GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
12-19-2016, 17:49 | #61 (permalink) |
Junior Member Join Date: May 2007
Member: 514552 Status: Offline Thanks Meter: 1 | Please how do I get the mifi working back? Thanks |
12-20-2016, 11:22 | #63 (permalink) | |
Major Poster Join Date: Jul 2013 Location: Nigeria
Member: 1970813 Status: Offline Sonork: kofi Thanks Meter: 24 | Quote:
12-20-2016, 11:33 | #64 (permalink) | |
Member: 514552 Status: Offline Thanks Meter: 1 | Quote:
Thanks | |
12-21-2016, 08:07 | #66 (permalink) | |
If ur boot shot is successful , Ur mobile wifi two light will go off as if it is DEAD but it is not!!! All u need to do is to flash it with the correct files and ur mobile wifi is unlock!!! U most first of all flash it with this E5573cs_Update_21.318.99.03.00!!! Now for the second file to flash must be this Update_WEBUI_17.100.15.01.356_MRE5!!! Then the last file to flash is the E5573cs_Update_21.318.03.00.00!!! And ur mobile wifi is unlock!!! U can use the dc-unlock to see ur mobile wifi and rewite ur IMEI | |
12-21-2016, 08:24 | #67 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 496 | Quote:
Every Thing Ok Except Of Last Step >>>>Then the last file to flash is the E5573cs_Update_21.318.03.00.00!!! <<<<< Modem Dead On This Step | |
The Following User Says Thank You to shoaibrao For This Useful Post: |
12-21-2016, 10:59 | #68 (permalink) |
Member: 514552 Status: Offline Thanks Meter: 1 | Exactly the same problem I encoutered before I was able to revive it back. Its been unlocked and working fine, just that the moment it is powered off and powered on back, the 2 lights will be blinking as if it is still in that Balong stage, and it won't stop until I reflash it again. |
The Following User Says Thank You to wilfem For This Useful Post: |
12-22-2016, 12:40 | #70 (permalink) | |
12-22-2016, 16:45 | #71 (permalink) | |
Dead When Flash "E5573cs_Update_21.318.03.00.00" | |
12-24-2016, 18:02 | #74 (permalink) |
Member: 1970813 Status: Offline Sonork: kofi Thanks Meter: 24 | All the files u will need The problem is that u are using the wrong files or the right files with the wrong mobile WiFi so i want u to take a good look of ur mobile wifi or u can use dc unlock to know ur mobile WiFi by using USB to connect to ur pc. then u follow the step by step that i have mention in the past post and u can also get some files from here to GOODLUCK DOWNLOAD LINK Download Huawei Firmware Update / Upgrade / Downgrade Download Driver Update |
The Following User Says Thank You to sech444 For This Useful Post: |
12-24-2016, 22:01 | #75 (permalink) | |
Crazy Poster Join Date: Dec 2016 Location: Pakistan Age: 28
Member: 2661546 Status: Offline Thanks Meter: 9 | Quote:
The Following User Says Thank You to shah95 For This Useful Post: |
