Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 08-02-2018, 17:28   #1 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 86
Thumbs up Unlock LG LM-X210CM question [Solved]
Hello
Is it possible to unlock LG LM-X210CM?
thanks
Old 08-02-2018, 21:00   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 26,803
Hello.
Yes, "Unlock" operation is supported for this device model. Try and post here the result.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 08-02-2018, 21:19   #3 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 86
How can I model X210?
Old 08-03-2018, 05:05   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Please select LMX210CM is the list of Software and read attentively Software manual ("Help" button in Software) on how to perform the "Unlock" operation.
Old 10-31-2018, 09:12   #5 (permalink)
Member: 558861
Thanks Meter: 26
after unlock phone still lock asking unlock code any solution ?
Old 10-31-2018, 09:16   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
Please read this rules: http://forum.gsmhosting.com/vbb/f799...leted-2165821/.
Old 11-04-2018, 22:30   #7 (permalink)
Member: 2529251
Thanks Meter: 273
Phone is still locked and asking for code
Welcome to Octoplus/Octopus Box LG Software version 2.8.9
Checking data...OK
Platform: LG Qualcomm
Selected port: COM880
Selected model: LMX210CM
Reading info...
Model ID: LM-X210APMX210APM10c
IMEI: 353934-09-110340-1
Android version: 7.1.2
Battery level: 99%
SW Version: X210APM10c
Mode: Normal
Firmware compiled date: Dec 21 2017
Firmware compiled time: 05:00:00
Firmware released date: Jun 4 2018
Firmware released time: 18:54:00
SW Version: MPSS.JO.3.0.c8-00004-8937_GENNS_PACK-1
Bluetooth address: 084:6A:9C:12:AA
Wi-Fi MAC address: 00:57:C1:A8:8A:3C
SPC: 000000
Unlocking...
Write security backup function doesn't work for this device with latest
firmware versions. If you'll encounter any problem during Unlock operation
- you won't be able to restore the phone to it's initial state, so proceed at
your own risk.
Continue?
Reading QCN...
Send SPC...OK
Reading Mobile Property...OK
Reading Feature Mask...OK
Reading Roaming List 0...OK
Reading NV_Numbered Items...OK
Reading NV_Numbered SIM1 Items...OK
Reading NV_Numbered SIM2 Items...OK
Reading NV Items...OK
Reading EFS...OK
Reading Provisioning Items...OK
Reading QCN done!
Backup saved to "LMX210CM_353934091103401_04-11-2018_16-22-
02.qcn"
Switching to Download mode...OK
Initializing flash...OK
Reading partitions...OK
Detecting writing method...
LAF Error: 80000121.
Trying second method...
Trying third method...OK
Reading security area...OK
Backup saved to "LMX210CM_353934091103401_04-11-2018_16-24-
56.SEC"
Writing security area...OK
Switching to Normal mode...
Found model LMX210AP: ÿh at port COM880
Send SPC...OK
Writing QCN...
Writing NV_Numbered Items...OK
Writing NV_Numbered SIM1 Items...OK
Writing NV_Numbered SIM2 Items...OK
Writing QCN done!
Phone successfully unlocked!
Rebooting phone...
Performed by 2.8.9 Software version.
PHONE IS STILL LOCKED AND ASKING FOR CODE
Old 11-05-2018, 05:30   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
Hello.
There is new security type in your device, You need to use (install) the latest Software version v.2.8.9.7 from the Support Area (here is direct link for You: https://drive.google.com/open?id=1Rg...RZkVLoaDAgJmkG). "Unlock" operation for devices with new security is server based and requires 50 Octoplus Server Credits. You can buy Octopus/Octoplus Server Credits from your local reseller or directly HERE. You will get Username, Password and Credits on your account.
To unlock the device do the following:
1. Reboot the device.
2. Run Software.
3. Select (check) "Skip Read/Write QCN..." option in Software.
4. Perform the "Unlock" operation.
Post here the result.
Old 11-06-2018, 19:27   #9 (permalink)
Member: 1931081
Thanks Meter: 9
Checking data...OK
Selected port: COM5
Reading info...
