Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 02-05-2017, 10:52   #1 (permalink)
Member: 70361
Thanks Meter: 20
Need Dump ZTE MF910+ Djezzy
Hi ,
after flashing my ZTE 910 With telia 09 firmware without taking a dump from my router , now i loose in it internet connection and wifi originaly it was destinated for Djezzy algeria
who can help me for restoring it ?
the difference is the telia firmware work with oled screen and mine work with led lights for showing state , then it isnt same firmware and some difference in hardware.
the method for getting dump is :
1- getting qtools_win.zip
2 - extract the zip file in directory ex: c:\qtools_win
3 - logon on your modem in http://192.168.0.1
4- launch in another page
http://192.168.0.1/goform/goform_pro...tchCmd=FACTORY
it change the router to modem
5- in device manager you find something seem like this :
then you launch rawdump9x25.cmd it will ask de diag port
the result file names rawdump.bin is approx 500 Mb after compress with 7 zip it dont exceed 100 Mb .
and thanx in advance
The Following 3 Users Say Thank You to rafik23 For This Useful Post:
Old 02-08-2017, 15:45   #2 (permalink)
Member: 520327
Sonork: 100.1636717
Thanks Meter: 84
plz explaine how to ?
Old 02-08-2017, 15:45   #3 (permalink)
Member: 2682479
Hello plese active me
Old 02-25-2017, 12:34   #4 (permalink)
Member: 423717
Thanks Meter: 11
here is the dump
https:// mega. nz/ #!z8sUlaQQ!xtFPh227BnHXdtdVIApMIowdS-FC-jbBlzdk9a8YtBk
The Following User Says Thank You to miseajour87 For This Useful Post:
Old 03-01-2017, 13:31   #5 (permalink)
Member: 2234281
Thanks Meter: 4
Mf910
Originally Posted by rafik23 View Post
Hi ,
after flashing my ZTE MF910 With telia 09 firmware without taking a dump from my router , now i loose in it internet connection and wifi originaly it was destinated for Djezzy algeria
What about changing to connect on another PC?
Old 03-01-2017, 18:23   #6 (permalink)
Member: 2357875
hi pleas help me to unlock my zte 910 + for all operator
Old 03-28-2017, 14:33   #7 (permalink)
Member: 2539274
Thanks Meter: 2
Hi please can you help me to exit fastboot mode on this modem ?
The modem is detest as Android Sooner Single ADB Interface
I tried a lot of commands as ''fastboot reboot reboot'' but nothing, is stucks on this mode
Please help
Old 03-31-2017, 00:09   #8 (permalink)
Member: 2701506
Sonork: 45556658712
Originally Posted by miseajour87 View Post
here is the dump
thanks you my friend
How use its in my mf910+ please help me
The Following User Says Thank You to miress For This Useful Post:
Old 04-12-2017, 09:43   #9 (permalink)
Member: 70361
Thanks Meter: 20
hi
the method is explain in 1st post but you must make save nvram with qpst
after reflash restore nvram
thx for the dump but the problem has been resolved
Old 12-20-2017, 20:23   #10 (permalink)
Member: 1582098
Thanks Meter: 17
hi
hi rafik can you post the nvram that worked for you i have the same situation 3G and 4G does not work i must restore nvram but i did not save it from the start.
thanks
Old 08-03-2018, 07:34   #11 (permalink)
Member: 2352644
Thanks Meter: 3
I have ZTE MF910+ running Maxis firmware and i want to remove the Maxis and have original ZTE firmware in it. I have another ZTE MF910+ running the Original ZTE firmware that i need. Is there a way to extract and flash it on the Maxis device ? Someone help pls
Old 08-05-2018, 14:06   #12 (permalink)
kamikazizs's Avatar
Member: 2695426
Thanks Meter: 1,453
You are in the right post you have to do exactly the descreption so you can extrat the original firmware from one modem to upload it to the other but remembere that you have to change the IMEi after that else you have two modem with the same IMEI
Old 08-07-2018, 13:11   #13 (permalink)
Member: 2352644
Thanks Meter: 3
If i got it right, the post Only explains how to get / extract the dump file, someone explain how to upload it to the other modem please, which command/ tool to use ?
Thanks
Old 08-07-2018, 13:18   #14 (permalink)
Member: 2352644
Thanks Meter: 3
I also have 2pcs ZTE MF920V Optus Logo soft bricked - interrupted during update and therefore will power on and connect for 5 seconds then go OFF and Signal indicator remains flashing.
If anyone can help me restore it.
Old 08-07-2018, 14:04   #15 (permalink)
kamikazizs's Avatar
Member: 2695426
Thanks Meter: 1,453
Thanks
You have right ; You do the same think with this command but you must have the dump file in the folder and copy this command "restorrawdump 9x25"to the same folder""qtools" and for the other modem MF920V i have no idea!
https://mega.nz/#!Q8BGnYAJ!4o3a2DHrfEXxw8YnE5Al1OmI3hq0FE2j4D0brdy YcfU
Page generated in 0.25752 seconds with 9 queries
