01-13-2013, 14:45 | #1 (permalink) |
Freak Poster Join Date: Jun 2012
Member: 1769097 Status: Offline Sonork: 1001597271 Thanks Meter: 35 | samsung e189 cdma user code? i want to know what i missing i want to unlock user code for this model and i install all this soft office , adobe reader , java , dotnet40 , via drivers , USB_Download_for_VIA_1.3 , SamsungPST_E189 For Verizon 1.0.004 and after all that message show to me no port connect where is the problem ? |
01-14-2013, 07:33 | #2 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 365730 Status: Offline Thanks Meter: 84 | Try this:-http://forum.gsmhosting.com/vbb/f128...6/#post8517209 and do rebuild or usb rebuild Last edited by hitesh2000; 01-14-2013 at 07:41. |
The Following User Says Thank You to hitesh2000 For This Useful Post: |
01-14-2013, 08:20 | #3 (permalink) | |
Member: 1769097 Status: Offline Sonork: 1001597271 Thanks Meter: 35 | Quote:
01-14-2013, 10:20 | #4 (permalink) |
Member: 365730 Status: Offline Thanks Meter: 84 | what problem you are facing be more specific. procedure is simple, open software select port go for rebuid or usb rebuild |
01-15-2013, 12:04 | #6 (permalink) |
Member: 365730 Status: Offline Thanks Meter: 84 | brother you must be selecting wrong port.select appropriate port and go for rebuild, work on almost all Samsung(cdma) models.after rebuild efs area of the phone is erased ,phone rewrite this area with company settings,so you will get default password after rebuild. |
01-16-2013, 08:14 | #7 (permalink) | |
thankyou for your reporting but i do scan then select port and do rebuild and say please wait for repoting but no thing happens | |
01-17-2013, 08:07 | #8 (permalink) | |
Member: 365730 Status: Offline Thanks Meter: 84 | Quote:
1:you are selecting wrong port go for other port. when you attach mobile you will see two new port so go for other one or simply try serial port uart cable. 2:mobile not support rebuild command.In this you can try with original PST. | |
01-17-2013, 08:32 | #9 (permalink) | |
say no port connect in device manger com show same com in program but always show this message no port connect is there any special driver or programe to fix this problem thankyou | |
01-17-2013, 13:32 | #10 (permalink) | |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
Did You Try With This PST ? : SamsungPST_E189 For Verizon 1.0.004.msi If Yes Then Please Contact Me, By PM Or Yahoo. | |
The Following User Says Thank You to MyGSM World For This Useful Post: |
02-05-2014, 12:42 | #12 (permalink) | |
Freak Poster Join Date: Jun 2006 Location: Pendora Age: 45
Member: 299122 Status: Offline Sonork: 1658277 Thanks Meter: 54 | Quote:
Thanks in advance cmaster | |
