huawei 35573-cs-609 imei 0000 need help i tried with dc unlocker crack say imei ok but still 0000 s/n write ok but imei write failed i think its nv data fault or else but i need help for it thanks here is dc unlocker logs selection : manufacturer - Huawei modems model - Auto detect (recommended) Found Applications port COM86 Found modem : E5573CS-609 Model : Huawei E5573 (untested) IMEI : 000000000000000 Serial NR. : 5LL7S17401025990 Firmware : 21.318.99.03.00 Compile date / time : May 13 2016 11:45:50 Hardware ver. : CL1E5573CSM Ver.B Dashboard version : 00.00.00.000.00 SIM Lock status : unlocked Wrong codes entered : 0 (unlock attempts left : 10) ================================================== ================= AT^CIMEI="861350032976612" OK after that still same Detecting modem : selection : manufacturer - Huawei modems model - Huawei E5573 (untested) Selected Applications port COM86 Found modem : E5573CS-609 Model : Huawei E5573 (untested) IMEI : 000000000000000 Serial NR. : 5LL7S17401025990 Firmware : 21.318.99.03.00 Compile date / time : May 13 2016 11:45:50 Hardware ver. : CL1E5573CSM Ver.B Dashboard version : 00.00.00.000.00 SIM Lock status : unlocked Wrong codes entered : 0 (unlock attempts left : 10) |
any modem expert plz told me how to solve or back to stock |
close please i solved my problem |
Need unlock firmware Stc.5573s.932 |
for restore imei (repair) AT^NVWREX=0,0,16,x x x x x x x x x x x x x x 0 put x = digit of imei numer for seriel number= at^sn=xxxxxxxxxxxxxxx store these NV values in NVRAM, put this command AT ^ INFORBU done it .fix i more thing you use D99 firmware after reapir these values you need to change fw. |
E5573Cs-609TCPU-V200R001B323D01SP01C274_Firmware_Pakistan_Telenor Pakistan (Pvt) Limited_05014LHK but now i need to unlock it do you help me for |
https://drive.google.com/file/d/1HJb...ew?usp=sharing download telnor e5573cs-609 unlock file detect modme in dc then give at^godload command wait 5 sec for make com port in device manger then run file after flash modem will unlock done done |
alwinder bro i need a last help for it after all sim work ok but now device cannot reset or factory default not work what i can do |
usbloader you used that reason reset button not work i will upload program it will fix your modem then your modem will ok |
https://drive.google.com/file/d/1szG...ew?usp=sharing download this program then detect modem in dc then run file and enter pc ui com port number then press enter enter enter your modem will repair |
Help link not working sir ttps://drive.google.com/file/d/1szG...ew?usp=sharing download this program then detect modem in dc then run file and enter pc ui com port number then press enter enter enter your modem will repair Report Post |
