03-02-2015, 23:15 | #1 (permalink) |
No Life Poster Join Date: Nov 2011 Location: mexico
Member: 1681847 Status: Offline Thanks Meter: 103 | LG LS980 cant acces without SPC Last edited by Octopus box; 03-03-2015 at 07:13. |
03-03-2015, 04:41 | #2 (permalink) | |
Member: 1681847 Status: Offline Thanks Meter: 103 | Got it working. I returned to ZV8 firmware and got it to read SPC. Now that I have acces I have unlocked, repair NVM and reapaired QCN with support file. But I still get a message that sim card is not in cellphone Quote:
03-04-2015, 04:40 | #4 (permalink) | |
Member: 1681847 Status: Offline Thanks Meter: 103 | Quote:
Also tried same process with version ZV8. Also tried with QNC file and still nothing. sometimes I get a signal and go's every 1 minute. Any ideas what I can do. Do you have NVM from a working LS980? PS-PHONE HISTORY: phone was working great and unlocked before but tried to update with cyanogen 12 and now NO signal. | |
03-04-2015, 07:27 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to change (to configure) settings in file "build.prop" inside of phone. Search in XDA forum how to do this. Also, look here: http://forum.gsmhosting.com/vbb/f799...olved-1920734/ and ask mr. razib143 in PM, he will help You. Then say here the result. |
03-05-2015, 05:32 | #6 (permalink) | |
03-05-2015, 11:05 | #7 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Hello, Did you modified build.prop properly like this??? follow these steps. adb pull /system/build.prop adb shell su exit exit now.... build.prop modified time... with Notepad++ From these sentence to ... ro.carrier=unknown ro.build.target_operator=SPR persist.service.crash.enable=0 ro.telephony.default_network=10 telephony.lteOnCdmaDevice=1 should be change these..... ( Case Sensitive ) ro.carrier=spr ro.build.target_operator=spr persist.service.crash.enable=1 ro.telephony.default_network=0 telephony.lteOnCdmaDevice=0 Save the build.prop and use ADB to push it to the sdcard. now insert build.prop file into the phone via ADB command.. adb push build.prop /sdcard/ adb shell su mount -o remount,rw /system cp /sdcard/build.prop /system/ mount -o remount,ro /system reboot Here modified build.prop file myself for you... For Sprint... Link.... Let us inform if done.... Best of luck... |
03-06-2015, 03:49 | #8 (permalink) | |
downloaded your build.prop file 1. flashed fresh version of ZV8 2. usb dubugging enable 3. towelroot 4. installed root browser 5. pushed build.prop file to SDCARD folder 6. inserted bild.prop to SYSTEM folder 7. checked if build.prop was new file ( it was changed with your settings ) 8. reboot 9. many popup errores liek google apps crashing, chrome stoped working etc.. Like I said did it twice with fresh firmware and same results. | |
03-06-2015, 13:11 | #9 (permalink) | |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Quote:
Then now do this for your SIM and Network.... Copy All file and Folders from carrier to /carrier/ ( inside phone by root explore ) Then Reboot File is here.... Hope now it will be done... Best of Luck... | |
04-04-2015, 21:50 | #10 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
@Revolution Cel Bro Your Problem Solved? I Am Also Facing Problem Same Like Yours If Yes I Need Your Help Plz Thanks Anticipation Last edited by Octopus box; 04-05-2015 at 08:14. | |
04-05-2015, 08:18 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to write firmware from the Support Area, than make Unlock, write QCN from the Support Area and make Repair Network. |
