Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 08-02-2018, 19:04   #1 (permalink)
TechPhone's Avatar
Member: 41672
Thanks Meter: 195
Angry B310s-927 only power led on (dead recovery)
Huawei B310s-927 only power led on (dead recovery)
how to recover pls. give solution and file
thanks
Old 08-05-2018, 13:58   #2 (permalink)
kamikazizs's Avatar
Member: 2695426
Thanks Meter: 1,453
thanks
If you understand arabic this is the solution :
https://www.youtube.com/watch?v=UrW74-f_OyQ
The Following User Says Thank You to kamikazizs For This Useful Post:
Old 08-05-2018, 19:09   #3 (permalink)
TechPhone's Avatar
Member: 41672
Thanks Meter: 195
Angry
thanks 4 reply and solution successfully review
thanks
Old 09-04-2018, 12:02   #4 (permalink)
alirazamanzoor's Avatar
Member: 2562113
Sonork: alirazamanzoor
Thanks Meter: 89
thanks
you need to erase your bad block via fastboot
load usbloader.bin in fastboot via (balong_dload -f usbloader.bin ) and then erase all parts.
fastboot -i0x12d1 erase fastboot
@rem fastboot -i0x12d1 erase nvbacklte
@rem fastboot -i0x12d1 erase nvdefault
fastboot -i0x12d1 erase nvdload
fastboot -i0x12d1 erase oeminfo
fastboot -i0x12d1 erase kernel
fastboot -i0x12d1 erase kernelbk
fastboot -i0x12d1 erase m3image
fastboot -i0x12d1 erase dsp
fastboot -i0x12d1 erase misc
fastboot -i0x12d1 erase vxworks
fastboot -i0x12d1 erase wbdata
fastboot -i0x12d1 erase reserve2
fastboot -i0x12d1 erase reserve3
fastboot -i0x12d1 erase om
fastboot -i0x12d1 erase app
fastboot -i0x12d1 erase webui
fastboot -i0x12d1 erase system
fastboot -i0x12d1 erase userdata
fastboot -i0x12d1 erase online
fastboot -i0x12d1 erase cdromiso
device will be reboot in 12D1 .done it
The Following User Says Thank You to alirazamanzoor For This Useful Post:
Old 12-10-2022, 03:41   #5 (permalink)
Member: 1899668
Thanks Meter: 3
Simply burn with the "Balong_USB_Downloader exe" the file: "Fix b310s Leds and Boot bin"
Page generated in 0.16824 seconds with 8 queries
