03-13-2023, 04:13 | #1 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1452508 Status: Offline Sonork: Yenierms Thanks Meter: 4 | Unlock Failed LG V405UA SPR [Solved] Welcome to Octoplus/Octopus Box LG Software version 3.2.1 Card S/N : 0000067180 Connecting to server ...OK Authorizing...OK ----------------------------------------------------------- Work ID: 0000000001B6D15C Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: V405UA (SPR) Initializing ADB...OK Waiting for phone...OK Model ID: LM-V405UA Phone firmware version: LMV405AT-00-V15b-LAO-COM-JUN-07-2019- ARB00+0 Short firmware version: V15b Kernel version: 4.9.65-perf+ (lgmobile@LGEACI5R3) (gcc version 4.9.x 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Jun 7 09:45:25 KST 201 Android version: 8.1.0 Hardware: Qualcomm Technologies, Inc SDM845 AArch64 Processor rev 13 (aarch64) Carrier id: SPRINT Target operator: SPR Unlock operation for V405UA (SPR) will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: ady***** Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 110 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable) 3. Connect cable and press "Ok" button. Initializing flash...OK Platform: sdm845 SW version: LMV405UA3AT-00-V15b-310-120-JUN-07-2019-ARB00+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: PT01S180921000880 IMEI: 359583-09-*****-3 Target operator: LAO Hardware: rev_10 Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone...OK Initializing flash...OK Prepairing loader... Executing loader... Connecting to phone...OK Initializing flash...OK Initializing device... Checking data... Response is not received! Failed! Rebooting phone... Performed by 3.2.1 Software version. Any solution for this error ? Last edited by yenierms; 03-13-2023 at 04:20. |
03-13-2023, 11:17 | #3 (permalink) | |
Member: 1452508 Status: Offline Sonork: Yenierms Thanks Meter: 4 | Quote:
-------------------------------------------------------------------------------- Work ID: 00000000018CF283 Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: V405UA (SPR) Reading info... Model ID: LM-V405UA IMEI: 359583-09-******-3 Android version: 8.1.0 Battery level: 100% Mode: Emergency Initializing flash...OK Platform: sdm845 SW version: LMV405UA3AT-00-V15b-310-120-JUN-07-2019-ARB00+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: PT01S180921000880 IMEI: 359583-09-******-3 Target operator: LAO Hardware: rev_10 Unlock operation for V405UA (SPR) will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: adyu***** Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 110 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Can't found Micro SD cards Please, connect Micro SD card to PC, then press "OK" button! Can't found Micro SD cards Please, connect Micro SD card to PC, then press "OK" button! Can't found Micro SD cards Please, connect Micro SD card to PC then repeat operation again. NOTE: SD card must be formatted in FAT or FAT32 file system and size must be lower than 32 GB! Failed! Rebooting phone... Performed by 3.2.1 Software version. | |
03-14-2023, 00:57 | #8 (permalink) | |
-------------------------------------------------------------------------------- Work ID: 00000000018D3865 Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: V405UA (SPR) Initializing ADB...OK Waiting for phone...OK Model ID: LM-V405UA Phone firmware version: LMV405AT-00-V15b-LAO-COM-JUN-07-2019- ARB00+0 Short firmware version: V15b Kernel version: 4.9.65-perf+ (lgmobile@LGEACI5R3) (gcc version 4.9.x 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Jun 7 09:45:25 KST 201 Android version: 8.1.0 Hardware: Qualcomm Technologies, Inc SDM845 AArch64 Processor rev 12 (aarch64) Carrier id: SPRINT Target operator: SPR Unlock operation for V405UA (SPR) will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: ady*** Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 110 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable) 3. Connect cable and press "Ok" button. Initializing flash...OK Platform: sdm845 SW version: LMV405UA3AT-00-V15b-310-120-JUN-07-2019-ARB00+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: PT01S180921000880 IMEI: 359583-09-*****-3 Target operator: LAO Hardware: rev_10 Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone...OK Initializing flash...OK Prepairing loader... Executing loader... Connecting to phone...OK Initializing flash...OK Initializing device... Checking data... Response is not received! Failed! Rebooting phone... Performed by 3.2.1 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001DDFEDC Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: V405UA (SPR) Initializing ADB...OK Waiting for phone...OK Model ID: LM-V405UA Phone firmware version: LMV405AT-00-V15c-LAO-COM-JUL-22-2019- ARB00+0 Short firmware version: V15c Kernel version: 4.9.65-perf+ (lgmobile@LGEACI4R11) (gcc version 4.9.x 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Jul 22 10:08:57 KST 201 Android version: 8.1.0 Hardware: Qualcomm Technologies, Inc SDM845 AArch64 Processor rev 13 (aarch64) Carrier id: SPRINT Target operator: SPR Unlock operation for V405UA (SPR) will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: ady**** Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 110 credits. To perform "Unlock" operation you need to have 100 credits. Prepairing loader... Step 1... Step 2... Step 3... Copying on SD Card... Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable) 3. Connect cable and press "Ok" button. Initializing flash...OK Platform: sdm845 SW version: LMV405UA3AT-00-V15c-310-120-JUL-22-2019-ARB00+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: PT01S180921000880 IMEI: 359583-09-*****-3 Target operator: LAO Hardware: rev_10 Reading partitions... Checking data... Connecting to phone...OK Initializing flash...OK Sending loader... Connecting to phone...OK Initializing flash...OK Prepairing loader... Executing loader... Connecting to phone...OK Initializing flash...OK Initializing device... Checking data... Reading SIMLOCK... Sending data to server... Obtaining response... Unlocking... Phone successfully unlocked! Rebooting phone... Performed by 3.2.1 Software version. Thank you very much, with firmware version 15c the unlock worked. | |
The Following User Says Thank You to yenierms For This Useful Post: |
