GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
11-18-2016, 14:00 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2014 Location: Planet, Earth
Member: 2249268 Status: Offline Sonork: 1671720 Thanks Meter: 47 | HOW TO UNLOCK E5573s-320/606-ULTIMATE GUIDE After searching on the net so many times, trying to find a way out to unlock the new modem/mifi on algo code 4 I found this guide very very powerful No ALgo code 4 needed No hash reader needed No code calculator needed NB: I CANT POST IMAGES MORE THAN 15, I had to remove some images to shorten the steps but it should be ok for you for full guide check on here https://forum.hovatek.com/thread-16008.html NB: I WONT POST ANY LINK BECAUSE IT WILL BE DELETED OR REMOVED WATCH THE PROCESS AND FIX YOUR MIFI everything is detailed and made easy with pictures Im using the E5573s-320 REQUIREMENTS 1. BALONG USB DOWNLOADER 2. E5573s-320/606 2.180 FIRMWARE 3. E5573s-320/606 2.11.9 firmware 4. E5573s-320/606 17v web UI - dashboard software-huawei 5. Huawei latest modem drivers v5-mifi drivers 6. Dc unlocker- FREE CLIENT VERSION 1. Im using MTN 4g mifi E5573s-320 for the process the Softwares need are shown in here 2. lets start, disassemble modem as shown in picture We need a pin to shot quickly the boot pin to the usb connector on PCB 3. Remove sim and battery they are not needed in the process Now short boot the boot pin, the first pin close to the usb cable connector on PCB as shown, the connect usb cable while holding the connection for detection After pc detection remove the pin, your connection is now stable for flashing watch for detection detection complete 4. Now extract and run Balong USB downloader as admin b. Click detect as shown in picture, with correct driver, you should see this -below NB: You need to download the huawei old and new mifi drivers c. Now extract the E5573s-320/606 2.11.9 firmware Now you should see a file called USBLOADER.bin This is the file that we will flash, at the same time it will unlock your modem Now lets flash Click Load to flash Now your Modem is unlocked After flashing the USBLOADER the modem is UNLOCKED 5. Now we will be able to downgrade without any error a. b. 6. Now we need to read dashboard to verify imei and WEbUI version b. Modem is unlocked Nothing else needed c. IMEI is written , Now ok 7. Now you see the dashboard version is zeros lets flash the WEBUI Now the webUI IS WRITTEN 8. Now lets upgrade the dashboard again to complete the process NB Without upgrading the dashboard to 2.180, the mifi may not work properly due to downgrade firmware installed, you will have problems with usage it is must to upgrade after the above process Now modem is ready for use I tested on 2g, 3g and 4g networks all working perfect Last edited by Droidmobitech; 12-05-2016 at 16:54. |
12-05-2016, 13:46 | #8 (permalink) |
Freak Poster Join Date: Aug 2014
Member: 2234281 Status: Offline Thanks Meter: 4 | Huawei e5573s-320 Thanks for your sharing. How to rewrite the IMEI of Huawei E5573S-320? |
12-05-2016, 16:43 | #9 (permalink) | |
Member: 2249268 Status: Offline Sonork: 1671720 Thanks Meter: 47 | Quote:
Code "AT^CIMEI="3589XXXXXXXXXXXX" XXXXX==PUT IMEI DIGIT Press Enter You should see Ok | |
12-06-2016, 22:31 | #10 (permalink) |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | MKEY - Modem Unlock Flash KEY Easy Unlock 5573CS322 / 609 / 323 and much Other WITHOUT LOSE IMEI or SSID or Kill NVM and lose Dashboard! Many reports from our users is Here : Mkey - Modem Unlock Key - GSM-Forum |
The Following 2 Users Say Thank You to TestBox2 For This Useful Post: |
