06-04-2020, 19:32 | #1 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2607892 Status: Offline Thanks Meter: 0 | X540EMW Repair IMEI issue [Answered] Card S/N : 01000068E6 -------------------------------------------------------------------------------- Platform: LG MTK Selected port: COM22 Selected baudrate: 921600 Selected model: X540EMW Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM63 Mode: Emergency Initializing flash...OK Model ID: LM-X540HM Platform: mt6765 Android version: 9 SW version: LMX540HMAT-00-V10a-334-020-MAR-09-2020+3 LAF Version: 1.1 Product ID: CB42S191121002056 IMEI: 358946-10-072439-4 Target operator: LAO Hardware: rev_10 Battery level: 19% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 358946-10-072439-4 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Performed by 3.0.2.02 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM63 Selected baudrate: 0 Selected model: X540EMW Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM63 Mode: Emergency Initializing flash...OK Model ID: LM-X540HM Platform: mt6765 Android version: 9 SW version: LMX540HMAT-00-V10a-334-020-MAR-09-2020+3 LAF Version: 1.1 Product ID: CB42S191121002056 IMEI: 358946-10-072439-4 Target operator: LAO Hardware: rev_10 Battery level: 19% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 358946-10-072439-4 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: Authorizing...Failed! Login error: Wrong username! Performed by 3.0.2.02 Software version. -------------------------------------------------------------------------------- Connecting to server ...OK Username: oct_tVOK5jS Authorizing...OK Checking balance...OK Your balance: 100 credits. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM63 Selected baudrate: 0 Selected model: X540EMW Selected USB connection type Please, disconnect cable, power phone OFF, connect P999 cable (with 910k resistor) or Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM63 Mode: Emergency Initializing flash...OK Model ID: LM-X540HM Platform: mt6765 Android version: 9 SW version: LMX540HMAT-00-V10a-334-020-MAR-09-2020+3 LAF Version: 1.1 Product ID: CB42S191121002056 IMEI: 358946-10-072439-4 Target operator: LAO Hardware: rev_10 Battery level: 19% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI A: 358946-10-072439-4 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: oct_tVOK5jS Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Fixing IMEI... New IMEI A: 358946-10-072541-7 Patching security... Writing security area... Reconnecting phone... Phone found at port COM63 Mode: Emergency Initializing flash...OK Prepairing for change protect status... Reconnecting phone... Phone found at port COM63 Mode: Emergency Initializing flash...OK Removing write protection...OK Reconnecting phone... Phone found at port COM63 Mode: Emergency Initializing flash...OK Reading partitions...OK Erasing part 1...OK Reconnecting phone... Phone found at port COM63 Mode: Emergency Initializing flash...OK Prepairing for change protect status... Reconnecting phone... Phone found at port COM63 Mode: Emergency Initializing flash...OK Restore write protection...OK Reconnecting phone... Phone found at port COM63 Mode: Emergency Initializing flash...OK Reading partitions...OK IMEI successfully fixed! Warning: If your device were stuck at logo, after operation was completed, then please, don't reflash your device, first contact with Support via Skype or create thread at forum! Performed by 3.0.2.02 Software version. |
06-05-2020, 08:20 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,388 | Hello. You should accept Software updates, when Software is starting! We've added You one more attempt, please download and install Octoplus LG tool 3.0.2.3 version from Support Area and repeat operation again |
