Octopus Box LG Software version 2.8.9.7 Please select Reset FRP Method! To perform Reset FRP operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint. Found port COM10 Connecting...Failed! Performed by 2.8.9.7 Software version. Please select Reset FRP Method! To perform Reset FRP operation do the next: 1. Attach testpoint as shown on Figure in manual, and connect phone with Micro USB cable. 2. Check PC Device Manager, a new device should appear "Qualcomm HS- USB QDLoader 9008". 3. Release testpoint. Found port COM10 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Searching signatures... Step 1... Step 2... Step 3... Step 4... Step 5... Error code: ASDQKEASDA Rebooting phone... Performed by 2.8.9.7 Software version. |
08-26-2019, 11:53 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, use search, before opening threads: G6 bricked [Solved] |
08-26-2019, 12:08 | #6 (permalink) | |
https://drive.google.com/open?id=1T3...m88v_ZZ3GXWsvn | |
08-26-2019, 13:01 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You don't need that test Software version, the options which were added in that test Software version are already present in actual Software version what You have |
