01-10-2019, 02:23 | #1 (permalink) |
Freak Poster Join Date: Sep 2014
Member: 2257452 Status: Offline Thanks Meter: 16 | X212TA Reset FRP problem [Answered] Welcome to Octoplus/Octopus Box LG Software version 2.8.9.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM137 Selected model: LMX212TA Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info...Failed! Port busy Performed by 2.8.9.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM2677 Selected model: LMX212TA Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X212TA IMEI: 356351-09-411975-4 Android version: 8.1.0 Battery level: 70% SW Version: X212TA20c Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX212TAAT-01-V20c-310-260-NOV-22-2018-ARB00+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: YS91S181126003136 IMEI: 356351-09-411975-4 Target operator: LAO Hardware: rev_10 Reset FRP operation for LMX212TA will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Resetting FRP Lock...Failed! Performed by 2.8.9.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM2677 Selected model: LMX212TA Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X212TA IMEI: 356351-09-411975-4 Android version: 8.1.0 Battery level: 67% SW Version: X212TA20c Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX212TAAT-01-V20c-310-260-NOV-22-2018-ARB00+0 Android version: 8.1.0 LAF Version: 1.1 Product ID: YS91S181126003136 IMEI: 356351-09-411975-4 Target operator: LAO Hardware: rev_10 Reset FRP operation for LMX212TA will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Detecting writing method... Trying third method...Failed! Resetting FRP Lock...Failed! Performed by 2.8.9.8 Software version. Last edited by Octopus box; 01-10-2019 at 07:38. |
