11-01-2009, 04:52 | #1 (permalink) |
Registered User Join Date: Jan 2008 Location: India
Member: 690799 Status: Offline Thanks Meter: 157 | samsung b239 & other cdma model no incoming & outgoing very big problem Now these days , we observe , very frequently coming incoming & outgoing call problem ever there is a full network in Samsung CDma handsets like B239 etc. If any one have this soloution for it plz post here. what we have tried is :- 1. full flash 2. rebuild 3. nam change but no soloution except PA change (we got success after change pa). but PA availability in the market is very rare. so we need any other solution. thanks in advance. |
The Following 2 Users Say Thank You to nakshatra For This Useful Post: |
11-01-2009, 11:21 | #2 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 659890 Status: Offline Thanks Meter: 263 | Quote:
01-24-2010, 16:17 | #4 (permalink) | |
Junior Member Join Date: Jul 2006
Member: 312822 Status: Offline Thanks Meter: 3 | Quote:
03-09-2010, 05:46 | #6 (permalink) | |
Freak Poster Join Date: Jun 2007
Member: 524163 Status: Offline Sonork: 1589680 Thanks Meter: 33 | Quote:
03-14-2010, 18:47 | #8 (permalink) |
Member: 312822 Status: Offline Thanks Meter: 3 | No way when u touch the pa it gets hot.i have replaced PA from dead set and mobile is working fine so do not wast time. the only solution for all cdma sets with same problem is change PA. this problem comes in all cdma. so please try to find jumper for PA |
03-14-2010, 18:58 | #9 (permalink) | |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | Quote:
here is the solution open any rebuilding software connect cable by usb to serial or simple serial interface click rebuild notice Auto test appears on screen remove cable atonce now set showing only auto test now > all test commands u can visit or go through find rx tx gain u have to calibrate it have a good set to compare u can easily calibrate the network thats all br, | |
03-15-2010, 19:42 | #11 (permalink) |
Freak Poster Join Date: Oct 2004 Location: KADAPA, A.P. INDIA. Age: 52
Member: 86802 Status: Offline Thanks Meter: 457 | Instead of Using USB Cable to rebuild models like b239 and b259; remove the serial number sticker, You will find the IF Jack for SW & rebuild below this Sticker. Use rx tx & gnd connections. Connect it infinity and use infinity post in pst, use SCH-S269 PST to rebuild the set. Your problem will be solved. Don't tamper hardware by changing pa, etc. This solution is already tested by me. Screenshot or log cannot be posted for this complaint. You guys too can test and post your valuable report for the other users of this great forum. Regards, Etool30 |
07-23-2010, 21:31 | #13 (permalink) | |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,827 | Quote:
Haier c2000/3010/5000/6000 etc, full network but no incoming & outgoing call | nakshatra | Various CDMA/TDMA Cell Phones | 12 | 10-04-2013 20:16 |
1100 no incomeing & no outgoing | hasanphone | Nokia Hardware & Hardware Repair | 2 | 02-13-2008 16:12 |
3105 no incoming only outgoing. | shoeb7 | Nokia CDMA | 3 | 08-07-2006 20:31 |
TM 100 no incoming & outgoing calls !!!!! | Yashaka | Sharp | 4 | 11-10-2004 17:31 |
t100 no incomeing & outgoing | SATISH | Samsung Hardware Repair | 5 | 08-09-2004 09:28 |
