08-03-2020, 11:21 | #1 (permalink) |
Insane Poster Join Date: Aug 2010
Member: 1357861 Status: Offline Thanks Meter: 18 | unlock lg x430emw not done help me [Solved] Connecting to server ...OK Username: hamzoun260 Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: Selected baudrate: 921600 Selected model: X430EMW Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM144 Mode: Emergency Initializing flash...OK Model ID: LM-X430EMW Platform: mt6765 Android version: 9 SW version: LMX430EMWAT-64-V10j-EEA-XX-MAY-07-2020+0 LAF Version: 1.1 Product ID: 02PAB621FE7Y00H3T IMEI: 358854-10-457627-5 Target operator: LAO Hardware: rev_10 Battery level: 25% Reading partitions...OK LAF Error: 00000000. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 358854-10-457627-5 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: hamzoun260 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area...Failed! Performed by 2.9.8 Software version. ------------------------------------------------------------------ |
08-03-2020, 12:08 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello. Please download and install latest test software version 3.0.2.04 from the Support Area (LG/TEST SOFTWARE/), put the phone into download mode then repeat the operation once again. We added you one more attempt. Quote:
The Following User Says Thank You to Octopus support For This Useful Post: |
08-03-2020, 13:07 | #3 (permalink) |
Member: 1357861 Status: Offline Thanks Meter: 18 | thank you bro Connecting to server ...OK Username: hamzoun260 Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM116 Selected baudrate: 921600 Selected model: X430EMW Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM116 Mode: Emergency Initializing flash...OK Model ID: LM-X430EMW Platform: mt6765 Android version: 9 SW version: LMX430EMWAT-64-V10j-EEA-XX-MAY-07-2020+0 LAF Version: 1.1 Product ID: 02PAB621FE7Y00H3T IMEI: 358854-10-457627-5 Target operator: LAO Hardware: rev_10 Battery level: 38% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 358854-10-457627-5 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: hamzoun260 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Unlock" operation you need to have 100 credits. Unlocking...OK Writing security area... Initializing flash...OK Writing security area...OK Initializing flash...OK Prepairing for change protect status... Initializing flash...OK Removing write protection...OK Initializing flash...OK Reading partitions...OK Erasing part 1...OK Initializing flash...OK Erasing part 2...OK Initializing flash...OK Prepairing for change protect status... Initializing flash...OK Restore write protection...OK Initializing flash...OK Reading partitions...OK Phone successfully unlocked! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.2.04 Software version. |
The Following User Says Thank You to titigsm25 For This Useful Post: |