Model ID: LM-X210CM
IMEI: 35XXXX-XX-XXXXX-7
Battery level: 63%
SW Version: X210CM10h
Mode: Normal
Firmware compiled date: Jun 20 2018
Firmware compiled time: 06:00:00
Firmware released date: Jul 5 2018
Firmware released time: 20:00:53
SW Version: MPSS.JO.3.0.c12-00013-8937_GENNS_PACK-1
Bluetooth address: 00:XX:XX:XX:XX:XX
Wi-Fi MAC address: 00:XX:XX:XX:XX:XX
SPC: 000000
Unlocking...
Initializing ADB...OK
Waiting for phone...OK
Connecting to server...OK
Octopus smart card is present.
Checking smart card...OK
Username: XXXXXXXXXX
Authorizing...OK
Checking balance...OK
Checking operation...OK
Get credits, needed for current operation...OK
Your balance: 75 credits.
To perform "Unlock" operation you need to have 50 credits.
your own risk.
Continue?
Skip Read/Write QCN
Backup saved to "LMX210CM_35XXXXXXXXX_06-11-2018_12-07-
14.SEC"
Found model LMX210CM* ÿh at port COM5
Authorizing...OK
Sending device information...OK
Finalizing...
Rebooting phone...
Performed by 2.8.9.8 Software version.
SUCCEFULLY UNLOCK READY 50 CREDITS
The Following User Says Thank You to CARSACELL For This Useful Post:
Old 11-06-2018, 21:34   #10 (permalink)
Member: 2279568
Thanks Meter: 2
i have the same model from cricket i previously unlocked with octopus box with succes but after the phone force update i block the phone permanently,my question is if i can fix that or unlocked again with the new unlock by server ?
Old 11-07-2018, 01:14   #11 (permalink)
Member: 2122242
Thanks Meter: 59
Hi guys, please help me...
He says he has been released successfully, but he keeps saying Network Blocked
Checking data...OK
Plataforma: LG Qualcomm
Puerto seleccionado: COM22
Modelo seleccionado: LMX210CM
Lectura de la información...
Model ID: LM-X210CM
IMEI: 354376********
Battery level: 51%
Versión de SW: X210CM10j
Mode: Normal
Firmware released date: Aug 14 2018
Firmware released time: 18:58:34
Versión de SW: MPSS.JO.3.0.c12-00013-8937_GENNS_PACK-1
Dirección de Bluetooth: 00:57:C1:05:48:35
Wi-Fi MAC address: 00:57:C1:AE:20:1D
SPC: 000000
Liberación...
Username: sergiosierra
Authorizing...OK
Your balance: 51 credits.
your own risk.
Continue?
Reading QCN...
Send SPC...OK
Reading EFS...OK
Reading QCN done!
Backup reservado en "LMX210CM_354376******** 06-11-2018_17-44-
31.qcn"
Cambio para Modo de Download...OK
Lectura de la zona de seguridad...OK
Backup reservado en "LMX210CM_354376******** 06-11-2018_17-50-
47.SEC"
Escritura de la zona de seguridad...OK
Found model LMX210CM*	ÿh at port COM22
Send SPC...OK
Writing QCN...
Writing QCN done!
Authorizing...OK
Finalización...
¡El teléfono está liberado con éxito!
Rebooting phone...
regards!!!
Old 11-07-2018, 02:11   #12 (permalink)
Member: 2122242
Thanks Meter: 59
This appears to me after trying to unlock.
Old 11-07-2018, 06:31   #13 (permalink)
Member: 1146942
Sonork: 100.1587278
Hi.
We have added 50 credits to your account, please check your balance. Please do Factory data reset, run Software, check "Skip QCN..." option and repeat the "Unlock" operation again. Post here the result.
Old 11-07-2018, 22:41   #14 (permalink)
Member: 2122242
Thanks Meter: 59
Lg lmx210cm
Hi.
Thank you for your support, after Factory Reset..... UNLOCK DONE!!!
Checking data...OK
Model ID: LM-X210CM
IMEI: 354376-**-******-*
Battery level: 60%
Mode: Normal
IMEI: 354376-09-318989-8
SPC: 000000
Liberación...
Authorizing...OK
your own risk.
Continue?
Skip Read/Write QCN
Backup reservado en "LMX210CM_354376-**-******-*_07-11-2018_15-27-
03.SEC"
Authorizing...OK
Finalización...
Rebooting phone...
Regards!!!
The Following User Says Thank You to sergiosierra For This Useful Post:
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.20833 seconds with 7 queries
